Not connected, Your IP: 18.117.196.184
1252
IP Leak incorrect location
When I check my IP (193.180.164.42) I get the location Greenwich UK, what is incorect. It should be Sweden. The same situation is with DNS, again UK instead of Sweden.
The IPv6 locations is correct both on IP and DNS. Any idea?
Which server are you connected to? Have you checked DNS servers on your system? Lately, ipleak seems to have had some issues - it's working fine for me, though. Have you checked other leaktests such as https://www.dnsleaktest.com/ or  https://www.grc.com/dns/dns.htm?
Hi Corrado,
In my case the IP and DNS servers identification for IPv6 is correct, IPv4 is also correct except the geographical locations of the servers.
I received a reply from airVPN staff who explained the problem. IPLeak.net is gathering data from an external database which can contain wrong data, as is in my case.
