Not connected, Your IP: 3.145.94.251
I noticed when I went to the IP Leak page under IP address it showed up my Computers local IP address showed up. While my ISP IP address did not. Is there a problem with my local IP address showing up and if it is, how do I configure my DD-WRT to block it.
most likely this is due to a webRTC leak
If using chrome try installing uBlock origin  or privacy badger
and enable blocking of webrtc requests
or as stated on the ip leak page:
  • Mozilla Firefox: Type "about:config” in the address bar. Scroll down to “media.peerconnection.enabled”, double click to set it to false.
  • Google Chrome: Install Google official extension WebRTC Network Limiter.
  • Opera: Type "about:config" in the address bar or go to "Settings". Select "Show advanced settings" and click on "Privacy & security". At "WebRTC" mark select "Disable non-proxied UDP".
Strange behaviour on IPLeak test today on two seperate browsers:
The IP Address check (with the country flag) shows up as normal, but the DNS Address shows nothing (it usually has one or two entries with flags showing) - all it says is 0 servers, 100 errors.
Anyone any idea why this should be happening for the first time?
Can confirm, I get the same 100 errors showing up in Firefox, from Linux Mint 18 Cinnamon. I thought it was just me, as I was messing with Eddie's DNS beforehand. If you wait a while, it will reduce like mine did, to something like "44 tests pending, 66 errors". But these numbers change all the time.
Yep works now. Thanks Staff.
More problems now when I visit IP Leak page - none of the usual info tabs are showing anything about my connection. The only thing showing is the green light confirming it's an AIrVPN Exit Node - other than that, nothing on two seperate browsers. Was working fine not long ago.
