Not connected, Your IP: 34.228.43.90
puff-m-d
"Experimental" in Advanced Settings
In Eddies preferences under the "Advanced" tab > "Microsoft Windows Only" section, there is an "Experimental" checkbox which is unchecked by default. I have searched and can not find any reference to this setting. What is it for and what exactly does it do if checked? Someone on another forum brought this up and has made me curious as to its function. Does anyone know or have a link to explain this for me? Or maybe Staff can answer...
Any information will be greatly appreciated   ...
So if one uses a third party firewall the experimental method should be used?
