Slow p2p with port forwarding enabled
slow p2p torrent port forwarding
  • Please log in to reply
3 replies to this topic
#1 Tommelot
Tommelot
  • Members
  • Pip
  • 3 posts
Posted 02 October 2017 - 08:23 AM
Hi all,
The screenshot below shows the struggles I've been having with AirVPN, since I bought a subscription yesterday Capture1.PNG
My internet connection is 30 mbit, but I already know from experience without vpn that the provider delivers a consistent 10 mbit connection (something they won't fix),
However, since I joined AirVPN the p2p capacity has grinded to a halt! Using a private torrent subscription, I normally download 1mb/s, and I still seem to be able to reach those speeds for a few minutes per hour, but the rest of the time the speeds are reduced to 50kb/s max.
I've set up Deluge to only listen on a specific port, which I received through this website, but it seems to no avail.
Looking at the eddie log, it appears that the slowdown either started or ended around the 9:50 mark (I wasn't tracking when I took the screenshots), and would really like to consistently receive quicker speeds. Is there anything I can try? I've already tried a few different servers and did the general reading-up on the forum.
#2 giganerd
giganerd
    I shall have no title
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 04 October 2017 - 01:21 PM
Disabled your antivirus?
Always remember:
There's a guide to AirVPN,
Amazon IPs are not dangerous here,
running TOR exits is discouraged,
using spoilers for your logs helps us read your thread.
~ Furthermore, I propose that your paranoia is to be destroyed. ~
Instead of writing me a personal mail, consider contacting me via XMPP at gigan3rd@xmpp.airvpn.org or join the lounge@conference.xmpp.airvpn.org. I might read the mail too late whereas I'm always available on XMPP ;)
#3 Tommelot
Tommelot
  • Members
  • Pip
  • 3 posts
Posted 08 October 2017 - 04:13 PM
Antivirus? Don't have it.
#4 dudaboss
dudaboss
    Member
  • Members
  • PipPip
  • 15 posts
Posted 11 October 2017 - 08:00 PM
Some servers are slower than others especially when you connect half way around the world.  Try connecting to a closer server and check firewall settings to make sure eddie is not being affected by the firewall.
Similar Topics Collapse
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Servers online. Online Sessions: 13924 - BW: 45807 Mbit/sYour IP: 34.229.175.129Guest Access.
