Not connected, Your IP: 3.133.159.224
Lightn1ng
ANSWERED Connect loop on Linux using NetworkManager
I am running Gentoo Linux ~amd64 and installed the Eddie dependencies and downloaded the portable version. When I log in and connect, it connects for 1 second, then instantly disconnects and tries a different server. This goes on until I close the program. There is nothing weird in Eddie's log:
lightn1ng@gentooi5 ~/Downloads/eddie-ui_2.13.6_linux_x64_portable $ sudo ./airvpn
I 2018.03.02 18:38:40 - Eddie version: 2.13.6 / linux_x64, System: Linux, Name: This is \n.\O (\s \m \r) \t, Version: Linux gentooi5 4.15.7-gentoo-r1-lightn1ng #1 SMP Fri Mar 2 17:39:57 EST 2018 x86_64 Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz GenuineIntel GNU/Linux, Mono/.Net Framework: v4.0.30319
. 2018.03.02 18:38:40 - Reading options from /home/lightn1ng/Downloads/eddie-ui_2.13.6_linux_x64_portable/AirVPN.xml
. 2018.03.02 18:38:40 - Command line arguments (0):
I 2018.03.02 18:38:41 - OpenVPN Driver - Found, /dev/net/tun
I 2018.03.02 18:38:41 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (/home/lightn1ng/Downloads/eddie-ui_2.13.6_linux_x64_portable/openvpn)
I 2018.03.02 18:38:41 - SSH - Version: OpenSSH_7.6p1lpk, OpenSSL 1.0.2n  7 Dec 2017 (/usr/bin/ssh)
I 2018.03.02 18:38:41 - SSL - Version: stunnel 5.40 (/home/lightn1ng/Downloads/eddie-ui_2.13.6_linux_x64_portable/stunnel)
I 2018.03.02 18:38:41 - curl - Version: 7.58.0 (/usr/bin/curl)
I 2018.03.02 18:38:41 - Certification Authorities: /home/lightn1ng/Downloads/eddie-ui_2.13.6_linux_x64_portable/cacert.pem
. 2018.03.02 18:38:41 - Updating systems & servers data ...
! 2018.03.02 18:38:42 - Ready
. 2018.03.02 18:38:42 - Systems & servers data update completed
I 2018.03.02 18:38:47 - Session starting.
I 2018.03.02 18:38:47 - Checking authorization ...
! 2018.03.02 18:38:48 - Connecting to Saiph (Canada, Toronto, Ontario)
. 2018.03.02 18:38:48 - OpenVPN > OpenVPN 2.4.3 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Aug  9 2017
. 2018.03.02 18:38:48 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.03.02 18:38:48 - Connection to OpenVPN Management Interface
. 2018.03.02 18:38:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.03.02 18:38:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.03.02 18:38:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.03.02 18:38:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.226:443
. 2018.03.02 18:38:48 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2018.03.02 18:38:48 - OpenVPN > UDP link local: (not bound)
. 2018.03.02 18:38:48 - OpenVPN > UDP link remote: [AF_INET]184.75.223.226:443
. 2018.03.02 18:38:48 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.226:443, sid=bfd61bf7 a90cf4d8
. 2018.03.02 18:38:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.03.02 18:38:48 - OpenVPN > VERIFY KU OK
. 2018.03.02 18:38:48 - OpenVPN > Validating certificate extended key usage
. 2018.03.02 18:38:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.03.02 18:38:48 - OpenVPN > VERIFY EKU OK
. 2018.03.02 18:38:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.03.02 18:38:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.03.02 18:38:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.03.02 18:38:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.226:443
! 2018.03.02 18:38:49 - Disconnecting
. 2018.03.02 18:38:49 - Connection terminated.
I 2018.03.02 18:38:51 - Cancel requested.
! 2018.03.02 18:38:51 - Session terminated.
Can somebody please assist?
Thanks in advance
-Lightn1ng
I experimented a bit more and found a line
. 2018.03.02 18:49:14 - OpenVPN > Linux ip link set failed: could not execute external program
this might be of use
Please check here.
It may also be beneficial to use the experimental client while you're there.
Please check here.
Holy cow, thank you!
It looks like Gentoo Linux puts the file in /bin rather than /sbin. Creating a symbolic link with:
sudo ln -sv /bin/ip /sbin/ip
fixed it instantly.
Thanks!
Welcome to AirVPN
Enjoy.
