Not connected, Your IP: 18.118.126.241
MVirgilStone59
1337X blocks AirVPN Alkaid Chicago
1337X  [https://1337x.to] does not allow connections from AirVPN Alkaid Server Chicago
Config = AirVPN_US-Chicago-Illinois_Alkaid_UDP-443.ovpn
Several other AirVPN servers seem to connect fine. I use Alkaid often as it pings close to home and is fast for my remote location. This is new and started in the last few days.
Regards,
M.Virgil Stone Sends...
I tried to access using Sabik without success.
I have a self-signed certificate yet Chrome and Edge are generating security warnings from website URL. A fake(?) website is at [http://www.1377x.to/home/].
I used 1337x until it had become almost useless because of bogus torrents, malware infested popups, and redirects.
General suggestion to try with firefox, chrome and edge block sites and give captchas periodically no matter what I do.  They seem to deliberately mess with vpn's, adblockers and anti-trackers.  Firefox never does but will run much better with a number of config changes.  Another thing to try is stripped Chromium, it's much better at avoiding weirdblocks than the standard version.  At github: https://chromium.woolyss.com/  The green one, no sync, rtc, widevine.
