Not connected, Your IP: 18.191.216.163
majoriscannis
How to fix constant restart loop
Was wondering if anyone knew how to fix the constant restart loop. I try to log on to a server and it redirects and then restarts for 3 secs then goes to another server and restarts. Any assistance would be appreciated.
What Operating system/platform are you using....if Windows 10 see below(links).
Got the same on Ubuntu 16.04.
It's actually for certain servers and not all of them, thankfully.
Something to do with ipv6 I guess because the loop is
Checking route ipv4 then immediately Checking route ipv6 and failing.
On other servers, it is NOT checking route ipv6 and seems to be fine with ipv4.
So cancel your connection attemp and try selecting another server in the list to see if it's the same.
Hope this help.
To be more precise, some servers are checking for ipv6 routes and others are not.
I just tried again, first on Chara (NL), which is checking route ipv6 after ipv4 and failing:
. 2018.07.07 10:19:28 - Unable to compute route for 2a00:1678:2470:14:8b1f:21a6:b646:bf3d: IPv6 VPN gateway not available.
. 2018.07.07 10:19:28 - Flushing DNS
I 2018.07.07 10:19:30 - Checking route IPv4
I 2018.07.07 10:19:30 - Checking route IPv6
. 2018.07.07 10:19:30 - curl: (7) Couldn't connect to server
. 2018.07.07 10:19:30 - Checking route (2° try)
. 2018.07.07 10:19:31 - curl: (7) Couldn't connect to server
. 2018.07.07 10:19:31 - Checking route (3° try)
. 2018.07.07 10:19:33 - curl: (7) Couldn't connect to server
E 2018.07.07 10:19:33 - Checking route IPv6 failed.
. 2018.07.07 10:19:33 - OpenVPN > Initialization Sequence Completed
! 2018.07.07 10:19:33 - Disconnecting
Then on Phaet (NL), which is not checking ipv6 after ipv4 and it's working.
Can you check the logs to see if you've got the same behaviour? And maybe try the Phaet server to see if it works.
If you do, maybe rename the topic to something like "checking route ipv6 not working".
