Not connected, Your IP: 3.145.119.199
ChurchOfKek
Curl 28 DNS Problems
Hi. I am running Eddie 2.12.4 on my Ubuntu 17.04 machine and I have been having problems with DNS checking, with the client giving Curl 28 connection timed out. Eventually the client does manage to connect and I can then use the internet again. If I turn DNS checking off, the client connects but I get no internet. The log is quite lengthy, so I will attach it as a .txt file
airvpnlog.txt
