Not connected, Your IP: 3.16.66.206
ls176
Eddie 2.13.6 and XP
Eddie 2.13.6 on an XP SP3 box fails to load:
Unable to load DLL 'Lib.Platform.Windows.Native.dll': The specified procedure could not be found.
(Exception from HRESULT: 0x8007007F)
Eddie-CLI.exe is more forthcoming:
Unhandled Exception: System.DllNotFoundException: Unable to load DLL 'Lib.Platform.W
indows.Native.dll': The specified procedure could not be found. (Exception from HRES
ULT: 0x8007007F)
   at Eddie.Platform.Windows.Native.eddie_test_native()
   at Eddie.Platform.Windows.Platform.NativeTest()
   at Eddie.Core.Engine.Initialization(Boolean cli)
   at Eddie.CLI.Windows.Program.Main(String[] args)
Looking briefly I see Lib.Platform.Windows.Native.dll imports fwpuclnt.dll, part of Windows Filtering Platform.  WFP is Vista+.
So... XP dropped?
The download page states XP is not recommended for a good reason. If you're using a VPN for your privacy, using XP — that hasn't seen an update since 2014 — is counterproductive.
I highly recommend you upgrade to Windows 7 at least or migrate to another OS (Linux or MacOS)!!
XP is a very old OS and Air has said on a number of occasions that one cannot reasonably expect it to be supported for much longer.
However this event once more shows that Windows XP should no more be used when security is a priority. It is an abandoned system. It seems somehow contradictory to use AirVPN services while at the same time running Windows XP...
That it received any support at all, is a small miracle in itself. So if possible, you ought to use a newer OS.
I recommend:
- Seeing if you can change to use Windows Firewall, if you can start Eddie.
- Running Eddie in compatibility mode.
- Running a portable version of Eddie.
Otherwise you may have to upgrade your OS or install Linux alongside Windows XP. If you really must, you could also try downloading an older version of Eddie (also under "Other Versions" on the download page) if you really must. But I don't know if this would make a difference; except for lowering your security even more.
What I am getting at is the download page happily serves up 2.13.6 XP builds which afaict can't work and should probably redirect to 2.12.4 or a big red splash or something.
No I don't think that would make sense and it's probably a lot of work in the end.
As long as you've got the option to download earlier versions, I think that's fair and I assume you've found out where to download them.
