Not connected, Your IP: 3.138.200.66
trubadur
Ubuntu 17.10 internet connection problems
I got eddie working for a while on Ubuntu 17.10 but now I'm encountering problems. Now when I boot my computer I don't have an internet connection unless I'm connected through eddie. Also, eddie gets stuck on "flushing dns...". I suspect that this started happening when I did not disconnect my vpn connection before shutting down. If anyone has encountered similar problems with Ubuntu 17.10 please share, I can't be the only one.
logs
I 2017.12.22 01:52:29 - Eddie version: 2.13.6 / linux_x64, System: Linux, Name: Ubuntu 17.10 \n \l, Version: Linux robin-GE60-2PC 4.13.0-21-generic #24-Ubuntu SMP Mon Dec 18 17:29:16 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net Framework: v4.0.30319
. 2017.12.22 01:52:29 - Reading options from /home/robin/.airvpn/AirVPN.xml
. 2017.12.22 01:52:29 - Command line arguments (1): path="/home/robin/.airvpn"
I 2017.12.22 01:52:30 - OpenVPN Driver - Found, /dev/net/tun
I 2017.12.22 01:52:30 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08 (/usr/sbin/openvpn)
I 2017.12.22 01:52:30 - SSH - Version: OpenSSH_7.5p1 Ubuntu-10, OpenSSL 1.0.2g 1 Mar 2016 (/usr/bin/ssh)
I 2017.12.22 01:52:30 - SSL - Version: stunnel 5.39 (/usr/bin/stunnel4)
I 2017.12.22 01:52:30 - curl - Version: 7.55.1 (/usr/bin/curl)
I 2017.12.22 01:52:30 - Certification Authorities: /usr/share/AirVPN/cacert.pem
. 2017.12.22 01:52:30 - Updating systems & servers data ...
! 2017.12.22 01:52:30 - Ready
. 2017.12.22 01:52:31 - Systems & servers data update completed
I 2017.12.22 01:52:32 - Session starting.
I 2017.12.22 01:52:32 - Checking authorization ...
! 2017.12.22 01:52:32 - Connecting to Ain (Sweden, Stockholm)
. 2017.12.22 01:52:40 - OpenVPN > OpenVPN 2.4.3 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 3 2017
. 2017.12.22 01:52:40 - OpenVPN > library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08
. 2017.12.22 01:52:40 - Connection to OpenVPN Management Interface
. 2017.12.22 01:52:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.12.22 01:52:40 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.22 01:52:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.12.22 01:52:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.104.79:443
. 2017.12.22 01:52:40 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2017.12.22 01:52:40 - OpenVPN > UDP link local: (not bound)
. 2017.12.22 01:52:40 - OpenVPN > UDP link remote: [AF_INET]128.127.104.79:443
. 2017.12.22 01:52:40 - OpenVPN > TLS: Initial packet from [AF_INET]128.127.104.79:443, sid=39332b76 c4f076f1
. 2017.12.22 01:52:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.12.22 01:52:40 - OpenVPN > VERIFY KU OK
. 2017.12.22 01:52:40 - OpenVPN > Validating certificate extended key usage
. 2017.12.22 01:52:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.12.22 01:52:40 - OpenVPN > VERIFY EKU OK
. 2017.12.22 01:52:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ain, emailAddress=info@airvpn.org
. 2017.12.22 01:52:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.12.22 01:52:40 - OpenVPN > [Ain] Peer Connection Initiated with [AF_INET]128.127.104.79:443
. 2017.12.22 01:52:40 - OpenVPN > SENT CONTROL [Ain]: 'PUSH_REQUEST' (status=1)
. 2017.12.22 01:52:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.122 255.255.0.0,peer-id 0,cipher AES-256-GCM'
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.12.22 01:52:40 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.12.22 01:52:40 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2017.12.22 01:52:40 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.12.22 01:52:40 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.12.22 01:52:40 - OpenVPN > ROUTE_GATEWAY 192.168.10.1/255.255.255.0 IFACE=wlp5s0 HWADDR=a0:88:69:6c:be:a2
. 2017.12.22 01:52:40 - OpenVPN > TUN/TAP device tun0 opened
. 2017.12.22 01:52:40 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.12.22 01:52:40 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.12.22 01:52:40 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.12.22 01:52:40 - OpenVPN > /sbin/ip addr add dev tun0 10.4.6.122/16 broadcast 10.4.255.255
. 2017.12.22 01:52:40 - OpenVPN > /sbin/ip route add 128.127.104.79/32 via 192.168.10.1
. 2017.12.22 01:52:40 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1
. 2017.12.22 01:52:40 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1
. 2017.12.22 01:52:40 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2017.12.22 01:52:40 - Flushing DNS
. 2017.12.22 02:02:31 - Updating systems & servers data ...
. 2017.12.22 02:02:32 - Systems & servers data update completed
