watcherblue 0 Posted ... [Note, I accidentally posted this to the "Other VPN competitors or features" sub-forum and could not figure out how to move the post to this sub-forum, so I'm reposting.] I would like to be able to use AirVPN for all Internet access while simultaneously routing 192.168.x.x traffic to an OpenVPN server running on a personal ASUS router (my home LAN). Are there any instructions on how to configure this setup (on Windows)? Quote Share this post Link to post
watcherblue 0 Posted ... ping (I would really appreciate someone attempting to give me pointers on resolving this issue.) Quote Share this post Link to post
zsam288 27 Posted ... I might misunderstand your question, so just to be clear. You want to be able to go to 192.168.x.x not on AirVPN while still being connected to AirVPN?If yes, then just use Eddie, this will automatically exclude local addresses from the vpn tunnelJust make sure in settings "allow lan/private" is enabled Quote Share this post Link to post
watcherblue 0 Posted ... I might misunderstand your question, so just to be clear. You want to be able to go to 192.168.x.x not on AirVPN while still being connected to AirVPN? Yes. And the 192.168.x.x addresses will be provided via another OpenVPN connection. So, can I make Eddie open two connections simultaneously? Or do I need to somehow run the official OpenVPN client and Eddie simultaneously in order to have access to the Internet via AirVPN while being able to also access a 192.168.x.x. network via another OpenVPN connection? Quote Share this post Link to post
Staff 9691 Posted ... I might misunderstand your question, so just to be clear. You want to be able to go to 192.168.x.x not on AirVPN while still being connected to AirVPN? Yes. And the 192.168.x.x addresses will be provided via another OpenVPN connection. Hello! 192.168.0.0/16 is a private subnet. Devices already in the subnet are already in your private network, it would make no sense and it is would be also very challenging to route the local traffic onto the Internet just to receive it back in the very same private network. Why should you want to make a packet for your printer travel thousands of miles when it can travel a few meters and remain not exposed on the Internet? If you mean, instead, that you want to access your local network from the Internet, and therefore create a VPN to share devices and resources which are inside your local network from external devices in a secured environment, then you need to setup a VPN server, so that all the devices (inside and outside your physical local network) will be connected to the same virtual private network... but this has little or nothing to do with AirVPN. Kind regards 3 LZ1, iampd and zsam288 reacted to this Quote Share this post Link to post
