Not connected, Your IP: 216.73.216.36
Uninstalled Air VPN anyway tap windows thing it installed, now my Internet doesn't work. Every time I restart I get notifications from Eddie and the task bar icon is still there wtf. I've uninstalled network adapter, restarted pc loads, dns is all auto in ip4. I have no Internet? Help please?
What platform is this on, exactly? If it didn't work uninstalling Eddie the regular way, maybe you can try a program like Ccleaner.
I assume you used Network Lock when running Eddie. Which is the only way I can see that your connection is still off, after resetting DNS. So please try resetting your firewall rules too.
If you use Eddie again, it's important to shut it down through its own menus, so that it can restore settings properly .
