56Kmodem 3 Posted ... Hello, if I go manually to /home/eddie and type in the shell: nohup ./eddie-cli --login=myname--password=mypassword--netlock --connect --server=myserver & I can start it without any problems. But I can not start it via a full path like: nohup /home/eddie/eddie-cli --login=myname--password=mypassword--netlock --connect --server=myserver & same thing goes for a shell or python script I always get the error: /home# exception inside UnhandledException handler: Object reference not set to an instance of an object [ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: Lib.Platform.Linux.Native.so at (wrapper managed-to-native) Eddie.Platform.Linux.Native:eddie_signal (int,Eddie.Platform.Linux.Native/eddie_sighandler) at Eddie.Platform.Linux.Platform.OnInit (System.Boolean cli) [0x0021a] in <fa5edc113cd34687a3a471dec3ba63b7>:0 at Eddie.Core.Engine.Initialization (System.Boolean cli) [0x00000] in <1e873ed653644897a51a4d68deac7371>:0 at Eddie.CLI.Linux.MainClass.Main (System.String[] args) [0x00030] in <0746b67a12534408be7db4eef2ec9960>:0 Any ideas? Quote Share this post Link to post
LZ1 662 Posted ... Hello! If it's happening with the experimental client then you can post about it in the experimental clients own thread in the announcement forum, so it'll get seen. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
greerd 5 Posted ... trynohup /home/eddie/./eddie-cli --login=myname--password=mypassword--netlock --connect --server=myserver & you forgot the ./ since /home/eddie isn't in the $PATH. Quote Share this post Link to post
corrado 100 Posted ... Are you using the portable version? You need to change the working directory in your shell/python script.... Quote Share this post Link to post
56Kmodem 3 Posted ... Thank you very much. I worked with python and told the path via os.chdir. After that I started it with os.system. Quote Share this post Link to post
corrado 100 Posted ... Glad, I could help! As you are using python I would suggest you use the subprocess module instead of os.system as it is more flexible and secure. With subprocess it is even easier to specify the working directory when using the Popen constructor - subprocess.Popen(args, cwd=$WORKINGDIRECTORY). Have a look at the documentation. 1 56Kmodem reacted to this Quote Share this post Link to post
