guppie 1 Posted ... for the past few days i haven't been able to connect to the vpn with network lock enabled only when its disabled. 1 GIUUcfUSurP6Df5RetWGpf6Lse reacted to this Quote Share this post Link to post
LZ1 662 Posted ... Hello! Then please share your Eddie logs . If you don't know how, you can refer to the FAQ link in my signature. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
GIUUcfUSurP6Df5RetWGpf6Lse 8 Posted ... Hi, I have the same issue at the moment. When the Network Lock is active, there is not connection to AirVPN servers (unable to check authorization). System: Windows 10AirVPN client version: 2.10.3 Logs of failed instances: I 2018.07.28 07.57.20 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64 . 2018.07.28 07.57.20 - Reading options from C:\Users\user\AppData\Local\AirVPN\AirVPN.xml . 2018.07.28 07.57.20 - Data Path: C:\Users\user\AppData\Local\AirVPN . 2018.07.28 07.57.20 - App Path: C:\Program Files\AirVPN . 2018.07.28 07.57.20 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe . 2018.07.28 07.57.20 - Command line arguments (1): path="home" . 2018.07.28 07.57.20 - Operating System: Microsoft Windows NT 6.2.9200.0 . 2018.07.28 07.57.20 - Updating systems & servers data ... . 2018.07.28 07.57.21 - Systems & servers data update completed I 2018.07.28 07.57.21 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 I 2018.07.28 07.57.21 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe) I 2018.07.28 07.57.21 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe) I 2018.07.28 07.57.21 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe) ! 2018.07.28 07.57.21 - Activation of Network Lock - Windows Firewall I 2018.07.28 07.57.25 - Session starting. I 2018.07.28 07.57.25 - Checking authorization ... . 2018.07.28 07.57.25 - Checking authorization ..., 1° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.25 - Checking authorization ..., 2° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.25 - Checking authorization ..., 3° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.25 - Checking authorization ..., 4° try failed (Unable to connect to the remote server) W 2018.07.28 07.57.25 - Authorization check failed, continue anyway ({1]) ! 2018.07.28 07.57.25 - Connecting to Musica (Netherlands, Alblasserdam) . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:25 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:25 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015 . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:25 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:25 LOG5[ui]: Reading configuration from file C:\Users\user\AppData\Local\AirVPN\8061219069b9c8e322610a2fdd30ceb06dce9b63a1ad79e298abc2e1574fd47f.tmp.ssl . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:25 LOG5[ui]: UTF-8 byte order mark not detected . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG6[ui]: Initializing service [openvpn] . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG5[ui]: Configuration successful . 2018.07.28 07.57.26 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2018.07.28 07.57.26 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2018.07.28 07.57.26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104 . 2018.07.28 07.57.26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2018.07.28 07.57.26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.57.26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.57.26 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072] . 2018.07.28 07.57.26 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:8914 [nonblock] . 2018.07.28 07.57.26 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:8914 . 2018.07.28 07.57.26 - OpenVPN > TCPv4_CLIENT link local: [undef] . 2018.07.28 07.57.26 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:8914 . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:34512 . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG6[0]: Failover strategy: round-robin . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG6[0]: s_connect: connecting 213.152.161.250:443 . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG3[0]: s_connect: connect 213.152.161.250:443: Permission denied (WSAEACCES) (10013) . 2018.07.28 07.57.26 - SSL > 2018.07.28 07:57:26 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket . 2018.07.28 07.57.26 - OpenVPN > Connection reset, restarting [-1] . 2018.07.28 07.57.26 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting . 2018.07.28 07.57.26 - OpenVPN > Restart pause, 5 second(s) ! 2018.07.28 07.57.26 - Disconnecting ------ END OF FIRST TRY - The program then continues to try several more times ------ . 2018.07.28 07.57.26 - Connection terminated. I 2018.07.28 07.57.29 - Checking authorization ... . 2018.07.28 07.57.29 - Checking authorization ..., 1° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.29 - Checking authorization ..., 2° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.29 - Checking authorization ..., 3° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.29 - Checking authorization ..., 4° try failed (Unable to connect to the remote server) W 2018.07.28 07.57.29 - Authorization check failed, continue anyway ({1]) ! 2018.07.28 07.57.29 - Connecting to Musica (Netherlands, Alblasserdam) . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:29 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:29 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015 . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:29 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:29 LOG5[ui]: Reading configuration from file C:\Users\user\AppData\Local\AirVPN\e48d2d190711f5058b57c8e18fee2ad1e66df7d2cb1518cfa4e68323e665ac75.tmp.ssl . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:29 LOG5[ui]: UTF-8 byte order mark not detected . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG6[ui]: Initializing service [openvpn] . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG5[ui]: Configuration successful . 2018.07.28 07.57.30 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2018.07.28 07.57.30 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2018.07.28 07.57.30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104 . 2018.07.28 07.57.30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2018.07.28 07.57.30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.57.30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.57.30 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072] . 2018.07.28 07.57.30 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:47856 [nonblock] . 2018.07.28 07.57.30 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:47856 . 2018.07.28 07.57.30 - OpenVPN > TCPv4_CLIENT link local: [undef] . 2018.07.28 07.57.30 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:47856 . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:34526 . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG6[0]: Failover strategy: round-robin . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG6[0]: s_connect: connecting 213.152.161.250:443 . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG3[0]: s_connect: connect 213.152.161.250:443: Permission denied (WSAEACCES) (10013) . 2018.07.28 07.57.30 - SSL > 2018.07.28 07:57:30 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket . 2018.07.28 07.57.30 - OpenVPN > Connection reset, restarting [-1] . 2018.07.28 07.57.30 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting . 2018.07.28 07.57.30 - OpenVPN > Restart pause, 5 second(s) ! 2018.07.28 07.57.30 - Disconnecting . 2018.07.28 07.57.30 - Connection terminated. I 2018.07.28 07.57.33 - Checking authorization ... . 2018.07.28 07.57.33 - Checking authorization ..., 1° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.33 - Checking authorization ..., 2° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.33 - Checking authorization ..., 3° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.33 - Checking authorization ..., 4° try failed (Unable to connect to the remote server) W 2018.07.28 07.57.33 - Authorization check failed, continue anyway ({1]) ! 2018.07.28 07.57.33 - Connecting to Musica (Netherlands, Alblasserdam) . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015 . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[ui]: Reading configuration from file C:\Users\user\AppData\Local\AirVPN\5fa8da962d3a0acfdaf8bcd4c7e83da9d2539c7d44080a177036b10cdf20ea41.tmp.ssl . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[ui]: UTF-8 byte order mark not detected . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG6[ui]: Initializing service [openvpn] . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[ui]: Configuration successful . 2018.07.28 07.57.34 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2018.07.28 07.57.34 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2018.07.28 07.57.34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104 . 2018.07.28 07.57.34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2018.07.28 07.57.34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:34556 . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG6[0]: Failover strategy: round-robin . 2018.07.28 07.57.34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG6[0]: s_connect: connecting 213.152.161.250:443 . 2018.07.28 07.57.34 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072] . 2018.07.28 07.57.34 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:64390 [nonblock] . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG3[0]: s_connect: connect 213.152.161.250:443: Permission denied (WSAEACCES) (10013) . 2018.07.28 07.57.34 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:64390 . 2018.07.28 07.57.34 - SSL > 2018.07.28 07:57:34 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket . 2018.07.28 07.57.34 - OpenVPN > TCPv4_CLIENT link local: [undef] . 2018.07.28 07.57.34 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:64390 . 2018.07.28 07.57.34 - OpenVPN > Connection reset, restarting [-1] . 2018.07.28 07.57.34 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting . 2018.07.28 07.57.34 - OpenVPN > Restart pause, 5 second(s) ! 2018.07.28 07.57.35 - Disconnecting . 2018.07.28 07.57.35 - Connection terminated. I 2018.07.28 07.57.36 - Cancel requested. ! 2018.07.28 07.57.36 - Session terminated. ! 2018.07.28 07.57.47 - Logged out. I 2018.07.28 07.57.48 - Checking login ... . 2018.07.28 07.57.48 - Checking login ..., 1° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.48 - Checking login ..., 2° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.48 - Checking login ..., 3° try failed (Unable to connect to the remote server) . 2018.07.28 07.57.48 - Checking login ..., 4° try failed (Unable to connect to the remote server) F 2018.07.28 07.57.48 - Cannot login. (Unable to connect to the remote server) I then disabled the network lock and it connected normally: ! 2018.07.28 07.57.57 - Deactivation of Network Lock I 2018.07.28 07.58.03 - Checking login ... ! 2018.07.28 07.58.03 - Logged in. I 2018.07.28 07.58.07 - Session starting. I 2018.07.28 07.58.08 - Checking authorization ... ! 2018.07.28 07.58.08 - Connecting to Capricornus (Belgium, Brussels) . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015 . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG5[ui]: Reading configuration from file C:\Users\user\AppData\Local\AirVPN\d4182f9a6940e2aa1967e2dfb0e16eaf2b4b2f0838a0c5fa17141001795f9d5f.tmp.ssl . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG5[ui]: UTF-8 byte order mark not detected . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG6[ui]: Initializing service [openvpn] . 2018.07.28 07.58.09 - SSL > 2018.07.28 07:58:08 LOG5[ui]: Configuration successful . 2018.07.28 07.58.09 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2018.07.28 07.58.09 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2018.07.28 07.58.09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104 . 2018.07.28 07.58.10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2018.07.28 07.58.10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:34616 . 2018.07.28 07.58.10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.58.10 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072] . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG6[0]: Failover strategy: round-robin . 2018.07.28 07.58.10 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:52405 [nonblock] . 2018.07.28 07.58.10 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:52405 . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG6[0]: s_connect: connecting 194.187.251.92:443 . 2018.07.28 07.58.10 - OpenVPN > TCPv4_CLIENT link local: [undef] . 2018.07.28 07.58.10 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:52405 . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG5[0]: s_connect: connected 194.187.251.92:443 . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.6:34617 . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG6[0]: SNI: sending servername: 194.187.251.92 . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG6[0]: CERT: Locally installed certificate matched . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG6[0]: SSL connected: new session negotiated . 2018.07.28 07.58.10 - SSL > 2018.07.28 07:58:10 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption) . 2018.07.28 07.58.10 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:52405, sid=56528f53 0f9236c9 . 2018.07.28 07.58.10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2018.07.28 07.58.10 - OpenVPN > Validating certificate key usage . 2018.07.28 07.58.10 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2018.07.28 07.58.10 - OpenVPN > VERIFY KU OK . 2018.07.28 07.58.10 - OpenVPN > Validating certificate extended key usage . 2018.07.28 07.58.10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2018.07.28 07.58.10 - OpenVPN > VERIFY EKU OK . 2018.07.28 07.58.10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Capricornus, emailAddress=info@airvpn.org . 2018.07.28 07.58.11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2018.07.28 07.58.11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.58.11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2018.07.28 07.58.11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.07.28 07.58.11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2018.07.28 07.58.11 - OpenVPN > [Capricornus] Peer Connection Initiated with [AF_INET]127.0.0.1:52405 . 2018.07.28 07.58.13 - OpenVPN > SENT CONTROL [Capricornus]: 'PUSH_REQUEST' (status=1) . 2018.07.28 07.58.13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.12.161.1,route-gateway 10.12.161.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.12.161.41 255.255.255.0,peer-id 0' . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: route options modified . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: peer-id set . 2018.07.28 07.58.13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1563 . 2018.07.28 07.58.13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2018.07.28 07.58.13 - OpenVPN > open_tun, tt->ipv6=0 . 2018.07.28 07.58.13 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{36EA314C-E21B-4A06-B2EA-0FF9898B68A9}.tap . 2018.07.28 07.58.13 - OpenVPN > TAP-Windows Driver Version 9.21 . 2018.07.28 07.58.13 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.12.161.0/10.12.161.41/255.255.255.0 [SUCCEEDED] . 2018.07.28 07.58.13 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.12.161.41/255.255.255.0 on interface {36EA314C-E21B-4A06-B2EA-0FF9898B68A9} [DHCP-serv: 10.12.161.254, lease-time: 31536000] . 2018.07.28 07.58.13 - OpenVPN > Successful ARP Flush on interface [7] {36EA314C-E21B-4A06-B2EA-0FF9898B68A9} . 2018.07.28 07.58.18 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up . 2018.07.28 07.58.18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1 . 2018.07.28 07.58.18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2018.07.28 07.58.18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2018.07.28 07.58.18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 12 . 2018.07.28 07.58.18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2018.07.28 07.58.18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2018.07.28 07.58.18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.12.161.1 . 2018.07.28 07.58.18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2018.07.28 07.58.18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2018.07.28 07.58.18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.12.161.1 . 2018.07.28 07.58.18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2018.07.28 07.58.18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2018.07.28 07.58.18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 194.187.251.92 MASK 255.255.255.255 192.168.0.1 . 2018.07.28 07.58.18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2018.07.28 07.58.18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2018.07.28 07.58.18 - Starting Management Interface . 2018.07.28 07.58.18 - OpenVPN > Initialization Sequence Completed I 2018.07.28 07.58.19 - DNS of a network adapter forced (TAP-Windows Adapter V9) I 2018.07.28 07.58.33 - DNS of a network adapter forced (Realtek USB GbE Family Controller) I 2018.07.28 07.58.46 - Flushing DNS I 2018.07.28 07.58.57 - Checking route I 2018.07.28 07.59.01 - Checking DNS ! 2018.07.28 07.59.01 - Connected. . 2018.07.28 07.59.01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3104 . 2018.07.28 07.59.02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info Thanks for any help. Please let me know if I can provide something more to help troubleshoot. 1 JimboT reacted to this Quote Share this post Link to post
Staff 9761 Posted ... Hello!Eddie 2.10.3 is very old, it's time to upgrade. Can you please upgrade to Eddie 2.15.2 (latest stable release) and test again? This new version might be able to resolve the problem.You can download the latest release of Eddie for WIndows in our web site page "Enter" > "Windows", direct link https://airvpn.org/windowsWe're looking forward to hearing from you.Kind regards 1 GIUUcfUSurP6Df5RetWGpf6Lse reacted to this Quote Share this post Link to post
GIUUcfUSurP6Df5RetWGpf6Lse 8 Posted ... Hi, thank you very much for that! Upgrading helped. I had no idea I was using an old client and just never thought about updating. Sorry for the confusion there. Quote Share this post Link to post
