Not connected, Your IP: 216.73.217.25
DarkSpace-Harbinger
Verizon may be using Deep Packet Inspection to detect and throttle Video services and possibly VPN's used to bypass the cap.
Sadly there has been basically zero outcry about this illegal throttle. (The throttle itself is legal, but enforcement requires them to break secure connections, and that is a crime in all parts of America for any purpose other than law enforcement, and even then a warrant is required.)
