Not connected, Your IP: 3.238.5.144
Hi and good morning to all, I am here because,like so many others i am at the end of my tether and need help and assistance from those of you in the know.
I need to open ports for my Gameserver bypassing the VPN.
I will keep my first description as short as possible of my current setup and anybody whom wishes to help may ask for further details,
I have 2X instances of Pfsense running on a windows 2012 R2 server machine in Hyper-V, one is configured using this tut https://airvpn.org/topic/17444-how-to-set-up-pfsense-23-for-airvpn/ and the other handles the DHCP and Squid, my reasoning for this is, Squid does not play nice with Vpn's, i have tried everything to get them to work together but pfsense wants to use the default WAN when squid is installed so this was my workaround, i have tried others like pfBlockerNG but it does not have the level of control that Squid offers.
Now to the complicated bit, for the purpose of this i will refer to Pfsense 1 VPN as "Firewall" and Pfsense 2 DHCP & Squid as "Proxy",
The proxy
has 2X LAN subnets 192.168.1.1 which is the local LAN network and is hooked to Squid,
and 192.168.3.1 which is an isolated Lan i wish to use for a gameserver which has an Ip of 3.5
Then i have 2X wans 192.168.2.2 static which is bridged to 2.1 on the firewall,
and 192.168.4.2 Vlan-Id=10 which connects to 4.1 Vlan-Id=10 on the Firewall, my 192.168.3.5 is routed out this interface in order for it to be passed to the firewall and onto the WAN
The Firewall
is set up as described in the tut above and works as intended with the exception that the default LAN has changed to 192.168.2.1 is now a Virtual LAN interface and is bridged with the Virtual WAN interface of the proxy which is 2.2,
It also has a another LAN interface VLAN of 192.168.4.1 Id =10 which is hooked up to the 4.2 of the proxy, this interface is to bypass the VPN and is routed out the WAN.
Up until this point everything works as intended normal LAN clients can access the internet through the VPN, and my isolated Subnet can access the web through the WAN, i can also access any game servers i have running locally, and this is where the fun ends, for the life of me i cant get ports open to the outside world, it is strange to me that my Gameserver can access the web and servers can contact steam but beyond that, there seems to be no ports open, i have tried many things such  as forwarding ports using nat out the various gateways.
According to the various port checking sites i have visited all my ports are closed, even port 80 and i know this can not be because i can access the web just fine.
I appreciate that i may have many extra steps to take with my currant configuration in order to get this to work, and i am very much looking forward to any help than can be given.
Thanks in Advance.
