Not connected, Your IP: 44.204.99.5
seedyunder
Torrent Web UI not working when forwarded to different port
Ive been using airvpn for a while and have all my apps working well remotely.
Recently my uTorrent stopped being reachable remotley, I tried to change ports / settings but nothing seemed to work.
So I decided it was time to switch clients anyway and started using qBittorrent. But this has had the exact same problem.
It started driving me mad so decided to do a troubleshoot test:
I turned off my VPN and forward the webui port through my router and tried to connect remotley that way. It Worked.
So then I forwarded the webui port to a different port number and tried to connect remotely through that port. It Did NOT Work.
Just to make sure I tried the same method, different port number, with a another app (sabnzbd). It Worked.
So I dont think its fully a VPN problem.
Next I removed all router forwarding and re enabled my VPN.
In AirVPN i chose a new port number and forwarded it to be the same as local port and used that in qTorrent web ui. It Did NOT Work.
So Im at a loss. Any ideas?
Torrents download great on a separate port this is just for the remote web ui.
No UPNP or Router Port forwarding
Ports are all open when checked on AirVPN and Port Checkers.
Thanks )
So turned out the last attempt of using the same remote and local port worked.
Still not sure why I cant forward a remote port to a standard local port in either torrent client.
That's caused by how a torrent client works. It announces directly inside the packets the port you configure in it. More details in the answers to the FAQ:
https://airvpn.org/topic/9170-do-you-allow-p2p-how-can-i-optimize-performance-of-emule-and-bittorrent-with-airvpn/
