Not connected, Your IP: 18.222.125.171
Wasteofmytime5
Connection keeps constantly restarting and refusing to connect
I recently purchased AirVPN and wanted to use it on my Imac that has windows bootcamped on it (that might have something to do with it). I keep trying to connect to a server, but it constantly just restarts and doesn't work properly. I have found other threads with the same problem, but none oftheir solutions worked for me. These are my logs I hope any of you can be of service. Thank You.
I 2018.01.14 11:09:17 - Eddie version: 2.13.6 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.16299.0, Mono/.Net Framework: v4.0.30319
. 2018.01.14 11:09:18 - Reading options from C:\Users\Aaron Lozhkin\AppData\Local\AirVPN\AirVPN.xml
. 2018.01.14 11:09:18 - Command line arguments (1): path="home"
I 2018.01.14 11:09:22 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2018.01.14 11:09:22 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
I 2018.01.14 11:09:22 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2018.01.14 11:09:22 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2018.01.14 11:09:22 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
I 2018.01.14 11:09:22 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
. 2018.01.14 11:09:23 - Updating systems & servers data ...
! 2018.01.14 11:09:23 - Ready
. 2018.01.14 11:09:24 - Systems & servers data update completed
I 2018.01.14 11:09:38 - Checking login ...
! 2018.01.14 11:09:39 - Logged in.
I 2018.01.14 11:09:42 - Session starting.
. 2018.01.14 11:09:43 - IPv6 disabled with packet filtering.
I 2018.01.14 11:09:47 - Checking authorization ...
! 2018.01.14 11:09:48 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2018.01.14 11:09:48 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.01.14 11:09:48 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.01.14 11:09:48 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.01.14 11:09:48 - Connection to OpenVPN Management Interface
. 2018.01.14 11:09:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.14 11:09:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.214.162:443
. 2018.01.14 11:09:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.01.14 11:09:48 - OpenVPN > UDP link local: (not bound)
. 2018.01.14 11:09:48 - OpenVPN > UDP link remote: [AF_INET]184.75.214.162:443
. 2018.01.14 11:09:48 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.14 11:09:48 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.162:443, sid=4b733229 f2c60aa0
. 2018.01.14 11:09:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.14 11:09:48 - OpenVPN > VERIFY KU OK
. 2018.01.14 11:09:48 - OpenVPN > Validating certificate extended key usage
. 2018.01.14 11:09:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.14 11:09:48 - OpenVPN > VERIFY EKU OK
. 2018.01.14 11:09:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.01.14 11:09:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.14 11:09:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.214.162:443
. 2018.01.14 11:09:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.01.14 11:09:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.117.254 255.255.0.0'
. 2018.01.14 11:09:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.01.14 11:09:50 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.01.14 11:09:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.01.14 11:09:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2018.01.14 11:09:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.01.14 11:09:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.01.14 11:09:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.14 11:09:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.14 11:09:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:50 - OpenVPN > interactive service msg_channel=0
. 2018.01.14 11:09:50 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=9 HWADDR=ec:35:86:52:65:02
! 2018.01.14 11:09:50 - Disconnecting
. 2018.01.14 11:09:50 - Connection terminated.
I 2018.01.14 11:09:53 - Checking authorization ...
! 2018.01.14 11:09:54 - Connecting to Regulus (Canada, Toronto, Ontario)
. 2018.01.14 11:09:54 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.01.14 11:09:54 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.01.14 11:09:54 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.01.14 11:09:54 - Connection to OpenVPN Management Interface
. 2018.01.14 11:09:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.14 11:09:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.34:443
. 2018.01.14 11:09:54 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.01.14 11:09:54 - OpenVPN > UDP link local: (not bound)
. 2018.01.14 11:09:54 - OpenVPN > UDP link remote: [AF_INET]184.75.221.34:443
. 2018.01.14 11:09:54 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.14 11:09:54 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.34:443, sid=d1979e04 9eab1da8
. 2018.01.14 11:09:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.14 11:09:54 - OpenVPN > VERIFY KU OK
. 2018.01.14 11:09:54 - OpenVPN > Validating certificate extended key usage
. 2018.01.14 11:09:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.14 11:09:54 - OpenVPN > VERIFY EKU OK
. 2018.01.14 11:09:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.01.14 11:09:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.14 11:09:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.34:443
. 2018.01.14 11:09:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.01.14 11:09:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.160 255.255.0.0'
. 2018.01.14 11:09:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.01.14 11:09:56 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.01.14 11:09:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.01.14 11:09:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2018.01.14 11:09:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.01.14 11:09:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.01.14 11:09:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.14 11:09:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.14 11:09:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:09:56 - OpenVPN > interactive service msg_channel=0
. 2018.01.14 11:09:56 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=9 HWADDR=ec:35:86:52:65:02
! 2018.01.14 11:09:56 - Disconnecting
. 2018.01.14 11:09:56 - Connection terminated.
I 2018.01.14 11:09:59 - Checking authorization ...
! 2018.01.14 11:10:03 - Connecting to Mintaka (Canada, Toronto, Ontario)
. 2018.01.14 11:10:03 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.01.14 11:10:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.01.14 11:10:03 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.01.14 11:10:03 - Connection to OpenVPN Management Interface
. 2018.01.14 11:10:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.14 11:10:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.218:443
. 2018.01.14 11:10:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.01.14 11:10:03 - OpenVPN > UDP link local: (not bound)
. 2018.01.14 11:10:03 - OpenVPN > UDP link remote: [AF_INET]184.75.223.218:443
. 2018.01.14 11:10:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.14 11:10:03 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.218:443, sid=373e21ff 395332df
. 2018.01.14 11:10:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.14 11:10:03 - OpenVPN > VERIFY KU OK
. 2018.01.14 11:10:03 - OpenVPN > Validating certificate extended key usage
. 2018.01.14 11:10:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.14 11:10:03 - OpenVPN > VERIFY EKU OK
. 2018.01.14 11:10:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.01.14 11:10:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.14 11:10:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.218:443
. 2018.01.14 11:10:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.01.14 11:10:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.33.169 255.255.0.0'
. 2018.01.14 11:10:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.01.14 11:10:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.01.14 11:10:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.01.14 11:10:04 - OpenVPN > OPTIONS IMPORT: route options modified
. 2018.01.14 11:10:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.01.14 11:10:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.01.14 11:10:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.14 11:10:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2018.01.14 11:10:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:04 - OpenVPN > interactive service msg_channel=0
. 2018.01.14 11:10:04 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=9 HWADDR=ec:35:86:52:65:02
! 2018.01.14 11:10:04 - Disconnecting
. 2018.01.14 11:10:04 - Connection terminated.
I 2018.01.14 11:10:07 - Checking authorization ...
! 2018.01.14 11:10:08 - Connecting to Tegmen (Canada, Toronto, Ontario)
. 2018.01.14 11:10:08 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.01.14 11:10:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.01.14 11:10:08 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.01.14 11:10:08 - Connection to OpenVPN Management Interface
. 2018.01.14 11:10:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.14 11:10:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]137.63.71.50:443
. 2018.01.14 11:10:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.01.14 11:10:08 - OpenVPN > UDP link local: (not bound)
. 2018.01.14 11:10:08 - OpenVPN > UDP link remote: [AF_INET]137.63.71.50:443
. 2018.01.14 11:10:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.14 11:10:10 - OpenVPN > TLS: Initial packet from [AF_INET]137.63.71.50:443, sid=f11e385e b86412f6
. 2018.01.14 11:10:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.14 11:10:10 - OpenVPN > VERIFY KU OK
. 2018.01.14 11:10:10 - OpenVPN > Validating certificate extended key usage
. 2018.01.14 11:10:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.14 11:10:10 - OpenVPN > VERIFY EKU OK
. 2018.01.14 11:10:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tegmen, emailAddress=info@airvpn.org
. 2018.01.14 11:10:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.14 11:10:10 - OpenVPN > [Tegmen] Peer Connection Initiated with [AF_INET]137.63.71.50:443
! 2018.01.14 11:10:11 - Disconnecting
. 2018.01.14 11:10:11 - Connection terminated.
I 2018.01.14 11:10:14 - Checking authorization ...
! 2018.01.14 11:10:15 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2018.01.14 11:10:15 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.01.14 11:10:15 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.01.14 11:10:15 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.01.14 11:10:15 - Connection to OpenVPN Management Interface
. 2018.01.14 11:10:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.14 11:10:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.14 11:10:15 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.202:443
. 2018.01.14 11:10:15 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.01.14 11:10:15 - OpenVPN > UDP link local: (not bound)
. 2018.01.14 11:10:15 - OpenVPN > UDP link remote: [AF_INET]184.75.223.202:443
. 2018.01.14 11:10:15 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.14 11:10:15 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.202:443, sid=d6e8c2f8 49cc15b3
. 2018.01.14 11:10:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.14 11:10:15 - OpenVPN > VERIFY KU OK
. 2018.01.14 11:10:15 - OpenVPN > Validating certificate extended key usage
. 2018.01.14 11:10:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.14 11:10:15 - OpenVPN > VERIFY EKU OK
. 2018.01.14 11:10:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.01.14 11:10:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.14 11:10:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.202:443
. 2018.01.14 11:10:16 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
! 2018.01.14 11:10:17 - Disconnecting
. 2018.01.14 11:10:17 - Connection terminated.
I 2018.01.14 11:10:20 - Checking authorization ...
. 2018.01.14 11:10:29 - Above log line repeated 2 times more
I 2018.01.14 11:10:29 - Cancel requested.
. 2018.01.14 11:10:29 - IPv6 restored with packet filtering.
! 2018.01.14 11:10:29 - Session terminated.
