Not connected, Your IP: 34.238.138.162
Connorh16
Tap-Windows connection problem
I have a slight annoyance every time I want to connect to a server I have to uninstall TAP-Windows and then let the UI automatically re-install it when connecting to a server. If I don't uninstall TAP when trying to connect to a server It just gets stuck on connecting.
If you post a log maybe someone could help you out or failing that put in a support request (from client area).
