Not connected, Your IP: 18.116.42.208
nexxus
SSL certificate problem
Hi, since a couple of days I'm getting following problem on a Macbook AIr & Eddie and cant connect anymore:
I 2018.01.23 16:21:37 - Eddie version: 2.13.6 / macos_x64, System: MacOS, Name: 10.9.5, Version: Darwin MacBook-Air-532.local 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64, Mono/.Net Framework: v4.0.30319
. 2018.01.23 16:21:37 - Reading options from /Users/User1/.airvpn/AirVPN.xml
. 2018.01.23 16:21:38 - Command line arguments (0):
I 2018.01.23 16:21:40 - OpenVPN Driver - Expected
I 2018.01.23 16:21:40 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
I 2018.01.23 16:21:40 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
I 2018.01.23 16:21:40 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2018.01.23 16:21:40 - curl - Version: 7.30.0 (/usr/bin/curl)
I 2018.01.23 16:21:40 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/cacert.pem
. 2018.01.23 16:21:40 - Updating systems & servers data ...
! 2018.01.23 16:21:40 - Ready
. 2018.01.23 16:21:42 - Systems & servers data update completed
I 2018.01.23 16:21:46 - Session starting.
. 2018.01.23 16:21:46 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2018.01.23 16:21:46 - IPv6 disabled on network adapter (Thunderbolt Ethernet)
. 2018.01.23 16:21:46 - IPv6 disabled on network adapter (Wi-Fi)
. 2018.01.23 16:21:47 - IPv6 disabled on network adapter (iPhone)
. 2018.01.23 16:21:47 - IPv6 disabled on network adapter (Thunderbolt Ethernet 2)
. 2018.01.23 16:21:47 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2018.01.23 16:21:59 - Checking authorization ...
! 2018.01.23 16:22:00 - Connecting to Heze (United States, Fremont, California)
. 2018.01.23 16:22:00 - OpenVPN > OpenVPN 2.4.3 x86_64-apple-darwin16.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jun 23 2017
. 2018.01.23 16:22:00 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.01.23 16:22:00 - Connection to OpenVPN Management Interface
. 2018.01.23 16:22:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.23 16:22:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.23 16:22:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.23 16:22:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]46.21.151.106:443
. 2018.01.23 16:22:00 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2018.01.23 16:22:00 - OpenVPN > UDP link local: (not bound)
. 2018.01.23 16:22:00 - OpenVPN > UDP link remote: [AF_INET]46.21.151.106:443
. 2018.01.23 16:22:00 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.23 16:22:00 - OpenVPN > TLS: Initial packet from [AF_INET]46.21.151.106:443, sid=c6c0e191 f9de6557
. 2018.01.23 16:22:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.23 16:22:00 - OpenVPN > VERIFY KU OK
. 2018.01.23 16:22:00 - OpenVPN > Validating certificate extended key usage
. 2018.01.23 16:22:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.23 16:22:00 - OpenVPN > VERIFY EKU OK
. 2018.01.23 16:22:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.01.23 16:22:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.23 16:22:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.21.151.106:443
. 2018.01.23 16:22:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.01.23 16:22:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.62.134 255.255.0.0'
. 2018.01.23 16:22:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.01.23 16:22:02 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.01.23 16:22:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.01.23 16:22:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2018.01.23 16:22:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.01.23 16:22:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.01.23 16:22:02 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.23 16:22:02 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.23 16:22:02 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.23 16:22:02 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.23 16:22:02 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=en0 HWADDR=64:76:ba:a6:88:fe
. 2018.01.23 16:22:02 - OpenVPN > Opened utun device utun0
. 2018.01.23 16:22:02 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2018.01.23 16:22:02 - OpenVPN > /sbin/ifconfig utun0 delete
. 2018.01.23 16:22:02 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2018.01.23 16:22:02 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2018.01.23 16:22:02 - OpenVPN > /sbin/ifconfig utun0 10.4.62.134 10.4.62.134 netmask 255.255.0.0 mtu 1500 up
. 2018.01.23 16:22:02 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.62.134 255.255.0.0
. 2018.01.23 16:22:02 - OpenVPN > add net 10.4.0.0: gateway 10.4.62.134
. 2018.01.23 16:22:02 - OpenVPN > /sbin/route add -net 46.21.151.106 192.168.0.1 255.255.255.255
. 2018.01.23 16:22:02 - OpenVPN > add net 46.21.151.106: gateway 192.168.0.1
. 2018.01.23 16:22:02 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2018.01.23 16:22:02 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2018.01.23 16:22:02 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2018.01.23 16:22:02 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2018.01.23 16:22:03 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2018.01.23 16:22:03 - DNS of a network adapter forced (Thunderbolt Ethernet 2, from Automatic to 10.4.0.1)
. 2018.01.23 16:22:03 - Flushing DNS
I 2018.01.23 16:22:03 - Checking route
. 2018.01.23 16:22:03 - curl: (60) SSL certificate problem: Invalid certificate chain
. 2018.01.23 16:22:03 -     More details here: http://curl.haxx.se/docs/sslcerts.html
. 2018.01.23 16:22:03 -     curl performs SSL certificate verification by default, using a "bundle"
. 2018.01.23 16:22:03 -     of Certificate Authority (CA) public keys (CA certs). If the default
. 2018.01.23 16:22:03 -     bundle file isn't adequate, you can specify an alternate file
. 2018.01.23 16:22:03 -     using the --cacert option.
. 2018.01.23 16:22:03 -     If this HTTPS server uses a certificate signed by a CA represented in
. 2018.01.23 16:22:03 -     the bundle, the certificate verification probably failed due to a
. 2018.01.23 16:22:03 -     problem with the certificate (it might be expired, or the name might
. 2018.01.23 16:22:03 -     not match the domain name in the URL).
. 2018.01.23 16:22:03 -     If you'd like to turn off curl's verification of the certificate, use
. 2018.01.23 16:22:03 -     the -k (or --insecure) option.
. 2018.01.23 16:22:03 - Checking route (2° try)
. 2018.01.23 16:22:05 - curl: (60) SSL certificate problem: Invalid certificate chain
. 2018.01.23 16:22:05 -     More details here: http://curl.haxx.se/docs/sslcerts.html
. 2018.01.23 16:22:05 -     curl performs SSL certificate verification by default, using a "bundle"
. 2018.01.23 16:22:05 -     of Certificate Authority (CA) public keys (CA certs). If the default
. 2018.01.23 16:22:05 -     bundle file isn't adequate, you can specify an alternate file
. 2018.01.23 16:22:05 -     using the --cacert option.
. 2018.01.23 16:22:05 -     If this HTTPS server uses a certificate signed by a CA represented in
. 2018.01.23 16:22:05 -     the bundle, the certificate verification probably failed due to a
. 2018.01.23 16:22:05 -     problem with the certificate (it might be expired, or the name might
. 2018.01.23 16:22:05 -     not match the domain name in the URL).
. 2018.01.23 16:22:05 -     If you'd like to turn off curl's verification of the certificate, use
. 2018.01.23 16:22:05 -     the -k (or --insecure) option.
. 2018.01.23 16:22:05 - Checking route (3° try)
. 2018.01.23 16:22:08 - curl: (60) SSL certificate problem: Invalid certificate chain
. 2018.01.23 16:22:08 -     More details here: http://curl.haxx.se/docs/sslcerts.html
. 2018.01.23 16:22:08 -     curl performs SSL certificate verification by default, using a "bundle"
. 2018.01.23 16:22:08 -     of Certificate Authority (CA) public keys (CA certs). If the default
. 2018.01.23 16:22:08 -     bundle file isn't adequate, you can specify an alternate file
. 2018.01.23 16:22:08 -     using the --cacert option.
. 2018.01.23 16:22:08 -     If this HTTPS server uses a certificate signed by a CA represented in
. 2018.01.23 16:22:08 -     the bundle, the certificate verification probably failed due to a
. 2018.01.23 16:22:08 -     problem with the certificate (it might be expired, or the name might
. 2018.01.23 16:22:08 -     not match the domain name in the URL).
. 2018.01.23 16:22:08 -     If you'd like to turn off curl's verification of the certificate, use
. 2018.01.23 16:22:08 -     the -k (or --insecure) option.
E 2018.01.23 16:22:08 - Checking route failed.
. 2018.01.23 16:22:08 - OpenVPN > Initialization Sequence Completed
! 2018.01.23 16:22:08 - Disconnecting
. 2018.01.23 16:22:08 - Sending management termination signal
. 2018.01.23 16:22:08 - Management - Send 'signal SIGTERM'
. 2018.01.23 16:22:13 - Connection terminated.
