puffyx 0 Posted ... Hi, my problem is: Connecting to Vpn(Netherlands for example) with "Eddie" is working. But i want to use OpenVPN GUI too. I install OpenVPN but the downloaded UDP Files in the config file. Now i start the OpenVPN Gui, first time running all worked, i was connected to the land i chose. But after a restart of my PC the connecting seems to be not complete. In the Taskbar it seems to be o.k: Connecting with:AirVPN_Sweden_UDP-443Connect since....IP: 10.4...The little monitor in the Taskbar is green. But if i start my browser i`m not connected to VPN. A test with "wieistmeineip.de" says i `m still in Germany (My Country). How can i resolve this problem? Sorry for my bad english. Quote Share this post Link to post
bob1324 1 Posted ... Have you tried inserting: block-outside-dns at the end of the ovpn file. Had a same problem. I found it here: https://forums.openvpn.net/viewtopic.php?t=21742 Maybe it helps. Bob Quote Share this post Link to post
OpenSourcerer 1352 Posted ... You want to use OpenVPN gui, TOO? So you want to have two connections at once? Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
