Not connected, Your IP: 3.14.133.148
Hi all,
im getting network unreachable on my dd-wrt
I don;t know what im doing wrong, but i did follow everything from here :https://airvpn.org/ddwrt/
I added the screenshots and the error code.
lets hope some1 can help me
regards
20180310 22:05:00 I TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.180:1194
20180310 22:05:00 Socket Buffers: R=[172032->172032] S=[172032->172032]
20180310 22:05:00 I UDPv4 link local: (not bound)
20180310 22:05:00 I UDPv4 link remote: [AF_INET]213.152.161.180:1194
20180310 22:05:00 N write UDPv4: Network unreachable (code=128)
20180310 22:05:00 I Network unreachable restarting
20180310 22:05:00 I SIGUSR1[soft network-unreachable] received process restarting
20180310 22:05:00 Restart pause 300 second(s)
20180310 22:10:00 W WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
20180310 22:10:00 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20180310 22:10:00 I TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.180:1194
20180310 22:10:00 Socket Buffers: R=[172032->172032] S=[172032->172032]
20180310 22:10:00 I UDPv4 link local: (not bound)
20180310 22:10:00 I UDPv4 link remote: [AF_INET]213.152.161.180:1194
20180310 22:10:00 N write UDPv4: Network unreachable (code=128)
20180310 22:10:00 I Network unreachable restarting
20180310 22:10:00 I SIGUSR1[soft network-unreachable] received process restarting
20180310 22:10:00 Restart pause 300 second(s)
20180310 22:12:00 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20180310 22:12:00 D MANAGEMENT: CMD 'state'
20180310 22:12:00 MANAGEMENT: Client disconnected
20180310 22:12:00 D MANAGEMENT: CMD 'status 2'
20180310 22:12:00 D MANAGEMENT: CMD 'log 500'
19700101 01:00:00
Change your port to 443
i did no that not working aswell... what can cause the problem?
also when i check ifconfig i don't see tun in the list....
ok i got it working now.
there is 1 thing whats not working.
when i connect my laptop to this router it hides my ip
but when i connect my phone or something else i see my ip and its not hidden..
did i do anything wrong ?
Hi! Try adding remote-cert-tls server to OpenVPN "Additional Config" box and remove "nsCertType verification" check box above TLS Auth key. Edit: I just read your last comment, sorry. Good you got it working.
Your phone probably overrides your router's DNS server IP-addresses. I use these in DD-WRT Firewall settings at Administartion page:
iptables -t nat -A PREROUTING -i br0 -p udp --dport 53 -j DNAT --to $(nvram get lan_ipaddr)
iptables -t nat -A PREROUTING -i br0 -p tcp --dport 53 -j DNAT --to $(nvram get lan_ipaddr)
Edit. It forces LAN devices to make DNS queries to your router IP address thus DNS servers are what your router uses.
