lw1975 0 Posted ... Hi I've just installed Airvpn with Tunnelblick on my Mac and although I connect fine, I completely lose internet connection - or rather, the internet simply hangs. What am I doing wrong? Thanks! Quote Share this post Link to post
Staff 9761 Posted ... HiI've just installed Airvpn with Tunnelblick on my Mac and although I connect fine, I completely lose internet connection - or rather, the internet simply hangs.What am I doing wrong?Thanks!Hello!Can you please send us Tunnelblick logs?Kind regards Quote Share this post Link to post
magnum1 0 Posted ... I'm having exactly the same problem - here is my log - can someone help?? 2013-03-23 14:01:49 *Tunnelblick: OS X 10.8.3; Tunnelblick 3.2.8 (build 2891.3099) 2013-03-23 14:01:49 *Tunnelblick: Attempting connection with UK Tunnelblick VPN Configuration; Set nameserver = 1; monitoring connection 2013-03-23 14:01:49 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start UK\ Tunnelblick\ VPN\ Configuration.tblk 1337 1 0 0 0 49 -atDASNGWrdasngw 2013-03-23 14:01:49 *Tunnelblick: Established communication with OpenVPN 2013-03-23 14:01:49 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012 2013-03-23 14:01:49 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337 2013-03-23 14:01:49 Need hold release from management interface, waiting... 2013-03-23 14:01:49 MANAGEMENT: Client connected from 127.0.0.1:1337 2013-03-23 14:01:49 MANAGEMENT: CMD 'pid' 2013-03-23 14:01:49 MANAGEMENT: CMD 'state on' 2013-03-23 14:01:49 MANAGEMENT: CMD 'state' 2013-03-23 14:01:49 MANAGEMENT: CMD 'hold release' 2013-03-23 14:01:49 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2013-03-23 14:01:49 LZO compression initialized 2013-03-23 14:01:49 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 2013-03-23 14:01:49 Socket Buffers: R=[196724->65536] S=[9216->65536] 2013-03-23 14:01:49 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 2013-03-23 14:01:49 Local Options hash (VER=V4): '22188c5b' 2013-03-23 14:01:49 Expected Remote Options hash (VER=V4): 'a8f55717' 2013-03-23 14:01:49 UDPv4 link local: [undef] 2013-03-23 14:01:49 UDPv4 link remote: 31.193.12.74:443 2013-03-23 14:01:49 MANAGEMENT: >STATE:1364047309,WAIT,,, 2013-03-23 14:01:49 MANAGEMENT: >STATE:1364047309,AUTH,,, 2013-03-23 14:01:49 TLS: Initial packet from 31.193.12.74:443, sid=f44b40b0 6ae98ffb 2013-03-23 14:01:49 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 2013-03-23 14:01:49 VERIFY OK: nsCertType=SERVER 2013-03-23 14:01:49 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 2013-03-23 14:01:49 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/user/Library/Application Support/Tunnelblick/Configurations/UK Tunnelblick VPN Configuration.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Users/user/Library/Application Support/Tunnelblick/Configurations/UK Tunnelblick VPN Configuration.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Suser-SLibrary-SApplication Support-STunnelblick-SConfigurations-SUK Tunnelblick VPN Configuration.tblk-SContents-SResources-Sconfig.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart 2013-03-23 14:01:50 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-03-23 14:01:50 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-03-23 14:01:50 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-03-23 14:01:50 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-03-23 14:01:50 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2013-03-23 14:01:50 [server] Peer Connection Initiated with 31.193.12.74:443 2013-03-23 14:01:52 MANAGEMENT: >STATE:1364047312,GET_CONFIG,,, 2013-03-23 14:01:53 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-03-23 14:01:53 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.41.190 10.4.41.189' 2013-03-23 14:01:53 OPTIONS IMPORT: timers and/or timeouts modified 2013-03-23 14:01:53 OPTIONS IMPORT: LZO parms modified 2013-03-23 14:01:53 OPTIONS IMPORT: --ifconfig/up options modified 2013-03-23 14:01:53 OPTIONS IMPORT: route options modified 2013-03-23 14:01:53 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2013-03-23 14:01:53 ROUTE default_gateway=192.168.1.254 2013-03-23 14:01:53 TUN/TAP device /dev/tun0 opened 2013-03-23 14:01:53 MANAGEMENT: >STATE:1364047313,ASSIGN_IP,,10.4.41.190, 2013-03-23 14:01:53 /sbin/ifconfig tun0 delete ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address 2013-03-23 14:01:53 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure 2013-03-23 14:01:53 /sbin/ifconfig tun0 10.4.41.190 10.4.41.189 mtu 1500 netmask 255.255.255.255 up 2013-03-23 14:01:53 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.41.190 10.4.41.189 init No such key 2013-03-23 14:01:55 *Tunnelblick: Flushed the DNS cache 2013-03-23 14:01:55 /sbin/route add -net 31.193.12.74 192.168.1.254 255.255.255.255 add net 31.193.12.74: gateway 192.168.1.254 2013-03-23 14:01:55 /sbin/route add -net 0.0.0.0 10.4.41.189 128.0.0.0 add net 0.0.0.0: gateway 10.4.41.189 2013-03-23 14:01:55 /sbin/route add -net 128.0.0.0 10.4.41.189 128.0.0.0 add net 128.0.0.0: gateway 10.4.41.189 2013-03-23 14:01:55 MANAGEMENT: >STATE:1364047315,ADD_ROUTES,,, 2013-03-23 14:01:55 /sbin/route add -net 10.4.0.1 10.4.41.189 255.255.255.255 add net 10.4.0.1: gateway 10.4.41.189 2013-03-23 14:01:55 Initialization Sequence Completed 2013-03-23 14:01:55 MANAGEMENT: >STATE:1364047315,CONNECTED,SUCCESS,10.4.41.190,31.193.12.74 2013-03-23 14:01:55 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ] 2013-03-23 14:01:55 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored 2013-03-23 14:01:55 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use 2013-03-23 14:01:55 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes 2013-03-23 14:02:30 *Tunnelblick process-network-changes: SearchDomains changed from * * to * <array> { * 0 : openvpn * } * pre-VPN was * 2013-03-23 14:02:30 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 6675) to restart the connection. 2013-03-23 14:02:31 event_wait : Interrupted system call (code=4) 2013-03-23 14:02:31 TCP/UDP: Closing socket 2013-03-23 14:02:31 /sbin/route delete -net 10.4.0.1 10.4.41.189 255.255.255.255 delete net 10.4.0.1: gateway 10.4.41.189 2013-03-23 14:02:31 /sbin/route delete -net 31.193.12.74 192.168.1.254 255.255.255.255 delete net 31.193.12.74: gateway 192.168.1.254 2013-03-23 14:02:31 /sbin/route delete -net 0.0.0.0 10.4.41.189 128.0.0.0 delete net 0.0.0.0: gateway 10.4.41.189 2013-03-23 14:02:31 /sbin/route delete -net 128.0.0.0 10.4.41.189 128.0.0.0 delete net 128.0.0.0: gateway 10.4.41.189 2013-03-23 14:02:31 Closing TUN/TAP interface 2013-03-23 14:02:31 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.41.190 10.4.41.189 init 2013-03-23 14:02:31 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes 2013-03-23 14:02:32 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations 2013-03-23 14:02:32 SIGUSR1[hard,] received, process restarting 2013-03-23 14:02:32 MANAGEMENT: >STATE:1364047352,RECONNECTING,SIGUSR1,, 2013-03-23 14:02:32 MANAGEMENT: CMD 'hold release' 2013-03-23 14:02:32 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2013-03-23 14:02:32 LZO compression initialized 2013-03-23 14:02:32 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 2013-03-23 14:02:32 Socket Buffers: R=[196724->65536] S=[9216->65536] 2013-03-23 14:02:32 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 2013-03-23 14:02:32 Local Options hash (VER=V4): '22188c5b' 2013-03-23 14:02:32 Expected Remote Options hash (VER=V4): 'a8f55717' 2013-03-23 14:02:32 UDPv4 link local: [undef] 2013-03-23 14:02:32 UDPv4 link remote: 31.193.12.74:443 2013-03-23 14:02:32 MANAGEMENT: >STATE:1364047352,WAIT,,, 2013-03-23 14:02:32 MANAGEMENT: >STATE:1364047352,AUTH,,, 2013-03-23 14:02:32 TLS: Initial packet from 31.193.12.74:443, sid=7ee42890 d73a50ea 2013-03-23 14:02:32 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 2013-03-23 14:02:32 VERIFY OK: nsCertType=SERVER 2013-03-23 14:02:32 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 2013-03-23 14:02:35 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-03-23 14:02:35 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-03-23 14:02:35 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-03-23 14:02:35 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-03-23 14:02:35 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2013-03-23 14:02:35 [server] Peer Connection Initiated with 31.193.12.74:443 2013-03-23 14:02:36 MANAGEMENT: >STATE:1364047356,GET_CONFIG,,, 2013-03-23 14:02:37 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-03-23 14:02:43 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-03-23 14:02:43 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.41.190 10.4.41.189' 2013-03-23 14:02:43 OPTIONS IMPORT: timers and/or timeouts modified 2013-03-23 14:02:43 OPTIONS IMPORT: LZO parms modified 2013-03-23 14:02:43 OPTIONS IMPORT: --ifconfig/up options modified 2013-03-23 14:02:43 OPTIONS IMPORT: route options modified 2013-03-23 14:02:43 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2013-03-23 14:02:43 ROUTE default_gateway=192.168.1.254 2013-03-23 14:02:43 TUN/TAP device /dev/tun0 opened 2013-03-23 14:02:43 MANAGEMENT: >STATE:1364047363,ASSIGN_IP,,10.4.41.190, 2013-03-23 14:02:43 /sbin/ifconfig tun0 delete ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address 2013-03-23 14:02:43 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure 2013-03-23 14:02:43 /sbin/ifconfig tun0 10.4.41.190 10.4.41.189 mtu 1500 netmask 255.255.255.255 up 2013-03-23 14:02:43 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.41.190 10.4.41.189 init No such key 2013-03-23 14:02:45 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ] 2013-03-23 14:02:45 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored 2013-03-23 14:02:45 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use 2013-03-23 14:02:45 *Tunnelblick: Flushed the DNS cache 2013-03-23 14:02:45 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes Quote Share this post Link to post
Staff 9761 Posted ... I'm having exactly the same problem - here is my log - can someone help??2013-03-23 14:01:49 *Tunnelblick: OS X 10.8.3; Tunnelblick 3.2.8 (build 2891.3099)Hello!The problem is showed in the above quoted log line. Tunnelblick 3.2.8 is NOT fully compatible with Mac OS X 10.8.x.Please upgrade to Tunnelblick 3.3beta21b:http://code.google.com/p/tunnelblick/wiki/DownloadsEntry?tm=2Kind regards Quote Share this post Link to post
