iwih2gk 92 Posted ... First let me say that 2.15.2 is the best stable client yet on Debian! I have not benchmarked this question. I wonder if by selecting the protocol to employ both tls-crypt and SSL together I am incurring large speed hits? Primarily, I am way more interested in security/privacy than speed by a long shot. In the past I selected SSL because on occasion my ISP would throttle me sometimes without it. I should probably run straight tls-crypt without SSL and see if I get throttled. I reside close to many Air Servers that currently support the new tls-crypt protocols. Rambling sorry. How much speed degradation should a user expect via tls-crypt as the sole control parameter? Quote Share this post Link to post
go558a83nk 352 Posted ... tls-crypt itself shouldn't give any speed degradation. The reason SSL has a speed degradation is because it necessitates TCP. Try using tls-crypt with on a UDP port to see how it works for you. Quote Share this post Link to post
iwih2gk 92 Posted ... Thanks for the suggestion. I have a note to change the protocol when I exit this VM and get back to the host. I remember reading that "maybe" tls-crypt will help with throttling issues. My ISP isn't terrible about straight 443/80 connections, but sometimes, its irregular. If using tls-crypt without other wrappers works I'll likely pick up another 20 meg. Don't get me wrong the whole tunnel is very fast. My raw line is over 200 and I have never seen below 50 on Air before TOR enters the picture. Most times I easily exceed 100 +. Quote Share this post Link to post
iwih2gk 92 Posted ... Quick follow up in case others are playing with the new client protocols. I am now using UDP - 443 3 and employing tls-crypt per the new client. NO blocks from my ISP (throttles) noted. My current speeds through the tunnel are now 215 meg average. I ran multiple tests through several different systems and averaged the outcome here. Nice!! My RAW ISP is slightly over 200 meg so this means almost zero load through the first hop on Air. Very cool. It is my hope that tls-crypt will continue to "evade" any ISP throttles. We'll see. Quote Share this post Link to post
serenacat 83 Posted ... I noticed this, but have not chased the details, was doing a bit of curious googling of "tls-crypt"."Dunno about China, but there are reports that tls-crypt doesn't work in Egypt. I'm unsure what method they're using for detection.They're doing a protocol agnostic packet sequence and size variation match with whitelists for big-business to reduce false-positives."https://www.reddit.com/r/VPN/comments/856zlp/how_effective_is_tlscrypt_at_bypassing_isp_vpn/so I guess the next step up would be to fuzz the initial protocol with random chatter packets.In places like Egypt, Turkey, etc using https:443 might be less likely to attract attention, but presumably also a problem with up to date database(s) of detected commercial VPN entry IP addresses when dealing with SS. Quote Share this post Link to post
Staff 9763 Posted ... @serenacat Here the reports we have: China: tls-crypt always works in TCP and only sometimes in UDP (due to the fact that in mobile lines UDP is blocked by itself, we presume). OpenVPN over SSL works. tls-crypt is faster. Iran. same as ChinaUAE: same as ChinaEgypt: OpenVPN over SSL works. No reports about tls-crypt so far, unfortunately.Saudi Arabia: same as Egypt Kind regards Quote Share this post Link to post
invisible25 0 Posted ... OpenVPN over SSL Больше не работает в Туркменистане, хотя работал SSH тоже перестал работать, уважаемые можно найти причину?Так как SSH и Stunnel работают у Windscribe и Torguard, Можно ли наладить работу SSL ? Quote Share this post Link to post
Staff 9763 Posted ... Hello! If Windscribe and Torguard work, then the block might be not against the protocols, but against our own IP addresses, we're sorry. Kind regards Quote Share this post Link to post
