candlelight53
Anyway to use Tor over VPN with a kill switch
Hi, I know that you can't use network lock in conjunction with the Tor over VPN feature, but I don't want to have to choose between extra anonymity and the scare of a possible leak. Is there anyway to use the Tor over VPN feature, while also using a killswitch? I've looked around the forums here and on other sites, but I haven't found anything useful or that actually worked. So how do other people find a way to use Tor over VPN with a kill switch type fail safe? I use a mac computer along with the eddie application.
You can use Network Lock with Tor over OpenVPN. However you can't use it with OpenVPN over Tor, because the Tor guard entry-IP can't be known before the Tor circuit is established.
You can get something like the GL iNet MT-300N router like I have, set it up with a VPN on the router with their firmware or the openwrt debloated that they provide. and use tor on pc. Or you could use the router with tor and then use a VPN on pc without tor and use your killswitch. I hope this would provide what you want.
