Not connected, Your IP: 3.131.13.194
Hello.
Port forwarding isn't working for me at all. I already submitted a help desk ticket but have not received an answer.
What am I doing wrong? Do I need to change my firewall settings locally?
-I'm on Windows 10. I assigned ports in 3 different ways: one manually, one selected by the system and one selected from the graph.
-Eddie is set to lock the network.
-Both the AirVPN tester and CanYouSeeMe report that the ports are not forwarded.
-I am connected to Iskandar.
Hello.
is your server running and listening on the ports you've forwarded?
You need to run some sort of server or software that is listening to that port. For example, torrent software listening to your designated port. If it still doesn't work, try deleting the ports on airvpn and try a new one.
Indeed, I do have software that is listening to the port.
It is still reported as not open.
Edit: It appears to be working fine now. Thank you all for the help. I will mark this issue as solved.
