Not connected, Your IP: 3.141.31.240
I would like to use AirVPN on my Android device but am concerned about leaking. I have seen some posts on here about using AfWall+ and was wondering if this is the best way to go. Android now also natively has a kind of Network Lock feature. But then there is also the boot leak (discussed here, along with providing a userinit script for droidwall to disable network connectivity during boot and also a script to prevent Google portal capture during wifi connection: https://blog.torproject.org/mission-impossible-hardening-android-security-and-privacy).
My thinking is to use OpenVPN on the latest Lineage OS and would appreciate any assistance on the matter. Thank you.
