Reconnect Loop - Where's the problem?
reconnect loop
  • Please log in to reply
5 replies to this topic
#1 36KkJAWRkjDYPbtGZoNarPg
  • Members
  • Pip
  • 3 posts
Posted 24 June 2018 - 02:00 AM
Hey there,
using latest version of eddie on Mac OS Yosemite 10.10.5 !
Eddie worked fine a few months ago, but needed to uninstall. Problem only occurs now for first time after some months not using.
PROBLEM:
Connect - Disconnect - Connect - Disconnect - Loop...
Thanks for your help!
Here's the LOG:
. 2018.06.23 18:25:04 - Eddie version: 2.15.2 / macos_x64, System: MacOS, Name: 10.10.5, Version: Darwin Serandomirs-MacBook-Pro.local 14.5.0 Darwin Kernel Version 14.5.0: Sun Jun  4 21:40:08 PDT 2017; root:xnu-2782.70.3~1/RELEASE_X86_64 x86_64, Mono/.Net: v4.0.30319
. 2018.06.23 18:25:04 - Reading options from /Users/serandomir/.airvpn/default.xml
. 2018.06.23 18:25:06 - Command line arguments (0):
. 2018.06.23 18:25:06 - Profile path: /Users/serandomir/.airvpn/default.xml
. 2018.06.23 18:25:09 - OpenVPN Driver - Expected
. 2018.06.23 18:25:09 - OpenVPN - Version:  -  (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2018.06.23 18:25:09 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
. 2018.06.23 18:25:09 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2018.06.23 18:25:09 - curl - Version: 7.43.0 (/usr/bin/curl)
. 2018.06.23 18:25:09 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem
. 2018.06.23 18:25:10 - Updating systems & servers data ...
I 2018.06.23 18:25:10 - Ready
. 2018.06.23 18:25:11 - Systems & servers data update completed
! 2018.06.23 18:25:16 - Activation of Network Lock - macOS - PF
. 2018.06.23 18:25:16 - macOS - PF rules updated, reloading
I 2018.06.23 18:25:22 - Session starting.
I 2018.06.23 18:25:23 - Checking authorization ...
! 2018.06.23 18:25:24 - Connecting to Errai (Germany, Frankfurt)
. 2018.06.23 18:25:24 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:25:24 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:25:24 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:25:24 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:25:24 - Above log line repeated 1 times more
! 2018.06.23 18:25:24 - Disconnecting
. 2018.06.23 18:25:24 - Connection terminated.
I 2018.06.23 18:25:27 - Checking authorization ...
. 2018.06.23 18:25:28 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:25:28 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:25:28 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:25:28 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:25:28 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:25:29 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:25:29 - Connecting to Libertas (Germany, Munich)
. 2018.06.23 18:25:29 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:25:29 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:25:29 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:25:29 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:25:29 - Above log line repeated 1 times more
! 2018.06.23 18:25:29 - Disconnecting
. 2018.06.23 18:25:29 - Connection terminated.
. 2018.06.23 18:25:29 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:25:29 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:25:29 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:25:29 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:25:29 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:25:29 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:25:32 - Checking authorization ...
! 2018.06.23 18:25:33 - Connecting to Mesarthim (Germany, Munich)
. 2018.06.23 18:25:33 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:25:33 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:25:33 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:25:33 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:25:33 - Above log line repeated 1 times more
! 2018.06.23 18:25:33 - Disconnecting
. 2018.06.23 18:25:33 - Connection terminated.
I 2018.06.23 18:25:36 - Checking authorization ...
! 2018.06.23 18:25:37 - Connecting to Perseus (Germany, Munich)
. 2018.06.23 18:25:37 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:25:37 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:25:38 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:25:38 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:25:38 - Above log line repeated 1 times more
! 2018.06.23 18:25:38 - Disconnecting
. 2018.06.23 18:25:38 - Connection terminated.
I 2018.06.23 18:25:41 - Checking authorization ...
! 2018.06.23 18:25:41 - Connecting to Lepus (Germany, Munich)
. 2018.06.23 18:25:42 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:25:42 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:25:42 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:25:42 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:25:42 - Above log line repeated 1 times more
! 2018.06.23 18:25:42 - Disconnecting
. 2018.06.23 18:25:42 - Connection terminated.
I 2018.06.23 18:25:45 - Checking authorization ...
! 2018.06.23 18:25:46 - Connecting to Adhara (Germany, Frankfurt)
. 2018.06.23 18:25:46 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:25:46 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:25:46 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:25:46 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:25:46 - Above log line repeated 1 times more
! 2018.06.23 18:25:46 - Disconnecting
. 2018.06.23 18:25:46 - Connection terminated.
I 2018.06.23 18:25:47 - Cancel requested.
! 2018.06.23 18:25:47 - Session terminated.
! 2018.06.23 18:26:06 - Deactivation of Network Lock
I 2018.06.23 18:36:49 - Session starting.
I 2018.06.23 18:36:49 - Retrieving manifest
. 2018.06.23 18:36:49 - Updating systems & servers data ...
I 2018.06.23 18:36:49 - Checking authorization ...
! 2018.06.23 18:36:50 - Connecting to Cervantes (Germany, Frankfurt)
. 2018.06.23 18:36:51 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:36:51 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:36:51 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:36:51 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:36:51 - Above log line repeated 1 times more
! 2018.06.23 18:36:51 - Disconnecting
. 2018.06.23 18:36:51 - Connection terminated.
. 2018.06.23 18:36:51 - Systems & servers data update completed
I 2018.06.23 18:36:54 - Checking authorization ...
! 2018.06.23 18:36:55 - Connecting to Ogma (Germany, Frankfurt)
. 2018.06.23 18:36:55 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:36:55 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:36:55 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:36:55 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:36:55 - Above log line repeated 1 times more
! 2018.06.23 18:36:55 - Disconnecting
. 2018.06.23 18:36:55 - Connection terminated.
I 2018.06.23 18:36:58 - Checking authorization ...
! 2018.06.23 18:36:59 - Connecting to Perseus (Germany, Munich)
. 2018.06.23 18:36:59 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:36:59 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:36:59 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:36:59 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:36:59 - Above log line repeated 1 times more
! 2018.06.23 18:36:59 - Disconnecting
. 2018.06.23 18:36:59 - Connection terminated.
I 2018.06.23 18:37:02 - Checking authorization ...
. 2018.06.23 18:37:03 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:03 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:03 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:03 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:03 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:03 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:03 - Connecting to Libertas (Germany, Munich)
. 2018.06.23 18:37:04 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:04 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:04 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:04 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:04 - Above log line repeated 1 times more
! 2018.06.23 18:37:04 - Disconnecting
. 2018.06.23 18:37:04 - Connection terminated.
. 2018.06.23 18:37:04 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:04 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:04 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:04 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:04 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:04 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:37:07 - Checking authorization ...
! 2018.06.23 18:37:08 - Connecting to Mesarthim (Germany, Munich)
. 2018.06.23 18:37:08 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:08 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:08 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:08 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:08 - Above log line repeated 1 times more
! 2018.06.23 18:37:08 - Disconnecting
. 2018.06.23 18:37:08 - Connection terminated.
I 2018.06.23 18:37:11 - Checking authorization ...
! 2018.06.23 18:37:12 - Connecting to Lepus (Germany, Munich)
. 2018.06.23 18:37:12 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:12 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:12 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:12 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:12 - Above log line repeated 1 times more
! 2018.06.23 18:37:12 - Disconnecting
. 2018.06.23 18:37:12 - Connection terminated.
I 2018.06.23 18:37:15 - Checking authorization ...
! 2018.06.23 18:37:16 - Connecting to Adhara (Germany, Frankfurt)
. 2018.06.23 18:37:16 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:16 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:16 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:16 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:16 - Above log line repeated 1 times more
! 2018.06.23 18:37:16 - Disconnecting
. 2018.06.23 18:37:16 - Connection terminated.
I 2018.06.23 18:37:19 - Checking authorization ...
! 2018.06.23 18:37:20 - Connecting to Errai (Germany, Frankfurt)
. 2018.06.23 18:37:20 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:20 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:20 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:20 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:20 - Above log line repeated 1 times more
! 2018.06.23 18:37:20 - Disconnecting
. 2018.06.23 18:37:20 - Connection terminated.
I 2018.06.23 18:37:23 - Checking authorization ...
! 2018.06.23 18:37:24 - Connecting to Cervantes (Germany, Frankfurt)
. 2018.06.23 18:37:24 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:24 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:24 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:24 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:24 - Above log line repeated 1 times more
! 2018.06.23 18:37:24 - Disconnecting
. 2018.06.23 18:37:24 - Connection terminated.
I 2018.06.23 18:37:27 - Checking authorization ...
. 2018.06.23 18:37:28 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:29 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:29 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:29 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:29 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:29 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:29 - Connecting to Kleeia (Canada, Vancouver)
. 2018.06.23 18:37:29 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:29 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:29 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:29 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:29 - Above log line repeated 1 times more
! 2018.06.23 18:37:29 - Disconnecting
. 2018.06.23 18:37:29 - Connection terminated.
. 2018.06.23 18:37:29 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:29 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:30 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:30 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:30 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:30 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:37:33 - Checking authorization ...
. 2018.06.23 18:37:34 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:34 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:34 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:34 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:34 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:35 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:35 - Connecting to Gemma (Canada, Vancouver)
. 2018.06.23 18:37:35 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:35 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:35 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:35 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:35 - Above log line repeated 1 times more
! 2018.06.23 18:37:35 - Disconnecting
. 2018.06.23 18:37:35 - Connection terminated.
. 2018.06.23 18:37:35 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:35 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:35 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:35 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:35 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:35 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:37:38 - Checking authorization ...
. 2018.06.23 18:37:39 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:39 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:39 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:40 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:40 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:40 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:40 - Connecting to Homam (Canada, Vancouver)
. 2018.06.23 18:37:40 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:40 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:40 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:40 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:40 - Above log line repeated 1 times more
! 2018.06.23 18:37:40 - Disconnecting
. 2018.06.23 18:37:40 - Connection terminated.
. 2018.06.23 18:37:40 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:40 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:41 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:41 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:41 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:41 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:37:44 - Checking authorization ...
. 2018.06.23 18:37:45 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:45 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:45 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:45 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:45 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:46 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:46 - Connecting to Mimosa (Canada, Vancouver)
. 2018.06.23 18:37:46 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:46 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:46 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:46 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:47 - Above log line repeated 1 times more
! 2018.06.23 18:37:47 - Disconnecting
. 2018.06.23 18:37:47 - Connection terminated.
. 2018.06.23 18:37:47 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:47 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:47 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:47 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:47 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:47 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:37:50 - Checking authorization ...
. 2018.06.23 18:37:51 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:51 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:52 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:52 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:52 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:52 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:52 - Connecting to Cynosura (Canada, Vancouver)
. 2018.06.23 18:37:52 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:52 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:52 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:52 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:53 - Above log line repeated 1 times more
! 2018.06.23 18:37:53 - Disconnecting
. 2018.06.23 18:37:53 - Connection terminated.
. 2018.06.23 18:37:53 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:53 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:53 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:53 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:53 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:53 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:37:56 - Checking authorization ...
. 2018.06.23 18:37:58 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:58 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:37:58 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:37:58 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:37:58 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:58 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:37:58 - Connecting to Ukdah (Canada, Toronto, Ontario)
. 2018.06.23 18:37:58 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:37:58 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:37:59 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:37:59 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:37:59 - Above log line repeated 1 times more
! 2018.06.23 18:37:59 - Disconnecting
. 2018.06.23 18:37:59 - Connection terminated.
. 2018.06.23 18:37:59 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:37:59 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:37:59 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:37:59 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:37:59 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:37:59 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:38:02 - Checking authorization ...
! 2018.06.23 18:38:03 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2018.06.23 18:38:03 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:38:03 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:38:04 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:38:04 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:38:04 - Above log line repeated 1 times more
! 2018.06.23 18:38:04 - Disconnecting
. 2018.06.23 18:38:04 - Connection terminated.
I 2018.06.23 18:38:07 - Checking authorization ...
. 2018.06.23 18:38:08 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:38:09 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:38:09 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:38:09 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:38:09 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:38:09 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:38:09 - Connecting to Mintaka (Canada, Toronto, Ontario)
. 2018.06.23 18:38:09 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:38:09 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:38:09 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:38:09 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:38:09 - Above log line repeated 1 times more
! 2018.06.23 18:38:09 - Disconnecting
. 2018.06.23 18:38:09 - Connection terminated.
. 2018.06.23 18:38:10 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:38:10 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:38:10 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:38:10 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:38:10 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:38:10 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:38:11 - Cancel requested.
! 2018.06.23 18:38:11 - Session terminated.
I 2018.06.23 18:45:34 - Session starting.
I 2018.06.23 18:45:34 - Checking authorization ...
. 2018.06.23 18:45:35 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:45:35 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:45:35 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:45:35 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:45:35 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:45:36 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:45:36 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2018.06.23 18:45:36 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:45:36 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:45:36 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:45:36 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:45:36 - Above log line repeated 1 times more
! 2018.06.23 18:45:36 - Disconnecting
. 2018.06.23 18:45:36 - Connection terminated.
. 2018.06.23 18:45:36 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:45:37 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:45:37 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:45:37 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:45:37 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:45:37 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:45:40 - Checking authorization ...
. 2018.06.23 18:45:41 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:45:41 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:45:41 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:45:42 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:45:42 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:45:42 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:45:42 - Connecting to Sargas (Canada, Toronto, Ontario)
. 2018.06.23 18:45:42 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:45:42 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:45:42 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:45:42 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:45:42 - Above log line repeated 1 times more
! 2018.06.23 18:45:42 - Disconnecting
. 2018.06.23 18:45:42 - Connection terminated.
. 2018.06.23 18:45:42 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:45:42 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:45:43 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:45:43 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:45:43 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:45:43 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:45:44 - Cancel requested.
! 2018.06.23 18:45:44 - Session terminated.
. 2018.06.23 18:47:37 - Updating systems & servers data ...
. 2018.06.23 18:47:39 - Systems & servers data update completed
I 2018.06.23 18:47:44 - Session starting.
I 2018.06.23 18:47:44 - Checking authorization ...
! 2018.06.23 18:47:45 - Connecting to Aludra (Canada, Toronto, Ontario)
. 2018.06.23 18:47:45 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:47:45 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:47:45 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:47:45 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:47:46 - Above log line repeated 1 times more
! 2018.06.23 18:47:46 - Disconnecting
. 2018.06.23 18:47:46 - Connection terminated.
I 2018.06.23 18:47:49 - Checking authorization ...
. 2018.06.23 18:47:50 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.06.23 18:47:50 - IPv6 disabled on network adapter (Ethernet)
. 2018.06.23 18:47:50 - IPv6 disabled on network adapter (FireWire)
. 2018.06.23 18:47:50 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.06.23 18:47:51 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.06.23 18:47:51 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.06.23 18:47:51 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2018.06.23 18:47:51 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
. 2018.06.23 18:47:51 - OpenVPN >   Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2018.06.23 18:47:51 - OpenVPN >   Reason: no suitable image found.  Did find:
. 2018.06.23 18:47:51 - OpenVPN >     /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2018.06.23 18:47:51 - Above log line repeated 1 times more
! 2018.06.23 18:47:51 - Disconnecting
. 2018.06.23 18:47:51 - Connection terminated.
. 2018.06.23 18:47:51 - IPv6 restored on network adapter (Bluetooth DUN)
. 2018.06.23 18:47:51 - IPv6 restored on network adapter (Ethernet)
. 2018.06.23 18:47:51 - IPv6 restored on network adapter (FireWire)
. 2018.06.23 18:47:51 - IPv6 restored on network adapter (Wi-Fi)
. 2018.06.23 18:47:51 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.06.23 18:47:51 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.06.23 18:47:53 - Cancel requested.
! 2018.06.23 18:47:53 - Session terminated.
#2 giganerd
giganerd
    I shall have no title
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 24 June 2018 - 10:18 PM
Obviously,  the LZO library is not loaded. As I'm not familar with macOS, I don't know exactly what to do, but try to reinstall Eddie and/or somehow install/update LZO version 2.2 and higher.
Always remember:
There's a guide to AirVPN,
Amazon IPs are not dangerous here,
running TOR exits is discouraged,
using spoilers for your logs helps us read your thread.
~ Furthermore, I propose that your paranoia is to be destroyed. ~
Instead of writing me a personal mail, consider contacting me via XMPP at gigan3rd@xmpp.airvpn.org or join the lounge@conference.xmpp.airvpn.org. I might read the mail too late whereas I'm always available on XMPP ;)
#3 36KkJAWRkjDYPbtGZoNarPg
  • Members
  • Pip
  • 3 posts
Posted 29 June 2018 - 09:36 PM
Thanks a lot. I reinstalled everything (complete new download of client). Didn't work though. Any other suggestions please? :)
Same problem:
. 2018.06.29 14:34:03 - OpenVPN > dyld: Library not loaded: @loader_path/liblzo2.2.dylib
What is it and how can i optimize that process?
#4 giganerd
giganerd
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 29 June 2018 - 09:57 PM
I did a bit of research and read myself into dyld a bit. It looks like there is a variable DYLD_LIBRARY_PATH which sounds VERY similar to a variable we have on Linux called LD_LIBRARY_PATH which can be set to point executables to different from standard directories with shared libraries such as LZO.
I'm thinking that setting this to the directory containing the lib might get it to work. You've got to find it first. Although it's strange, try doing something like this in a terminal when you've found it:
DYLD_LIBRARY_PATH=/path/to/the/lib command-to-launch-eddie.
Again, though macOS is Unix and therefore somewhat familiar with Linux I can still be completely wrong. Don't forget to do your own research here as well. :)
Sent via Tapatalk. Means, I don't have a computer available now.
Always remember:
#5 36KkJAWRkjDYPbtGZoNarPg
  • Members
  • Pip
  • 3 posts
Posted 29 June 2018 - 10:27 PM
Thanks a lot for your response! To be honest, i have no idea what you are talking about though -.-'
Sorry. This is way to high for my current understanding. But i actually found a library folder of Eddie which i deleted and completly downloaded + reinstalled Eddie afterwards again. Still doesn't change.
I'm sorry, the terminal stuff i don't understand.
#6 joxcox
joxcox
  • Members
  • Pip
  • 1 posts
Posted 07 July 2018 - 05:28 AM
I'm suddenly having the same baffling issue—worked fine earlier today. OSX 10.13.5
Here's the log showing the loop/shift to new server-disconnect-shift-disconnect.  I'm baffled.
. 2018.07.06 23:19:25 - Eddie version: 2.15.2 / macos_x64, System: MacOS, Name: 10.13.5, Version: Darwin MacBook-Pro-2.local 17.6.0 Darwin Kernel Version 17.6.0: Tue May  8 15:22:16 PDT 2018; root:xnu-4570.61.1~1/RELEASE_X86_64 x86_64, Mono/.Net: v4.0.30319
. 2018.07.06 23:19:25 - Reading options from /Users/bretloewen/.airvpn/default.xml
. 2018.07.06 23:19:26 - Command line arguments (1): psn_0_708781="True"
. 2018.07.06 23:19:26 - Profile path: /Users/bretloewen/.airvpn/default.xml
. 2018.07.06 23:19:28 - OpenVPN Driver - Expected
. 2018.07.06 23:19:28 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2018.07.06 23:19:28 - SSH - Version: OpenSSH_7.6p1, LibreSSL 2.6.2 (/usr/bin/ssh)
. 2018.07.06 23:19:28 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2018.07.06 23:19:28 - curl - Version: 7.54.0 (/usr/bin/curl)
. 2018.07.06 23:19:28 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem
! 2018.07.06 23:19:28 - Logged out.
I 2018.07.06 23:19:28 - Checking login ...
! 2018.07.06 23:19:29 - Logged in.
! 2018.07.06 23:19:29 - Activation of Network Lock - macOS - PF
. 2018.07.06 23:19:29 - macOS - PF rules updated, reloading
. 2018.07.06 23:19:29 - Updating systems & servers data ...
. 2018.07.06 23:19:30 - macOS - PF rules updated, reloading
I 2018.07.06 23:19:30 - Session starting.
. 2018.07.06 23:19:32 - macOS - PF rules updated, reloading
. 2018.07.06 23:19:33 - Systems & servers data update completed
I 2018.07.06 23:19:35 - Checking authorization ...
. 2018.07.06 23:19:36 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.07.06 23:19:37 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.07.06 23:19:37 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.07.06 23:19:37 - Connecting to Chort (Canada, Toronto, Ontario)
. 2018.07.06 23:19:37 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Apr 27 2018
. 2018.07.06 23:19:37 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.06 23:19:37 - Auto retry with another port.
. 2018.07.06 23:19:37 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3100: Address already in use (errno=48)
. 2018.07.06 23:19:37 - OpenVPN > Exiting due to fatal error
! 2018.07.06 23:19:37 - Disconnecting
. 2018.07.06 23:19:37 - Connection terminated.
. 2018.07.06 23:19:37 - IPv6 restored on network adapter (Wi-Fi)
. 2018.07.06 23:19:37 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.07.06 23:19:37 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2018.07.06 23:19:37 - Checking authorization ...
. 2018.07.06 23:19:38 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.07.06 23:19:38 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.07.06 23:19:38 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.07.06 23:19:38 - Connecting to Chort (Canada, Toronto, Ontario)
. 2018.07.06 23:19:39 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Apr 27 2018
. 2018.07.06 23:19:39 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.06 23:19:39 - Connection to OpenVPN Management Interface
. 2018.07.06 23:19:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2018.07.06 23:19:39 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.06 23:19:39 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.06 23:19:39 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.234:443
. 2018.07.06 23:19:39 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2018.07.06 23:19:39 - OpenVPN > UDP link local: (not bound)
. 2018.07.06 23:19:39 - OpenVPN > UDP link remote: [AF_INET]104.254.90.234:443
. 2018.07.06 23:19:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101
. 2018.07.06 23:19:39 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.234:443, sid=a9d1520f 901e46a0
. 2018.07.06 23:19:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.06 23:19:39 - OpenVPN > VERIFY KU OK
. 2018.07.06 23:19:39 - OpenVPN > Validating certificate extended key usage
. 2018.07.06 23:19:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.06 23:19:39 - OpenVPN > VERIFY EKU OK
. 2018.07.06 23:19:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.06 23:19:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.06 23:19:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.234:443
. 2018.07.06 23:19:41 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.06 23:19:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.11.196 255.255.0.0,peer-id 12,cipher AES-256-GCM'
. 2018.07.06 23:19:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.07.06 23:19:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.06 23:19:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.06 23:19:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.06 23:19:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.06 23:19:41 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=en0 HWADDR=98:01:a7:ac:b8:0f
. 2018.07.06 23:19:41 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2018.07.06 23:19:41 - Above log line repeated 2 times more
. 2018.07.06 23:19:41 - OpenVPN > Opened utun device utun3
. 2018.07.06 23:19:41 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2018.07.06 23:19:41 - OpenVPN > /sbin/ifconfig utun3 delete
. 2018.07.06 23:19:41 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2018.07.06 23:19:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2018.07.06 23:19:41 - OpenVPN > /sbin/ifconfig utun3 10.4.11.196 10.4.11.196 netmask 255.255.0.0 mtu 1500 up
. 2018.07.06 23:19:41 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.11.196 255.255.0.0
. 2018.07.06 23:19:41 - OpenVPN > route: writing to routing socket: File exists
. 2018.07.06 23:19:41 - OpenVPN > add net 10.4.0.0: gateway 10.4.11.196: File exists
. 2018.07.06 23:19:41 - OpenVPN > /sbin/route add -net 104.254.90.234 192.168.0.1 255.255.255.255
. 2018.07.06 23:19:41 - OpenVPN > add net 104.254.90.234: gateway 192.168.0.1
. 2018.07.06 23:19:41 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:19:41 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1: File exists
. 2018.07.06 23:19:41 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:19:41 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1: File exists
. 2018.07.06 23:19:41 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2018.07.06 23:19:41 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2018.07.06 23:19:41 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2018.07.06 23:19:41 - Routes, added a new route, 104.254.90.235 for gateway 10.4.0.1
. 2018.07.06 23:19:41 - Flushing DNS
. 2018.07.06 23:19:42 - macOS - PF rules updated, reloading
I 2018.07.06 23:19:42 - Checking route IPv4
. 2018.07.06 23:20:02 - curl: (28) Connection timed out after 20006 milliseconds
. 2018.07.06 23:20:02 - Checking route (2° try)
. 2018.07.06 23:20:23 - curl: (28) Connection timed out after 20002 milliseconds
. 2018.07.06 23:20:23 - Checking route (3° try)
. 2018.07.06 23:20:45 - curl: (28) Connection timed out after 20002 milliseconds
E 2018.07.06 23:20:45 - Checking route IPv4 failed.
. 2018.07.06 23:20:45 - OpenVPN > Initialization Sequence Completed
! 2018.07.06 23:20:45 - Disconnecting
. 2018.07.06 23:20:45 - Routes, removed a route previously added, 104.254.90.235 for gateway 10.4.0.1
. 2018.07.06 23:20:45 - Sending management termination signal
. 2018.07.06 23:20:45 - Management - Send 'signal SIGTERM'
. 2018.07.06 23:20:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.06 23:20:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.07.06 23:20:50 - OpenVPN > /sbin/route delete -net 104.254.90.234 192.168.0.1 255.255.255.255
. 2018.07.06 23:20:50 - OpenVPN > delete net 104.254.90.234: gateway 192.168.0.1
. 2018.07.06 23:20:50 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:20:50 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2018.07.06 23:20:50 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:20:50 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2018.07.06 23:20:50 - OpenVPN > Closing TUN/TAP interface
. 2018.07.06 23:20:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.07.06 23:20:50 - Connection terminated.
. 2018.07.06 23:20:50 - IPv6 restored on network adapter (Wi-Fi)
. 2018.07.06 23:20:50 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.07.06 23:20:50 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2018.07.06 23:20:50 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2018.07.06 23:20:50 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2018.07.06 23:20:50 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
I 2018.07.06 23:20:53 - Checking authorization ...
. 2018.07.06 23:20:54 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.07.06 23:20:54 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2018.07.06 23:20:55 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2018.07.06 23:20:55 - Connecting to Dheneb (Canada, Toronto, Ontario)
. 2018.07.06 23:20:55 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Apr 27 2018
. 2018.07.06 23:20:55 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.06 23:20:55 - Connection to OpenVPN Management Interface
. 2018.07.06 23:20:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2018.07.06 23:20:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.06 23:20:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.06 23:20:55 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.21.149.44:443
. 2018.07.06 23:20:55 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2018.07.06 23:20:55 - OpenVPN > UDP link local: (not bound)
. 2018.07.06 23:20:55 - OpenVPN > UDP link remote: [AF_INET]199.21.149.44:443
. 2018.07.06 23:20:55 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101
. 2018.07.06 23:20:55 - OpenVPN > TLS: Initial packet from [AF_INET]199.21.149.44:443, sid=f23f691c 6d01fe51
. 2018.07.06 23:20:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.06 23:20:55 - OpenVPN > VERIFY KU OK
. 2018.07.06 23:20:55 - OpenVPN > Validating certificate extended key usage
. 2018.07.06 23:20:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.06 23:20:55 - OpenVPN > VERIFY EKU OK
. 2018.07.06 23:20:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.06 23:20:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.06 23:20:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.21.149.44:443
. 2018.07.06 23:20:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.06 23:20:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.5.142 255.255.0.0,peer-id 47,cipher AES-256-GCM'
. 2018.07.06 23:20:56 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.07.06 23:20:56 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.06 23:20:56 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.06 23:20:56 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.06 23:20:56 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.06 23:20:56 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=en0 HWADDR=98:01:a7:ac:b8:0f
. 2018.07.06 23:20:56 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2018.07.06 23:20:56 - Above log line repeated 2 times more
. 2018.07.06 23:20:56 - OpenVPN > Opened utun device utun3
. 2018.07.06 23:20:56 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2018.07.06 23:20:56 - OpenVPN > /sbin/ifconfig utun3 delete
. 2018.07.06 23:20:56 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2018.07.06 23:20:56 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2018.07.06 23:20:56 - OpenVPN > /sbin/ifconfig utun3 10.4.5.142 10.4.5.142 netmask 255.255.0.0 mtu 1500 up
. 2018.07.06 23:20:56 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.5.142 255.255.0.0
. 2018.07.06 23:20:57 - OpenVPN > route: writing to routing socket: File exists
. 2018.07.06 23:20:57 - OpenVPN > add net 10.4.0.0: gateway 10.4.5.142: File exists
. 2018.07.06 23:20:57 - OpenVPN > /sbin/route add -net 199.21.149.44 192.168.0.1 255.255.255.255
. 2018.07.06 23:20:57 - OpenVPN > add net 199.21.149.44: gateway 192.168.0.1
. 2018.07.06 23:20:57 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:20:57 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2018.07.06 23:20:57 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:20:57 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2018.07.06 23:20:57 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2018.07.06 23:20:57 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2018.07.06 23:20:57 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2018.07.06 23:20:57 - Routes, added a new route, 199.21.149.49 for gateway 10.4.0.1
. 2018.07.06 23:20:57 - Flushing DNS
I 2018.07.06 23:20:57 - Checking route IPv4
. 2018.07.06 23:21:17 - curl: (28) Connection timed out after 20000 milliseconds
. 2018.07.06 23:21:17 - Checking route (2° try)
. 2018.07.06 23:21:38 - curl: (28) Connection timed out after 20000 milliseconds
. 2018.07.06 23:21:38 - Checking route (3° try)
. 2018.07.06 23:22:01 - curl: (28) Connection timed out after 20003 milliseconds
E 2018.07.06 23:22:01 - Checking route IPv4 failed.
. 2018.07.06 23:22:01 - OpenVPN > Initialization Sequence Completed
! 2018.07.06 23:22:01 - Disconnecting
. 2018.07.06 23:22:01 - Routes, removed a route previously added, 199.21.149.49 for gateway 10.4.0.1
. 2018.07.06 23:22:01 - Sending management termination signal
. 2018.07.06 23:22:01 - Management - Send 'signal SIGTERM'
. 2018.07.06 23:22:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.06 23:22:02 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.07.06 23:22:07 - OpenVPN > /sbin/route delete -net 199.21.149.44 192.168.0.1 255.255.255.255
. 2018.07.06 23:22:07 - OpenVPN > delete net 199.21.149.44: gateway 192.168.0.1
. 2018.07.06 23:22:07 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:22:07 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2018.07.06 23:22:07 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2018.07.06 23:22:07 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2018.07.06 23:22:07 - OpenVPN > Closing TUN/TAP interface
. 2018.07.06 23:22:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.07.06 23:22:07 - Connection terminated.
. 2018.07.06 23:22:07 - IPv6 restored on network adapter (Wi-Fi)
. 2018.07.06 23:22:07 - IPv6 restored on network adapter (Bluetooth PAN)
. 2018.07.06 23:22:07 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2018.07.06 23:22:07 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2018.07.06 23:22:08 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2018.07.06 23:22:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
I 2018.07.06 23:22:11 - Checking authorization ...
! 2018.07.06 23:22:11 - Connecting to Enif (Canada, Toronto, Ontario)
. 2018.07.06 23:22:12 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Apr 27 2018
. 2018.07.06 23:22:12 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.06 23:22:12 - Connection to OpenVPN Management Interface
. 2018.07.06 23:22:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2018.07.06 23:22:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.06 23:22:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.06 23:22:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.242:443
. 2018.07.06 23:22:12 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2018.07.06 23:22:12 - OpenVPN > UDP link local: (not bound)
. 2018.07.06 23:22:12 - OpenVPN > UDP link remote: [AF_INET]104.254.90.242:443
. 2018.07.06 23:22:12 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101
. 2018.07.06 23:22:12 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.242:443, sid=0954172c 171dadde
. 2018.07.06 23:22:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.06 23:22:12 - OpenVPN > VERIFY KU OK
. 2018.07.06 23:22:12 - OpenVPN > Validating certificate extended key usage
. 2018.07.06 23:22:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.06 23:22:13 - OpenVPN > VERIFY EKU OK
. 2018.07.06 23:22:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.06 23:22:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.06 23:22:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.242:443
. 2018.07.06 23:22:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.06 23:22:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.88.1,dhcp-option DNS6 fde6:7a:7d20:c58::1,tun-ipv6,route-gateway 10.16.88.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:c58::107c/64 fde6:7a:7d20:c58::1,ifconfig 10.16.88.126 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2018.07.06 23:22:13 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.07.06 23:22:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.06 23:22:13 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.06 23:22:13 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.06 23:22:13 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.06 23:22:13 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=en0 HWADDR=98:01:a7:ac:b8:0f
. 2018.07.06 23:22:13 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.06 23:22:13 - OpenVPN > GDG6: problem writing to routing socket
. 2018.07.06 23:22:13 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.06 23:22:13 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16)
. 2018.07.06 23:22:13 - Above log line repeated 2 times more
. 2018.07.06 23:22:13 - OpenVPN > Opened utun device utun3
. 2018.07.06 23:22:13 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.06 23:22:13 - OpenVPN > /sbin/ifconfig utun3 delete
. 2018.07.06 23:22:13 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2018.07.06 23:22:13 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2018.07.06 23:22:13 - OpenVPN > /sbin/ifconfig utun3 10.16.88.126 10.16.88.126 netmask 255.255.255.0 mtu 1500 up
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -net 10.16.88.0 10.16.88.126 255.255.255.0
. 2018.07.06 23:22:13 - OpenVPN > add net 10.16.88.0: gateway 10.16.88.126
. 2018.07.06 23:22:13 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:c58::107c/64
. 2018.07.06 23:22:13 - OpenVPN > add_route_ipv6(fde6:7a:7d20:c58::/64 -> fde6:7a:7d20:c58::107c metric 0) dev utun3
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:c58:: -prefixlen 64 -iface utun3
. 2018.07.06 23:22:13 - OpenVPN > route: writing to routing socket: File exists
. 2018.07.06 23:22:13 - OpenVPN > add net fde6:7a:7d20:c58::: gateway utun3: File exists
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -net 104.254.90.242 192.168.0.1 255.255.255.255
. 2018.07.06 23:22:13 - OpenVPN > add net 104.254.90.242: gateway 192.168.0.1
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -net 0.0.0.0 10.16.88.1 128.0.0.0
. 2018.07.06 23:22:13 - OpenVPN > add net 0.0.0.0: gateway 10.16.88.1
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -net 128.0.0.0 10.16.88.1 128.0.0.0
. 2018.07.06 23:22:13 - OpenVPN > add net 128.0.0.0: gateway 10.16.88.1
. 2018.07.06 23:22:13 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:c58::1 metric -1) dev utun3
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun3
. 2018.07.06 23:22:13 - OpenVPN > add net ::: gateway utun3
. 2018.07.06 23:22:13 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:c58::1 metric -1) dev utun3
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun3
. 2018.07.06 23:22:13 - OpenVPN > add net 2000::: gateway utun3
. 2018.07.06 23:22:13 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:c58::1 metric -1) dev utun3
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun3
. 2018.07.06 23:22:13 - OpenVPN > add net 3000::: gateway utun3
. 2018.07.06 23:22:13 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:c58::1 metric -1) dev utun3
. 2018.07.06 23:22:13 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun3
. 2018.07.06 23:22:13 - OpenVPN > add net fc00::: gateway utun3
. 2018.07.06 23:22:14 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.16.88.1, fde6:7a:7d20:c58::1)
. 2018.07.06 23:22:14 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.16.88.1, fde6:7a:7d20:c58::1)
. 2018.07.06 23:22:14 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.16.88.1, fde6:7a:7d20:c58::1)
. 2018.07.06 23:22:14 - Routes, added a new route, 104.254.90.243 for gateway 10.16.88.1
. 2018.07.06 23:22:14 - Routes, added a new route, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c58::1
. 2018.07.06 23:22:14 - Flushing DNS
I 2018.07.06 23:22:14 - Checking route IPv4
. 2018.07.06 23:22:34 - curl: (28) Connection timed out after 20004 milliseconds
. 2018.07.06 23:22:34 - Checking route (2° try)
. 2018.07.06 23:22:55 - curl: (28) Connection timed out after 20001 milliseconds
. 2018.07.06 23:22:55 - Checking route (3° try)
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 14003 - BW: 49354 Mbit/sYour IP: 54.197.24.206Guest Access.
