h29 1 Posted ... Hey Guys, since yesterday all airVPN servers in Beijing (China) are down. I'm subscribed to two VPN providers and right now only 2 servers are working, none from airVPN. All servers went offline at the same time. Can't connect through my phone either. Just me? Thanks for quick responses! 1 MrRoboto reacted to this Quote Share this post Link to post
hugomueller 13 Posted ... China is blocking VPNs. Go to preferences and protocols. Choose a different entry IP (ip 2,3 or 4) and try to connect. If this does not help use entry ip 4 and ssl. Quote Share this post Link to post
jacqueraymer 0 Posted ... indeed, my GF in china also suddenly cant connect since yesterday, and she has tried various ports in Eddie, its down on her mobile as well. Quote Share this post Link to post
Staff 10414 Posted ... Hey Guys, since yesterday all airVPN servers in Beijing (China) are down. I'm subscribed to two VPN providers and right now only 2 servers are working, none from airVPN. All servers went offline at the same time. Can't connect through my phone either. Just me? Thanks for quick responses! You were lucky you did not need anti-blocking techniques earlier. They have been enforced since many years ago in wide areas of China. Do not hesitate to open a ticket if you have still troubles after you have applied the recommendations in this thread. Kind regards Quote Share this post Link to post
MrRoboto 0 Posted ... Same here. I switched to servers in Bulgaria and Latvia, which works occasionally.Also, in AirVPN preferences, I switched to protocol from "automatic" to SSL tunnel port 443.Works now, don't know for how long. Quote Share this post Link to post
h29 1 Posted ... The point is, that they even blocked all cellular connections. Which is unusual in Beijing.... To all other people with the same problem: right now only the bottom SSL protocols are working. I had to activate IPv6 in my adapter settings too. Why do the other VPN providers don't need the SSL protocols? Some of their servers are working again. Quote Share this post Link to post
stevebeck 0 Posted ... Thanks for the help. I've been in China (Guangzhou) for over a year and have had little trouble using AirVPN with the default settings. Since Friday I haven't been able to connect at all however. (Incidentally the BBC News is blocked now too which it hasn't been for years.) Changing to protocol UDP port 443 I'm now able to connect on my computer. I'm still having trouble with my mobile connection however. I'm not sure how to change these settings in the OpenVPN app (not very technically literate I'm afraid...) but it seems I was already using UDP 443 and now that's not working. Quote Share this post Link to post
Staff 10414 Posted ... Thanks for the help. I've been in China (Guangzhou) for over a year and have had little trouble using AirVPN with the default settings. Since Friday I haven't been able to connect at all however. (Incidentally the BBC News is blocked now too which it hasn't been for years.) Changing to protocol UDP port 443 I'm now able to connect on my computer. I'm still having trouble with my mobile connection however. I'm not sure how to change these settings in the OpenVPN app (not very technically literate I'm afraid...) but it seems I was already using UDP 443 and now that's not working. Hello! On your Android or iOS device you need to re-generate a configuration file and import it as a profile in your application (openvpn-connect, OpenVPN for Android...). Try the following settings:- click "Advanced Mode" in the Configuration Generator- select protocol TCP, port 443, entry-IP address 3- proceed as usual to download / import the profile On entry-IP addresses 3 and 4 of our VPN servers you have OpenVPN working with "tls-crypt". It means that the whole Control Channel of OpenVPN is encrypted. This connection mode has showed great abilities to bypass a wide variety of blocks. In this case we also suggest TCP because, according to the reports we have been receiving from China in the last years, it is not uncommon that UDP gets entirely blocked on mobile lines. UPDATE: with our software Eddie Android edition, you will not need the Configuration Generator anymore in Android. Eddie will try by itself anti-blocking connection modes. If you don't wish to wait (Eddie may need up to 1 minute to find the proper way to circumvent China blocks). go to the "Settings" view and please set:Custom protocol option to TCPCustom port to 443Custom TLS mode to tls-cryptQuick connection mode to Use custom settingsEddie will connect to port 443, with protocol TCP, using tls-crypt. Kind regards Quote Share this post Link to post
stevebeck 0 Posted ... Thanks for the help. I've been in China (Guangzhou) for over a year and have had little trouble using AirVPN with the default settings. Since Friday I haven't been able to connect at all however. (Incidentally the BBC News is blocked now too which it hasn't been for years.) Changing to protocol UDP port 443 I'm now able to connect on my computer. I'm still having trouble with my mobile connection however. I'm not sure how to change these settings in the OpenVPN app (not very technically literate I'm afraid...) but it seems I was already using UDP 443 and now that's not working. Hello! On your Android or iOS device you need to re-generate a configuration file and import it as a profile in your application (openvpn-connect, OpenVPN for Android...). Try the following settings:- click "Advanced Mode" in the Configuration Generator- select protocol TCP, port 443, entry-IP address 3- proceed as usual to download / import the profile On entry-IP addresses 3 and 4 of our VPN servers you have OpenVPN working with "tls-crypt". It means that the whole Control Channel of OpenVPN is encrypted. This connection mode has showed great abilities to bypass a wide variety of blocks. In this case we also suggest TCP because, according to the reports we have been receiving from China in the last years, it is not uncommon that UDP gets entirely blocked on mobile lines. Kind regards Thank you so much! Fixed now. Sorry if this had already been answered somewhere else. Quote Share this post Link to post
bloodstroke 0 Posted ... I’m in Beijing. Some unblocked servers went up for little more than a day, but by yesterday they were blocked too. The blocked ones have a “...........” in place of latency. I’ve tried all the protocals, no luck there. Any updates? Quote Share this post Link to post
Staff 10414 Posted ... Hello! Thread has been updated to reflect new options for Android. Kind regards Quote Share this post Link to post
