averagecdn 0 Posted ... So I am new to Airvpn... and after downloading, installing and testing I am finding that I am only get 50% of my max speed (80mb) just wondering what if anything I can do to improve this. I have an 80mb connection because of my desire for fast downloads... I mainly use usenet for my downloads... but when I want to download a torrent I plan on using airvpn.... Quote Share this post Link to post
go558a83nk 383 Posted ... Test other ways. The test on this website seems to be biased low. Quote Share this post Link to post
go558a83nk 383 Posted ... What speeds do you typically see? the test on this web site? Quote Share this post Link to post
Guest Posted ... Try using one server from different regions near you, so you can find out which server gives you best speed.Narrow them down to a specific region and test all servers.I recommend using beta.speedtest.net (same provider for same region) or a well seeded test torrent like Linux distros from https://whirlpool.net.au/wiki/test_torrentsMake sure you re power your router before testing and do at least 3 tests if you're using beta.speedtest.net I can tell you right now that I only get about 20mbps download & upload from AirVPN test even with 100MB buffer size, but my raw connection is 94/95 and I get about 75~80mbps download and well over 20mbps upload. 1 inf0warri0r reacted to this Quote Share this post Link to post
