Marek.Br 0 Posted ... Hi,I can not connect to AirVPN servers, does not matter which one, as of this error: "write UDP [ECONNREFUSED]: Operation not permitted (code=1)" (last lines on the bottom of the log-file) I am running Android 7.1.2 with RessurectionRemix ROM.Does anybody have an idea what I need to change? Thank you for any advice! M.B. 2017-07-17 14:24:40 offizielle Version 0.6.73 läuft auf Android 7.1.2 API 25, ABI arm64-v8a 2017-07-17 14:24:40 Generiere OpenVPN-Konfiguration… 2017-07-17 14:24:40 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START): 2017-07-17 14:24:40 New OpenVPN Status (VPN_GENERATE_CONFIG->LEVEL_START): 2017-07-17 14:24:40 started Socket Thread 2017-07-17 14:24:40 Netzwerkstatus: CONNECTED to WIFI "bluepill" 2017-07-17 14:24:40 Debug state info: CONNECTED to WIFI "bluepill", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED 2017-07-17 14:24:40 Debug state info: CONNECTED to WIFI "bluepill", pause: userPause, shouldbeconnected: true, network: SHOULDBECONNECTED 2017-07-17 14:24:40 P:Initializing Google Breakpad! 2017-07-17 14:24:40 Current Parameter Settings: 2017-07-17 14:24:40 Warte 0s Sekunden zwischen zwei Verbindungsversuchen 2017-07-17 14:24:40 config = '/data/user/0/de.blinkt.openvpn/cache/android.conf' 2017-07-17 14:24:40 mode = 0 2017-07-17 14:24:40 show_ciphers = DISABLED 2017-07-17 14:24:40 show_digests = DISABLED 2017-07-17 14:24:40 show_engines = DISABLED 2017-07-17 14:24:40 genkey = DISABLED 2017-07-17 14:24:40 key_pass_file = '[UNDEF]' 2017-07-17 14:24:40 show_tls_ciphers = DISABLED 2017-07-17 14:24:40 connect_retry_max = 0 2017-07-17 14:24:40 Connection profiles [0]: 2017-07-17 14:24:40 proto = udp 2017-07-17 14:24:40 local = '[UNDEF]' 2017-07-17 14:24:40 local_port = '[UNDEF]' 2017-07-17 14:24:40 remote = 'nl.vpn.airdns.org' 2017-07-17 14:24:40 remote_port = '443' 2017-07-17 14:24:40 remote_float = DISABLED 2017-07-17 14:24:40 bind_defined = DISABLED 2017-07-17 14:24:40 bind_local = DISABLED 2017-07-17 14:24:40 bind_ipv6_only = DISABLED 2017-07-17 14:24:40 connect_retry_seconds = 2 2017-07-17 14:24:40 connect_timeout = 120 2017-07-17 14:24:40 socks_proxy_server = '[UNDEF]' 2017-07-17 14:24:40 socks_proxy_port = '[UNDEF]' 2017-07-17 14:24:40 tun_mtu = 1500 2017-07-17 14:24:40 tun_mtu_defined = ENABLED 2017-07-17 14:24:40 link_mtu = 1500 2017-07-17 14:24:40 link_mtu_defined = DISABLED 2017-07-17 14:24:40 tun_mtu_extra = 0 2017-07-17 14:24:40 tun_mtu_extra_defined = DISABLED 2017-07-17 14:24:40 mtu_discover_type = -1 2017-07-17 14:24:40 fragment = 0 2017-07-17 14:24:40 mssfix = 1450 2017-07-17 14:24:40 explicit_exit_notification = 5 2017-07-17 14:24:40 Connection profiles END 2017-07-17 14:24:40 remote_random = DISABLED 2017-07-17 14:24:40 ipchange = '[UNDEF]' 2017-07-17 14:24:40 dev = 'tun' 2017-07-17 14:24:40 dev_type = '[UNDEF]' 2017-07-17 14:24:40 dev_node = '[UNDEF]' 2017-07-17 14:24:40 lladdr = '[UNDEF]' 2017-07-17 14:24:40 topology = 1 2017-07-17 14:24:40 ifconfig_local = '[UNDEF]' 2017-07-17 14:24:40 ifconfig_remote_netmask = '[UNDEF]' 2017-07-17 14:24:40 ifconfig_noexec = DISABLED 2017-07-17 14:24:40 ifconfig_nowarn = ENABLED 2017-07-17 14:24:40 ifconfig_ipv6_local = '[UNDEF]' 2017-07-17 14:24:40 ifconfig_ipv6_netbits = 0 2017-07-17 14:24:40 ifconfig_ipv6_remote = '[UNDEF]' 2017-07-17 14:24:40 shaper = 0 2017-07-17 14:24:40 mtu_test = 0 2017-07-17 14:24:40 mlock = DISABLED 2017-07-17 14:24:40 keepalive_ping = 0 2017-07-17 14:24:40 keepalive_timeout = 0 2017-07-17 14:24:40 inactivity_timeout = 0 2017-07-17 14:24:40 ping_send_timeout = 0 2017-07-17 14:24:40 ping_rec_timeout = 0 2017-07-17 14:24:40 ping_rec_timeout_action = 0 2017-07-17 14:24:40 ping_timer_remote = DISABLED 2017-07-17 14:24:40 remap_sigusr1 = 0 2017-07-17 14:24:40 persist_tun = ENABLED 2017-07-17 14:24:40 persist_local_ip = DISABLED 2017-07-17 14:24:40 persist_remote_ip = DISABLED 2017-07-17 14:24:40 persist_key = DISABLED 2017-07-17 14:24:40 passtos = DISABLED 2017-07-17 14:24:40 resolve_retry_seconds = 1000000000 2017-07-17 14:24:40 resolve_in_advance = ENABLED 2017-07-17 14:24:40 username = '[UNDEF]' 2017-07-17 14:24:40 groupname = '[UNDEF]' 2017-07-17 14:24:40 chroot_dir = '[UNDEF]' 2017-07-17 14:24:40 cd_dir = '[UNDEF]' 2017-07-17 14:24:40 writepid = '[UNDEF]' 2017-07-17 14:24:40 up_script = '[UNDEF]' 2017-07-17 14:24:40 down_script = '[UNDEF]' 2017-07-17 14:24:40 down_pre = DISABLED 2017-07-17 14:24:40 up_restart = DISABLED 2017-07-17 14:24:40 up_delay = DISABLED 2017-07-17 14:24:40 daemon = DISABLED 2017-07-17 14:24:40 inetd = 0 2017-07-17 14:24:40 log = DISABLED 2017-07-17 14:24:40 suppress_timestamps = DISABLED 2017-07-17 14:24:40 machine_readable_output = ENABLED 2017-07-17 14:24:40 nice = 0 2017-07-17 14:24:40 verbosity = 4 2017-07-17 14:24:40 mute = 0 2017-07-17 14:24:40 gremlin = 0 2017-07-17 14:24:40 status_file = '[UNDEF]' 2017-07-17 14:24:40 status_file_version = 1 2017-07-17 14:24:40 status_file_update_freq = 60 2017-07-17 14:24:40 occ = ENABLED 2017-07-17 14:24:40 rcvbuf = 262144 2017-07-17 14:24:40 sndbuf = 262144 2017-07-17 14:24:40 sockflags = 0 2017-07-17 14:24:40 fast_io = DISABLED 2017-07-17 14:24:40 comp.alg = 2 2017-07-17 14:24:40 comp.flags = 1 2017-07-17 14:24:40 route_script = '[UNDEF]' 2017-07-17 14:24:40 route_default_gateway = '[UNDEF]' 2017-07-17 14:24:40 route_default_metric = 0 2017-07-17 14:24:40 route_noexec = DISABLED 2017-07-17 14:24:40 route_delay = 0 2017-07-17 14:24:40 route_delay_window = 30 2017-07-17 14:24:40 route_delay_defined = DISABLED 2017-07-17 14:24:40 route_nopull = DISABLED 2017-07-17 14:24:40 route_gateway_via_dhcp = DISABLED 2017-07-17 14:24:40 allow_pull_fqdn = DISABLED 2017-07-17 14:24:40 management_addr = '/data/user/0/de.blinkt.openvpn/cache/mgmtsocket' 2017-07-17 14:24:40 management_port = 'unix' 2017-07-17 14:24:40 management_user_pass = '[UNDEF]' 2017-07-17 14:24:40 management_log_history_cache = 250 2017-07-17 14:24:40 management_echo_buffer_size = 100 2017-07-17 14:24:40 management_write_peer_info_file = '[UNDEF]' 2017-07-17 14:24:40 management_client_user = '[UNDEF]' 2017-07-17 14:24:40 management_client_group = '[UNDEF]' 2017-07-17 14:24:40 management_flags = 4390 2017-07-17 14:24:40 shared_secret_file = '[UNDEF]' 2017-07-17 14:24:40 key_direction = 1 2017-07-17 14:24:40 ciphername = 'AES-256-CBC' 2017-07-17 14:24:40 ncp_enabled = ENABLED 2017-07-17 14:24:40 ncp_ciphers = 'AES-256-GCM:AES-128-GCM' 2017-07-17 14:24:40 authname = 'SHA1' 2017-07-17 14:24:40 prng_hash = 'SHA1' 2017-07-17 14:24:40 prng_nonce_secret_len = 16 2017-07-17 14:24:40 keysize = 0 2017-07-17 14:24:40 engine = DISABLED 2017-07-17 14:24:40 replay = ENABLED 2017-07-17 14:24:40 mute_replay_warnings = DISABLED 2017-07-17 14:24:40 replay_window = 64 2017-07-17 14:24:40 replay_time = 15 2017-07-17 14:24:40 packet_id_file = '[UNDEF]' 2017-07-17 14:24:40 test_crypto = DISABLED 2017-07-17 14:24:40 tls_server = DISABLED 2017-07-17 14:24:40 tls_client = ENABLED 2017-07-17 14:24:40 key_method = 2 2017-07-17 14:24:40 ca_file = '[[INLINE]]' 2017-07-17 14:24:40 ca_path = '[UNDEF]' 2017-07-17 14:24:40 dh_file = '[UNDEF]' 2017-07-17 14:24:40 cert_file = '[[INLINE]]' 2017-07-17 14:24:40 extra_certs_file = '[UNDEF]' 2017-07-17 14:24:40 priv_key_file = '[[INLINE]]' 2017-07-17 14:24:40 pkcs12_file = '[UNDEF]' 2017-07-17 14:24:40 cipher_list = '[UNDEF]' 2017-07-17 14:24:40 tls_verify = '[UNDEF]' 2017-07-17 14:24:40 tls_export_cert = '[UNDEF]' 2017-07-17 14:24:40 verify_x509_type = 0 2017-07-17 14:24:40 verify_x509_name = '[UNDEF]' 2017-07-17 14:24:40 crl_file = '[UNDEF]' 2017-07-17 14:24:40 ns_cert_type = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 65535 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_ku[i] = 0 2017-07-17 14:24:40 remote_cert_eku = 'TLS Web Server Authentication' 2017-07-17 14:24:40 ssl_flags = 0 2017-07-17 14:24:40 tls_timeout = 2 2017-07-17 14:24:40 renegotiate_bytes = -1 2017-07-17 14:24:40 renegotiate_packets = 0 2017-07-17 14:24:40 renegotiate_seconds = 3600 2017-07-17 14:24:40 handshake_window = 60 2017-07-17 14:24:40 transition_window = 3600 2017-07-17 14:24:40 single_session = DISABLED 2017-07-17 14:24:40 push_peer_info = DISABLED 2017-07-17 14:24:40 tls_exit = DISABLED 2017-07-17 14:24:40 tls_auth_file = '[[INLINE]]' 2017-07-17 14:24:40 tls_crypt_file = '[UNDEF]' 2017-07-17 14:24:40 client = ENABLED 2017-07-17 14:24:40 pull = ENABLED 2017-07-17 14:24:40 auth_user_pass_file = '[UNDEF]' 2017-07-17 14:24:40 OpenVPN 2.5-icsopenvpn [git:icsopenvpn-d51333c645c12713+] android-21-arm64-v8a [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jun 26 2017 2017-07-17 14:24:40 library versions: OpenSSL 1.1.0f 25 May 2017, LZO 2.10 2017-07-17 14:24:40 MANAGEMENT: Connected to management server at /data/user/0/de.blinkt.openvpn/cache/mgmtsocket 2017-07-17 14:24:40 MANAGEMENT: CMD 'hold release' 2017-07-17 14:24:40 MANAGEMENT: CMD 'proxy NONE' 2017-07-17 14:24:40 MANAGEMENT: CMD 'bytecount 2' 2017-07-17 14:24:40 MANAGEMENT: CMD 'state on' 2017-07-17 14:24:41 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 2017-07-17 14:24:41 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 2017-07-17 14:24:41 LZO compression initializing 2017-07-17 14:24:41 Control Channel MTU parms [ L:1622 D:1184 EF:66 EB:0 ET:0 EL:3 ] 2017-07-17 14:24:41 Data Channel MTU parms [ L:1622 D:1450 EF:122 EB:406 ET:0 EL:3 ] 2017-07-17 14:24:41 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client' 2017-07-17 14:24:41 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server' 2017-07-17 14:24:41 TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.19:443 2017-07-17 14:24:41 Socket Buffers: R=[212992->524288] S=[212992->524288] 2017-07-17 14:24:41 MANAGEMENT: CMD 'needok 'PROTECTFD' ok' 2017-07-17 14:24:41 UDP link local: (not bound) 2017-07-17 14:24:41 UDP link remote: [AF_INET]109.202.107.19:443 2017-07-17 14:24:41 MANAGEMENT: >STATE:1500294281,WAIT,,,,,, 2017-07-17 14:24:41 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:24:41 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,, 2017-07-17 14:24:41 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,, 2017-07-17 14:24:43 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:24:47 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:24:55 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:25:12 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:25:41 New OpenVPN Status (RECONNECTING->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): tls-error,,,,, 2017-07-17 14:25:41 New OpenVPN Status (RECONNECTING->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): tls-error,,,,, 2017-07-17 14:25:41 New OpenVPN Status (CONNECTRETRY->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): 2 2017-07-17 14:25:41 New OpenVPN Status (CONNECTRETRY->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): 2 2017-07-17 14:25:41 Warte 2s Sekunden zwischen zwei Verbindungsversuchen 2017-07-17 14:25:41 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 2017-07-17 14:25:41 TLS Error: TLS handshake failed 2017-07-17 14:25:41 TCP/UDP: Closing socket 2017-07-17 14:25:41 SIGUSR1[soft,tls-error] received, process restarting 2017-07-17 14:25:41 MANAGEMENT: >STATE:1500294341,RECONNECTING,tls-error,,,,, 2017-07-17 14:25:43 MANAGEMENT: CMD 'hold release' 2017-07-17 14:25:43 MANAGEMENT: CMD 'proxy NONE' 2017-07-17 14:25:43 MANAGEMENT: CMD 'bytecount 2' 2017-07-17 14:25:43 MANAGEMENT: CMD 'state on' 2017-07-17 14:25:44 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 2017-07-17 14:25:44 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 2017-07-17 14:25:44 LZO compression initializing 2017-07-17 14:25:44 Control Channel MTU parms [ L:1622 D:1184 EF:66 EB:0 ET:0 EL:3 ] 2017-07-17 14:25:44 Data Channel MTU parms [ L:1622 D:1450 EF:122 EB:406 ET:0 EL:3 ] 2017-07-17 14:25:44 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client' 2017-07-17 14:25:44 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server' 2017-07-17 14:25:44 TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.19:443 2017-07-17 14:25:44 Socket Buffers: R=[212992->524288] S=[212992->524288] 2017-07-17 14:25:44 MANAGEMENT: CMD 'needok 'PROTECTFD' ok' 2017-07-17 14:25:44 UDP link local: (not bound) 2017-07-17 14:25:44 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,, 2017-07-17 14:25:44 New OpenVPN Status (WAIT->LEVEL_CONNECTING_NO_SERVER_REPLY_YET): ,,,,, 2017-07-17 14:25:44 UDP link remote: [AF_INET]109.202.107.19:443 2017-07-17 14:25:44 MANAGEMENT: >STATE:1500294344,WAIT,,,,,, 2017-07-17 14:25:44 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:25:46 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:25:50 write UDP [ECONNREFUSED]: Operation not permitted (code=1) 2017-07-17 14:25:58 write UDP [ECONNREFUSED]: Operation not permitted (code=1) Quote Share this post Link to post
zhang888 1065 Posted ... Most likely a software issue on your side.Operation not permitted means you are not allowed tochange network settings. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
OpenSourcerer 1360 Posted ... Nevermind. I didn't properly see the logs apparently. Thanks Tapatalk. Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
