lemonade 4 Posted ... Hello I have a Macbook Air running 10.11.6 El Capitan My membership with AirVPN runs for at least another few months. I am having trouble connecting to my VPN and would like some help. Here are the logs. I 2017.10.30 06:49:34 - Eddie client version: 2.12.4 / macos_x64, System: MacOS, Name: 10.11.6, Mono/.Net Framework: v4.0.30319. 2017.10.30 06:49:34 - Reading options from /Users/XXXXXX/.airvpn/AirVPN.xml. 2017.10.30 06:49:35 - Data path: /Users/XXXXXX/.airvpn. 2017.10.30 06:49:35 - Application path: /Applications/Eddie.app/Contents/MacOS. 2017.10.30 06:49:35 - Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie. 2017.10.30 06:49:35 - Command line arguments (1): gui.osx.style="dark". 2017.10.30 06:49:35 - Operating System: Unix 15.6.0.0 - Darwin XXXXXXX.local 15.6.0 Darwin Kernel Version 15.6.0: Wed Nov 2 20:30:56 PDT 2016; root:xnu-3248.60.11.1.2~2/RELEASE_X86_64 x86_64I 2017.10.30 06:49:35 - OpenVPN Driver - ExpectedI 2017.10.30 06:49:35 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (/Applications/Eddie.app/Contents/MacOS/openvpn)I 2017.10.30 06:49:35 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)I 2017.10.30 06:49:35 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)I 2017.10.30 06:49:35 - curl - Version: 7.43.0 (/usr/bin/curl)I 2017.10.30 06:49:35 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem! 2017.10.30 06:49:35 - Activation of Network Lock - OS X - PF. 2017.10.30 06:49:35 - OS X - PF rules updated, reloading. 2017.10.30 06:49:35 - Updating systems & servers data ...I 2017.10.30 06:49:35 - Session starting.. 2017.10.30 06:49:35 - IPv6 disabled on network adapter (Wi-Fi). 2017.10.30 06:49:35 - IPv6 disabled on network adapter (Bluetooth PAN). 2017.10.30 06:49:35 - IPv6 disabled on network adapter (Thunderbolt Bridge). 2017.10.30 06:49:36 - Systems & servers data update completedI 2017.10.30 06:49:42 - Checking authorization ...! 2017.10.30 06:49:42 - Connecting to Agena (Canada, Toronto, Ontario)! 2017.10.30 06:49:43 - Disconnecting. 2017.10.30 06:49:43 - Connection terminated.. 2017.10.30 06:49:43 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017. 2017.10.30 06:49:43 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.10.30 06:49:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107. 2017.10.30 06:49:43 - OpenVPN > Error: private key password verification failed. 2017.10.30 06:49:43 - OpenVPN > Exiting due to fatal errorI 2017.10.30 06:49:46 - Checking authorization ...! 2017.10.30 06:49:46 - Connecting to Arkab (Canada, Toronto, Ontario). 2017.10.30 06:49:46 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017. 2017.10.30 06:49:46 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.10.30 06:49:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107. 2017.10.30 06:49:46 - OpenVPN > Error: private key password verification failed. 2017.10.30 06:49:46 - OpenVPN > Exiting due to fatal error! 2017.10.30 06:49:46 - Disconnecting. 2017.10.30 06:49:46 - Connection terminated.I 2017.10.30 06:49:49 - Cancel requested.. 2017.10.30 06:49:49 - IPv6 restored on network adapter (Wi-Fi). 2017.10.30 06:49:49 - IPv6 restored on network adapter (Bluetooth PAN). 2017.10.30 06:49:49 - IPv6 restored on network adapter (Thunderbolt Bridge)! 2017.10.30 06:49:49 - Session terminated. Also here are todays logs I 2017.11.02 15:26:30 - Eddie client version: 2.12.4 / macos_x64, System: MacOS, Name: 10.11.6, Mono/.Net Framework: v4.0.30319. 2017.11.02 15:26:30 - Reading options from /Users/XXXX/.airvpn/AirVPN.xml. 2017.11.02 15:26:31 - Data path: /Users/XXXX/.airvpn. 2017.11.02 15:26:31 - Application path: /Applications/Eddie.app/Contents/MacOS. 2017.11.02 15:26:31 - Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie. 2017.11.02 15:26:31 - Command line arguments (1): gui.osx.style="dark". 2017.11.02 15:26:31 - Operating System: Unix 15.6.0.0 - Darwin XXXXXlocal 15.6.0 Darwin Kernel Version 15.6.0: Wed Nov 2 20:30:56 PDT 2016; root:xnu-3248.60.11.1.2~2/RELEASE_X86_64 x86_64I 2017.11.02 15:26:31 - OpenVPN Driver - ExpectedI 2017.11.02 15:26:31 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (/Applications/Eddie.app/Contents/MacOS/openvpn)I 2017.11.02 15:26:31 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)I 2017.11.02 15:26:31 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)I 2017.11.02 15:26:31 - curl - Version: 7.43.0 (/usr/bin/curl)I 2017.11.02 15:26:31 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/../Resources/cacert.pem! 2017.11.02 15:26:31 - Activation of Network Lock - OS X - PF. 2017.11.02 15:26:31 - OS X - PF rules updated, reloadingI 2017.11.02 15:26:31 - Session starting.. 2017.11.02 15:26:31 - Updating systems & servers data .... 2017.11.02 15:26:31 - IPv6 disabled on network adapter (Wi-Fi). 2017.11.02 15:26:32 - IPv6 disabled on network adapter (Bluetooth PAN). 2017.11.02 15:26:32 - IPv6 disabled on network adapter (Thunderbolt Bridge). 2017.11.02 15:26:32 - Systems & servers data update completedI 2017.11.02 15:26:40 - Cancel requested.. 2017.11.02 15:26:40 - IPv6 restored on network adapter (Wi-Fi). 2017.11.02 15:26:40 - IPv6 restored on network adapter (Bluetooth PAN). 2017.11.02 15:26:40 - IPv6 restored on network adapter (Thunderbolt Bridge)! 2017.11.02 15:26:40 - Session terminated.I 2017.11.02 15:26:43 - Session starting.. 2017.11.02 15:26:43 - IPv6 disabled on network adapter (Wi-Fi). 2017.11.02 15:26:43 - IPv6 disabled on network adapter (Bluetooth PAN). 2017.11.02 15:26:43 - IPv6 disabled on network adapter (Thunderbolt Bridge)I 2017.11.02 15:26:43 - Checking authorization ...! 2017.11.02 15:26:44 - Connecting to Sualocin (Canada, Toronto, Ontario)! 2017.11.02 15:26:44 - Disconnecting. 2017.11.02 15:26:44 - Connection terminated.. 2017.11.02 15:26:52 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017. 2017.11.02 15:26:52 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.11.02 15:26:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107. 2017.11.02 15:26:52 - OpenVPN > Error: private key password verification failed. 2017.11.02 15:26:52 - OpenVPN > Exiting due to fatal errorI 2017.11.02 15:26:53 - Checking authorization ...! 2017.11.02 15:26:53 - Connecting to Ukdah (Canada, Toronto, Ontario)! 2017.11.02 15:26:53 - Disconnecting. 2017.11.02 15:26:53 - Connection terminated.I 2017.11.02 15:26:57 - Checking authorization ...! 2017.11.02 15:26:57 - Connecting to Alya (Canada, Toronto, Ontario). 2017.11.02 15:26:57 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017. 2017.11.02 15:26:57 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.11.02 15:26:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107. 2017.11.02 15:26:57 - OpenVPN > Error: private key password verification failed. 2017.11.02 15:26:57 - OpenVPN > Exiting due to fatal error. 2017.11.02 15:26:57 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017. 2017.11.02 15:26:57 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.11.02 15:26:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107! 2017.11.02 15:26:57 - Disconnecting. 2017.11.02 15:26:57 - Connection terminated.. 2017.11.02 15:26:57 - OpenVPN > Error: private key password verification failed. 2017.11.02 15:26:57 - OpenVPN > Exiting due to fatal errorI 2017.11.02 15:27:00 - Checking authorization ...! 2017.11.02 15:27:01 - Connecting to Lesath (Canada, Toronto, Ontario). 2017.11.02 15:27:01 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017. 2017.11.02 15:27:01 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.11.02 15:27:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3107. 2017.11.02 15:27:01 - OpenVPN > Error: private key password verification failed. 2017.11.02 15:27:01 - OpenVPN > Exiting due to fatal error! 2017.11.02 15:27:01 - Disconnecting. 2017.11.02 15:27:01 - Connection terminated.I 2017.11.02 15:27:03 - Cancel requested.. 2017.11.02 15:27:03 - IPv6 restored on network adapter (Wi-Fi). 2017.11.02 15:27:03 - IPv6 restored on network adapter (Bluetooth PAN). 2017.11.02 15:27:03 - IPv6 restored on network adapter (Thunderbolt Bridge)! 2017.11.02 15:27:03 - Session terminated. I have no idea what to do. Two additional things that may or may not be related: I do not have IPV6 enable. At least I dont think so. And Eddie does not start when the computer starts despite the box being checked for such action. Please help. Thank you. Quote Share this post Link to post
go558a83nk 343 Posted ... First thing to do is update to the latest version. See if that works. Quote Share this post Link to post
lemonade 4 Posted ... Cool Now I have this I 2017.11.02 16:04:29 - Eddie version: 2.13.6 / macos_x64, System: MacOS, Name: 10.11.6, Version: Darwin XXXXX.local 15.6.0 Darwin Kernel Version 15.6.0: Wed Nov 2 20:30:56 PDT 2016; root:xnu-3248.60.11.1.2~2/RELEASE_X86_64 x86_64, Mono/.Net Framework: v4.0.30319. 2017.11.02 16:04:29 - Reading options from /Users/XXXXX/.airvpn/AirVPN.xml. 2017.11.02 16:04:30 - Command line arguments (1): gui.osx.style="dark"I 2017.11.02 16:04:31 - OpenVPN Driver - ExpectedI 2017.11.02 16:04:31 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l 25 May 2017, LZO 2.10 (/Users/XXXXXX/Desktop/Eddie.app/Contents/MacOS/openvpn)I 2017.11.02 16:04:31 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)I 2017.11.02 16:04:31 - SSL - Version: stunnel 5.40 (/Users/XXXXXX/Desktop/Eddie.app/Contents/MacOS/stunnel)I 2017.11.02 16:04:31 - curl - Version: 7.43.0 (/usr/bin/curl)I 2017.11.02 16:04:31 - Certification Authorities: /Users/XXXXX/Desktop/Eddie.app/Contents/MacOS/cacert.pem! 2017.11.02 16:04:31 - Activation of Network Lock - OS X - PF. 2017.11.02 16:04:32 - OS X - PF rules updated, reloadingF 2017.11.02 16:04:32 - Unable to start PF Firewall.. 2017.11.02 16:04:40 - Updating systems & servers data ...I 2017.11.02 16:04:40 - Session starting.. 2017.11.02 16:04:41 - IPv6 disabled on network adapter (Wi-Fi). 2017.11.02 16:04:41 - IPv6 disabled on network adapter (Bluetooth PAN). 2017.11.02 16:04:41 - IPv6 disabled on network adapter (Thunderbolt Bridge). 2017.11.02 16:04:41 - Systems & servers data update completedI 2017.11.02 16:05:03 - Checking authorization ...! 2017.11.02 16:05:03 - Connecting to Tyl (Canada, Toronto, Ontario)! 2017.11.02 16:05:03 - Disconnecting. 2017.11.02 16:05:03 - Connection terminated. Quote Share this post Link to post
