Not connected, Your IP: 3.138.101.95
glm
Connection can't be established
I can't connect to any of the servers right now and looking at the logs doesn't really help me right now.
I already set all the preferences to default, updated Eddie and restarted my Computer.
Maybe one of you guys has an idea, here are the logs:
I 2018.06.29 20:15:30 - Session starting.
I 2018.06.29 20:15:30 - Checking authorization ...
! 2018.06.29 20:15:31 - Connecting to Nash (Netherlands, Alblasserdam)
. 2018.06.29 20:15:31 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.06.29 20:15:31 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.06.29 20:15:31 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.06.29 20:15:31 - Connection to OpenVPN Management Interface
. 2018.06.29 20:15:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.06.29 20:15:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.06.29 20:15:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.06.29 20:15:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.24:443
. 2018.06.29 20:15:31 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.06.29 20:15:31 - OpenVPN > UDP link local: (not bound)
. 2018.06.29 20:15:31 - OpenVPN > UDP link remote: [AF_INET]213.152.161.24:443
. 2018.06.29 20:15:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.06.29 20:16:03 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2018.06.29 20:16:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.06.29 20:16:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2018.06.29 20:16:08 - Disconnecting
. 2018.06.29 20:16:08 - Connection terminated.
I 2018.06.29 20:16:11 - Checking authorization ...
. 2018.06.29 20:16:11 - IPv6 disabled with packet filtering.
! 2018.06.29 20:16:11 - Connecting to Gienah (Netherlands, Alblasserdam)
. 2018.06.29 20:16:11 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.06.29 20:16:11 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.06.29 20:16:11 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.06.29 20:16:11 - Connection to OpenVPN Management Interface
. 2018.06.29 20:16:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.06.29 20:16:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.06.29 20:16:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.06.29 20:16:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.93:443
. 2018.06.29 20:16:11 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.06.29 20:16:11 - OpenVPN > UDP link local: (not bound)
. 2018.06.29 20:16:11 - OpenVPN > UDP link remote: [AF_INET]213.152.162.93:443
. 2018.06.29 20:16:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.06.29 20:16:44 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2018.06.29 20:16:44 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.06.29 20:16:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2018.06.29 20:16:49 - Disconnecting
. 2018.06.29 20:16:49 - Connection terminated.
. 2018.06.29 20:16:49 - IPv6 restored with packet filtering.
I 2018.06.29 20:16:51 - Cancel requested.
! 2018.06.29 20:16:51 - Session terminated.
That worked. Thanks! Don't know what happened, it worked fine for a year until today.
