no Connection with AirVPN Client v. 2.1.2.4
  • Please log in to reply
3 replies to this topic
#1 box7020
box7020
  • New Members
  • Pip
  • 2 posts
Posted 19 June 2017 - 11:21 AM
Hi.
i just installed the AirVPN Client v. 2.1.2.4.
Ecerytime i try to connect to an Server i get the following errors, can somebody help`? :
I 2017.06.19 13:18:34 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net Framework: v2.0.50727
. 2017.06.19 13:18:34 - Reading options from C:\Users\x\AppData\Local\AirVPN\AirVPN.xml
. 2017.06.19 13:18:34 - Data path: C:\Users\x\AppData\Local\AirVPN
. 2017.06.19 13:18:34 - Application path: C:\Program Files\AirVPN
. 2017.06.19 13:18:34 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.06.19 13:18:34 - Command line arguments (1): path="home"
. 2017.06.19 13:18:34 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2017.06.19 13:18:34 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.06.19 13:18:34 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.06.19 13:18:34 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.06.19 13:18:34 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.06.19 13:18:34 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.06.19 13:18:34 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
! 2017.06.19 13:18:34 - Ready
. 2017.06.19 13:18:34 - Updating systems & servers data ...
. 2017.06.19 13:18:35 - Systems & servers data update completed
I 2017.06.19 13:19:55 - Session starting.
. 2017.06.19 13:19:55 - IPv6 disabled with packet filtering.
I 2017.06.19 13:19:55 - Checking authorization ...
! 2017.06.19 13:19:55 - Connecting to Cygnus (Netherlands, Alblasserdam)
. 2017.06.19 13:19:55 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.19 13:19:55 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.06.19 13:19:55 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.19 13:19:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.19 13:19:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 13:19:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.19 13:19:55 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.243:443
. 2017.06.19 13:19:55 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2017.06.19 13:19:55 - OpenVPN > UDP link local: (not bound)
. 2017.06.19 13:19:55 - OpenVPN > UDP link remote: [AF_INET]213.152.161.243:443
. 2017.06.19 13:19:55 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.243:443, sid=6ae97953 e449a2c1
. 2017.06.19 13:19:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.19 13:19:55 - OpenVPN > Validating certificate key usage
. 2017.06.19 13:19:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.19 13:19:55 - OpenVPN > VERIFY KU OK
. 2017.06.19 13:19:55 - OpenVPN > Validating certificate extended key usage
. 2017.06.19 13:19:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.19 13:19:55 - OpenVPN > VERIFY EKU OK
. 2017.06.19 13:19:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cygnus, emailAddress=info@airvpn.org
. 2017.06.19 13:19:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.19 13:19:55 - OpenVPN > [Cygnus] Peer Connection Initiated with [AF_INET]213.152.161.243:443
. 2017.06.19 13:19:57 - OpenVPN > SENT CONTROL [Cygnus]: 'PUSH_REQUEST' (status=1)
. 2017.06.19 13:19:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.35.130 255.255.0.0,peer-id 45,cipher AES-256-GCM'
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.19 13:19:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.19 13:19:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 13:19:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.19 13:19:57 - OpenVPN > interactive service msg_channel=0
. 2017.06.19 13:19:57 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 I=17 HWADDR=14:da:e9:4c:66:2b
. 2017.06.19 13:19:57 - OpenVPN > open_tun
. 2017.06.19 13:19:57 - OpenVPN > TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{9301F057-EC8A-41BA-8FE2-5AC48245F9F1}.tap
. 2017.06.19 13:19:57 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.19 13:19:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.35.130/255.255.0.0 [SUCCEEDED]
. 2017.06.19 13:19:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.35.130/255.255.0.0 on interface {9301F057-EC8A-41BA-8FE2-5AC48245F9F1} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.19 13:19:57 - OpenVPN > Successful ARP Flush on interface [23] {9301F057-EC8A-41BA-8FE2-5AC48245F9F1}
. 2017.06.19 13:19:57 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.19 13:20:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.19 13:20:02 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.243 MASK 255.255.255.255 192.168.2.1
. 2017.06.19 13:20:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.06.19 13:20:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.19 13:20:02 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 13:20:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.06.19 13:20:02 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 13:20:02 - Starting Management Interface
. 2017.06.19 13:20:02 - OpenVPN > Initialization Sequence Completed
. 2017.06.19 13:20:02 - DNS leak protection with packet filtering enabled.
. 2017.06.19 13:20:02 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.06.19 13:20:02 - Flushing DNS
I 2017.06.19 13:20:08 - Checking route
E 2017.06.19 13:20:18 - curl: (28) Operation timed out after 10031 milliseconds with 0 out of 0 bytes received
. 2017.06.19 13:20:18 - Checking route (2° try)
! 2017.06.19 13:20:27 - Disconnecting
. 2017.06.19 13:20:27 - Management - Send 'signal SIGTERM'
. 2017.06.19 13:20:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
E 2017.06.19 13:20:29 - curl: (28) Operation timed out after 10031 milliseconds with 0 out of 0 bytes received
. 2017.06.19 13:20:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.19 13:20:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.19 13:20:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.19 13:20:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.243 MASK 255.255.255.255 192.168.2.1
. 2017.06.19 13:20:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.19 13:20:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 13:20:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.19 13:20:32 - OpenVPN > Closing TUN/TAP interface
. 2017.06.19 13:20:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.19 13:20:32 - Connection terminated.
. 2017.06.19 13:20:32 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.06.19 13:20:32 - DNS leak protection with packet filtering disabled.
I 2017.06.19 13:20:32 - Cancel requested.
. 2017.06.19 13:20:32 - IPv6 restored with packet filtering.
. 2017.06.19 13:20:32 - Flushing DNS
! 2017.06.19 13:20:38 - Session terminated.
#2 velijoze
velijoze
  • New Members
  • Pip
  • 1 posts
Posted 20 June 2017 - 10:43 AM
I have the same problem.  Can someone please help?  Thanks.
#3 amnesty
amnesty
    Advanced Member
  • Members
  • PipPipPip
  • 199 posts
Posted 20 June 2017 - 08:00 PM
See if this helps: Preferences > Advanced > uncheck "Check if the tunnel works".
I had this a few years ago. I think Malwarebytes caused it. I created an exception for airvpn and it went away. I do not use it anymore but it could be an issue on those lines.
EDIT: I should have said why I suggested that. Because of the following in your log:
This happened to me a few years ago. I think it was malwarebytes. I created an exception for AirVPN.exe & Openvpn.exe but no longer use that program.
Edited by amnesty, 21 June 2017 - 02:28 PM.
#4 box7020
box7020
  • New Members
  • Pip
  • 2 posts
Posted 25 June 2017 - 02:40 PM
Thank you for the replie. I tried it but no luck
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 14345 - BW: 50773 Mbit/sYour IP: 54.92.153.90Guest Access.
