Not connected, Your IP: 18.117.107.90
I am seeking some help with an issue that I have. I have airvpn set up and install on my ubuntu machine that I am using as a file/media server. I have gotten plex to work remotely perfectly. Before installing airvpn, I would connect to this media server using my windows machine by putting in the domain name that I assigned to the media server into putty on the windows machine and I would connect and do whatever I needed to do via the command line. After installing airvpn and running it on the ubuntu machine (media server) I can no longer connect via putty from the windows machine to the ubuntu machine (media server)
Can a staff or admin provide me with some kind of help on this topic so I can fix this issue.
Thank you.
