Eddie Client Not connecting
Not working no servers eddie client
  • Please log in to reply
5 replies to this topic
#1 dmir007
dmir007
  • New Members
  • Pip
  • 1 posts
Posted 14 June 2017 - 08:45 AM
Eddie was working until yesterday, and this morning I tried to connect, and have a problem as it cannot connect as there are no servers on the server list. i don't know what happened, I tried reinstalling and get the same problem. ( no server available). Is there a solution for this problem. There was a windows update on my PC last night, could be the cause, but I am just speculating at this time. I need a solution please.
#2 eye-eye
eye-eye
  • New Members
  • Pip
  • 2 posts
Posted 14 June 2017 - 12:02 PM
I am having the same problem. I could connect to US but not UK. Attached log. Also should it turn off leak protection?
. 2017.06.14 11:17:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.103.96.130 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:17:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:17:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:17:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:17:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:17:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:17:26 - Starting Management Interface
. 2017.06.14 11:17:26 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:17:26 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:17:26 - Flushing DNS
I 2017.06.14 11:17:29 - Checking route
E 2017.06.14 11:17:39 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:17:39 - Checking route (2° try)
E 2017.06.14 11:17:50 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:17:50 - Checking route (3° try)
E 2017.06.14 11:18:02 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:18:02 - Routing checking failed.
. 2017.06.14 11:18:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:18:02 - Disconnecting
. 2017.06.14 11:18:02 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:18:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:18:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:18:02 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:18:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.103.96.130 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:18:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:18:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:18:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:18:07 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:18:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:18:07 - Connection terminated.
. 2017.06.14 11:18:07 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:18:10 - Checking authorization ...
! 2017.06.14 11:18:11 - Connecting to Alathfar (United Kingdom, Maidenhead)
. 2017.06.14 11:18:11 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:18:11 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:18:11 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:18:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:18:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:18:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:18:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.103.96.132:443
. 2017.06.14 11:18:11 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:18:11 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:18:11 - OpenVPN > UDP link remote: [AF_INET]185.103.96.132:443
. 2017.06.14 11:18:11 - OpenVPN > TLS: Initial packet from [AF_INET]185.103.96.132:443, sid=eaa322ca e01442d3
. 2017.06.14 11:18:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:18:11 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:18:11 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:18:11 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:18:11 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:18:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:18:11 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:18:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:18:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:18:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]185.103.96.132:443
. 2017.06.14 11:18:16 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:18:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.41.139 255.255.0.0'
. 2017.06.14 11:18:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:18:16 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:18:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:18:16 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:18:16 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:18:16 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:18:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:18:16 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:18:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:18:16 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:18:16 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:18:16 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:18:16 - OpenVPN > open_tun
. 2017.06.14 11:18:16 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:18:16 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:18:16 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.41.139/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:18:16 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.41.139/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:18:16 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:18:16 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:18:21 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:18:21 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.103.96.132 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:18:21 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:18:21 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:18:21 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:18:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:18:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:18:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:18:22 - Starting Management Interface
. 2017.06.14 11:18:22 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:18:22 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:18:22 - Flushing DNS
I 2017.06.14 11:18:25 - Checking route
E 2017.06.14 11:18:35 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:18:35 - Checking route (2° try)
E 2017.06.14 11:18:46 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:18:46 - Checking route (3° try)
E 2017.06.14 11:18:58 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:18:58 - Routing checking failed.
. 2017.06.14 11:18:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:18:58 - Disconnecting
. 2017.06.14 11:18:58 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:18:58 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:18:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:18:58 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:19:03 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.103.96.132 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:19:03 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:19:03 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:19:03 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:19:03 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:19:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:19:03 - Connection terminated.
. 2017.06.14 11:19:03 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:19:06 - Checking authorization ...
! 2017.06.14 11:19:07 - Connecting to Dabih (United Kingdom, Manchester)
. 2017.06.14 11:19:07 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:19:07 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:19:07 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:19:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:19:07 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:19:07 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:19:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]82.145.37.202:443
. 2017.06.14 11:19:07 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:19:07 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:19:07 - OpenVPN > UDP link remote: [AF_INET]82.145.37.202:443
. 2017.06.14 11:19:07 - OpenVPN > TLS: Initial packet from [AF_INET]82.145.37.202:443, sid=6ef0101d ec45d0c4
. 2017.06.14 11:19:07 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:19:07 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:19:07 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:19:07 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:19:07 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:19:07 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:19:07 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:19:07 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:19:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:19:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]82.145.37.202:443
. 2017.06.14 11:19:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:19:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.125 255.255.0.0'
. 2017.06.14 11:19:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:19:09 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:19:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:19:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:19:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:19:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:19:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:19:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:19:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:19:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:19:09 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:19:09 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:19:09 - OpenVPN > open_tun
. 2017.06.14 11:19:09 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:19:09 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:19:09 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.125/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:19:09 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.125/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:19:09 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:19:09 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:19:14 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:19:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 82.145.37.202 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:19:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:19:14 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:19:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:19:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:19:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:19:14 - Starting Management Interface
. 2017.06.14 11:19:14 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:19:14 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:19:14 - Flushing DNS
I 2017.06.14 11:19:18 - Checking route
E 2017.06.14 11:19:28 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:19:28 - Checking route (2° try)
E 2017.06.14 11:19:39 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:19:39 - Checking route (3° try)
E 2017.06.14 11:19:51 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:19:51 - Routing checking failed.
. 2017.06.14 11:19:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:19:51 - Disconnecting
. 2017.06.14 11:19:51 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:19:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:19:51 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2017.06.14 11:19:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:19:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:19:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 82.145.37.202 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:19:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:19:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:19:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:19:56 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:19:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:19:56 - Connection terminated.
. 2017.06.14 11:19:57 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:20:00 - Checking authorization ...
! 2017.06.14 11:20:00 - Connecting to Algedi (United Kingdom, London)
. 2017.06.14 11:20:00 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:20:00 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:20:00 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:20:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:20:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]80.84.49.4:443
. 2017.06.14 11:20:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:20:00 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:20:00 - OpenVPN > UDP link remote: [AF_INET]80.84.49.4:443
. 2017.06.14 11:20:00 - OpenVPN > TLS: Initial packet from [AF_INET]80.84.49.4:443, sid=7735590b 83b5558a
. 2017.06.14 11:20:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:20:01 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:20:01 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:20:01 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:20:01 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:20:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:20:01 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:20:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:20:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:20:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]80.84.49.4:443
. 2017.06.14 11:20:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:20:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.17.2 255.255.0.0'
. 2017.06.14 11:20:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:20:03 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:20:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:20:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:20:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:20:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:20:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:20:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:20:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:03 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:20:03 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:20:03 - OpenVPN > open_tun
. 2017.06.14 11:20:03 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:20:03 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:20:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.17.2/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:20:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.17.2/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:20:03 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:20:03 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:20:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:20:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 80.84.49.4 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:20:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=65 and dwForwardType=4
. 2017.06.14 11:20:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:20:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:20:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:20:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:20:08 - Starting Management Interface
. 2017.06.14 11:20:08 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:20:08 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:20:08 - Flushing DNS
I 2017.06.14 11:20:12 - Checking route
E 2017.06.14 11:20:22 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:20:22 - Checking route (2° try)
E 2017.06.14 11:20:33 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:20:33 - Checking route (3° try)
E 2017.06.14 11:20:45 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:20:45 - Routing checking failed.
. 2017.06.14 11:20:45 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:20:45 - Disconnecting
. 2017.06.14 11:20:45 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:20:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:20:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:20:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:20:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 80.84.49.4 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:20:50 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:20:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:20:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:20:50 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:20:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:20:50 - Connection terminated.
. 2017.06.14 11:20:50 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:20:53 - Checking authorization ...
! 2017.06.14 11:20:54 - Connecting to Nashira (United Kingdom, Manchester)
. 2017.06.14 11:20:54 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:20:54 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:20:54 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:20:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:20:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]84.39.116.179:443
. 2017.06.14 11:20:54 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:20:54 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:20:54 - OpenVPN > UDP link remote: [AF_INET]84.39.116.179:443
. 2017.06.14 11:20:54 - OpenVPN > TLS: Initial packet from [AF_INET]84.39.116.179:443, sid=42515cee ea4596b6
. 2017.06.14 11:20:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:20:54 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:20:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:20:54 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:20:54 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:20:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:20:54 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:20:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:20:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:20:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]84.39.116.179:443
. 2017.06.14 11:20:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:20:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.2.154 255.255.0.0'
. 2017.06.14 11:20:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:20:56 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:20:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:20:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:20:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:20:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:20:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:20:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:20:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:20:56 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:20:56 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:20:56 - OpenVPN > open_tun
. 2017.06.14 11:20:57 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:20:57 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:20:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.2.154/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:20:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.2.154/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:20:57 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:20:57 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:21:01 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:21:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 84.39.116.179 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:21:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:21:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:21:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:21:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:21:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:21:01 - Starting Management Interface
. 2017.06.14 11:21:01 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:21:01 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:21:01 - Flushing DNS
I 2017.06.14 11:21:05 - Checking route
E 2017.06.14 11:21:15 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:21:15 - Checking route (2° try)
E 2017.06.14 11:21:26 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:21:26 - Checking route (3° try)
E 2017.06.14 11:21:38 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:21:38 - Routing checking failed.
. 2017.06.14 11:21:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:21:38 - Disconnecting
. 2017.06.14 11:21:38 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:21:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:21:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:21:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:21:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 84.39.116.179 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:21:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:21:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:21:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:21:43 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:21:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:21:44 - Connection terminated.
. 2017.06.14 11:21:44 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:21:47 - Checking authorization ...
! 2017.06.14 11:21:47 - Connecting to Asterion (United Kingdom, London)
. 2017.06.14 11:21:47 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:21:47 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:21:47 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:21:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:21:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:21:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:21:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.167:443
. 2017.06.14 11:21:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:21:48 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:21:48 - OpenVPN > UDP link remote: [AF_INET]217.151.98.167:443
. 2017.06.14 11:21:48 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.167:443, sid=a866c472 21e5a9c1
. 2017.06.14 11:21:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:21:48 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:21:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:21:48 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:21:48 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:21:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:21:48 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:21:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:21:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:21:49 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.167:443
. 2017.06.14 11:21:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:21:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.20.133 255.255.0.0'
. 2017.06.14 11:21:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:21:50 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:21:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:21:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:21:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:21:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:21:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:21:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:21:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:21:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:21:50 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:21:50 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:21:50 - OpenVPN > open_tun
. 2017.06.14 11:21:50 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:21:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:21:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.20.133/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:21:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.20.133/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:21:50 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:21:50 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:21:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:21:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 217.151.98.167 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:21:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:21:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:21:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:21:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:21:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:21:55 - Starting Management Interface
. 2017.06.14 11:21:55 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:21:55 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:21:56 - Flushing DNS
I 2017.06.14 11:21:59 - Checking route
E 2017.06.14 11:22:09 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:22:09 - Checking route (2° try)
. 2017.06.14 11:22:12 - Updating systems & servers data ...
E 2017.06.14 11:22:20 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:22:20 - Checking route (3° try)
E 2017.06.14 11:22:32 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:22:32 - Routing checking failed.
. 2017.06.14 11:22:32 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:22:32 - Disconnecting
. 2017.06.14 11:22:32 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:22:32 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:22:32 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:22:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:22:37 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 217.151.98.167 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:22:37 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:22:37 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:22:37 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:22:37 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:22:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:22:37 - Connection terminated.
. 2017.06.14 11:22:38 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:22:41 - Checking authorization ...
! 2017.06.14 11:22:41 - Connecting to Denebola (United Kingdom, Maidenhead)
. 2017.06.14 11:22:41 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:22:41 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:22:41 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:22:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:22:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:22:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:22:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.103.96.133:443
. 2017.06.14 11:22:41 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:22:41 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:22:41 - OpenVPN > UDP link remote: [AF_INET]185.103.96.133:443
. 2017.06.14 11:22:41 - OpenVPN > TLS: Initial packet from [AF_INET]185.103.96.133:443, sid=10929176 0f980a0a
. 2017.06.14 11:22:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:22:42 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:22:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:22:42 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:22:42 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:22:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:22:42 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:22:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:22:42 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:22:42 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]185.103.96.133:443
. 2017.06.14 11:22:44 - Systems & servers data update completed
. 2017.06.14 11:22:44 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:22:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.22.179 255.255.0.0'
. 2017.06.14 11:22:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:22:44 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:22:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:22:44 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:22:44 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:22:44 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:22:44 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:22:44 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:22:44 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:22:44 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:22:44 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:22:44 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:22:44 - OpenVPN > open_tun
. 2017.06.14 11:22:44 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:22:44 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:22:44 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.22.179/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:22:44 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.22.179/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:22:44 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:22:44 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:22:49 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:22:49 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.103.96.133 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:22:49 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:22:49 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:22:49 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:22:49 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:22:49 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:22:49 - Starting Management Interface
. 2017.06.14 11:22:49 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:22:49 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:22:49 - Flushing DNS
I 2017.06.14 11:22:52 - Checking route
E 2017.06.14 11:23:02 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:23:02 - Checking route (2° try)
E 2017.06.14 11:23:13 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:23:13 - Checking route (3° try)
E 2017.06.14 11:23:26 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:23:26 - Routing checking failed.
. 2017.06.14 11:23:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:23:26 - Disconnecting
. 2017.06.14 11:23:26 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:23:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:23:26 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2017.06.14 11:23:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:23:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:23:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.103.96.133 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:23:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:23:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:23:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:23:31 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:23:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:23:31 - Connection terminated.
. 2017.06.14 11:23:31 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:23:34 - Checking authorization ...
! 2017.06.14 11:23:35 - Connecting to Asterope (United Kingdom, Manchester)
. 2017.06.14 11:23:35 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:23:35 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:23:35 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:23:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:23:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:23:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:23:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]89.249.74.212:443
. 2017.06.14 11:23:35 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:23:35 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:23:35 - OpenVPN > UDP link remote: [AF_INET]89.249.74.212:443
. 2017.06.14 11:23:35 - OpenVPN > TLS: Initial packet from [AF_INET]89.249.74.212:443, sid=96ea8334 47a2d544
. 2017.06.14 11:23:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:23:35 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:23:35 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:23:35 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:23:35 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:23:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:23:35 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:23:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:23:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:23:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]89.249.74.212:443
. 2017.06.14 11:23:37 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:23:37 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.24.49 255.255.0.0'
. 2017.06.14 11:23:37 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:23:37 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:23:37 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:23:37 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:23:37 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:23:37 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:23:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:23:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:23:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:23:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:23:37 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:23:37 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:23:37 - OpenVPN > open_tun
. 2017.06.14 11:23:37 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:23:37 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:23:37 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.24.49/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:23:37 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.24.49/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:23:37 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:23:37 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:23:42 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:23:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 89.249.74.212 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:23:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:23:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:23:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:23:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:23:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:23:42 - Starting Management Interface
. 2017.06.14 11:23:42 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:23:43 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:23:43 - Flushing DNS
I 2017.06.14 11:23:46 - Checking route
E 2017.06.14 11:23:56 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:23:56 - Checking route (2° try)
E 2017.06.14 11:24:07 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:24:07 - Checking route (3° try)
E 2017.06.14 11:24:19 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:24:19 - Routing checking failed.
. 2017.06.14 11:24:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:24:19 - Disconnecting
. 2017.06.14 11:24:19 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:24:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:24:19 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:24:19 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:24:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 89.249.74.212 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:24:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:24:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:24:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:24:24 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:24:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:24:24 - Connection terminated.
. 2017.06.14 11:24:25 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:24:28 - Checking authorization ...
! 2017.06.14 11:24:28 - Connecting to Chow (United Kingdom, Manchester)
. 2017.06.14 11:24:28 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:24:28 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:24:28 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:24:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:24:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:24:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:24:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]89.249.74.217:443
. 2017.06.14 11:24:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:24:29 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:24:29 - OpenVPN > UDP link remote: [AF_INET]89.249.74.217:443
. 2017.06.14 11:24:29 - OpenVPN > TLS: Initial packet from [AF_INET]89.249.74.217:443, sid=03c06cfd 8de86560
. 2017.06.14 11:24:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:24:29 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:24:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:24:29 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:24:29 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:24:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:24:29 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:24:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:24:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:24:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]89.249.74.217:443
. 2017.06.14 11:24:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:24:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.2.211 255.255.0.0'
. 2017.06.14 11:24:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:24:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:24:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:24:31 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:24:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:24:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:24:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:24:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:24:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:24:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:24:31 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:24:31 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:24:31 - OpenVPN > open_tun
. 2017.06.14 11:24:31 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:24:31 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:24:31 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.2.211/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:24:31 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.2.211/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:24:31 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:24:31 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:24:37 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:24:37 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 89.249.74.217 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:24:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:24:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:24:37 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:24:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:24:37 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:24:37 - Starting Management Interface
. 2017.06.14 11:24:37 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:24:37 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:24:37 - Flushing DNS
I 2017.06.14 11:24:40 - Checking route
E 2017.06.14 11:24:50 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:24:50 - Checking route (2° try)
E 2017.06.14 11:25:01 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:25:01 - Checking route (3° try)
E 2017.06.14 11:25:14 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:25:14 - Routing checking failed.
. 2017.06.14 11:25:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:25:14 - Disconnecting
. 2017.06.14 11:25:14 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:25:14 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:25:14 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:25:14 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:25:20 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 89.249.74.217 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:25:20 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:25:20 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:25:20 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:25:20 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:25:20 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:25:20 - Connection terminated.
. 2017.06.14 11:25:20 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:25:32 - Checking authorization ...
! 2017.06.14 11:25:32 - Connecting to Alshain (United Kingdom, London)
. 2017.06.14 11:25:32 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:25:32 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:25:32 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:25:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:25:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:25:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:25:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.06.14 11:25:33 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:25:33 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:25:33 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.06.14 11:25:33 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=ad298cac af7a739d
. 2017.06.14 11:25:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:25:33 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:25:33 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:25:33 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:25:33 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:25:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:25:33 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:25:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:25:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:25:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.06.14 11:25:35 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:25:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.200 255.255.0.0'
. 2017.06.14 11:25:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:25:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:25:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:25:35 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:25:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:25:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:25:35 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:25:35 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:25:35 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:25:35 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:25:35 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:25:35 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:25:35 - OpenVPN > open_tun
. 2017.06.14 11:25:36 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:25:36 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:25:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.23.200/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:25:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.23.200/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:25:36 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:25:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:25:40 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:25:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 217.151.98.162 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:25:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:25:40 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:25:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:25:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:25:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:25:40 - Starting Management Interface
. 2017.06.14 11:25:40 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:25:40 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:25:40 - Flushing DNS
I 2017.06.14 11:25:43 - Checking route
E 2017.06.14 11:25:53 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:25:53 - Checking route (2° try)
E 2017.06.14 11:26:04 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:26:04 - Checking route (3° try)
E 2017.06.14 11:26:17 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:26:17 - Routing checking failed.
. 2017.06.14 11:26:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:26:17 - Disconnecting
. 2017.06.14 11:26:17 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:26:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:26:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:26:17 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:26:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 217.151.98.162 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:26:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:26:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:26:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:26:22 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:26:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:26:22 - Connection terminated.
. 2017.06.14 11:26:22 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:26:25 - Checking authorization ...
! 2017.06.14 11:26:26 - Connecting to Metallah (United States, Pennsylvania)
. 2017.06.14 11:26:26 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:26:26 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:26:26 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:26:26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:26:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:26:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:26:26 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.243.24.235:443
. 2017.06.14 11:26:26 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:26:26 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:26:26 - OpenVPN > UDP link remote: [AF_INET]104.243.24.235:443
. 2017.06.14 11:26:26 - OpenVPN > TLS: Initial packet from [AF_INET]104.243.24.235:443, sid=aac9bb16 64a9d66a
. 2017.06.14 11:26:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:26:26 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:26:26 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:26:26 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:26:26 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:26:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:26:26 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:26:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:26:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:26:28 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.243.24.235:443
. 2017.06.14 11:26:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:26:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.9.64 255.255.0.0'
. 2017.06.14 11:26:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:26:29 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:26:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:26:29 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:26:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:26:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:26:29 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:26:29 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:26:29 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:26:29 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:26:29 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:26:29 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:26:29 - OpenVPN > open_tun
. 2017.06.14 11:26:29 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:26:29 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:26:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.9.64/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:26:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.9.64/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:26:29 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:26:29 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:26:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:26:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.243.24.235 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:26:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:26:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:26:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:26:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:26:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:26:34 - Starting Management Interface
. 2017.06.14 11:26:34 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:26:34 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:26:34 - Flushing DNS
I 2017.06.14 11:26:37 - Checking route
E 2017.06.14 11:26:47 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:26:47 - Checking route (2° try)
E 2017.06.14 11:26:59 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:26:59 - Checking route (3° try)
E 2017.06.14 11:27:11 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:27:11 - Routing checking failed.
. 2017.06.14 11:27:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:27:11 - Disconnecting
. 2017.06.14 11:27:11 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:27:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:27:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:27:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:27:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 104.243.24.235 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:27:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:27:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:27:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:27:17 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:27:17 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:27:17 - Connection terminated.
. 2017.06.14 11:27:17 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:27:20 - Checking authorization ...
! 2017.06.14 11:27:21 - Connecting to Albireo (United States, Atlanta, Georgia)
. 2017.06.14 11:27:21 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:27:21 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:27:21 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:27:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:27:21 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:27:21 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:27:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.129.24.178:443
. 2017.06.14 11:27:21 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:27:21 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:27:21 - OpenVPN > UDP link remote: [AF_INET]104.129.24.178:443
. 2017.06.14 11:27:21 - OpenVPN > TLS: Initial packet from [AF_INET]104.129.24.178:443, sid=a9e485db 727199a2
. 2017.06.14 11:27:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:27:21 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:27:21 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:27:21 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:27:21 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:27:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:27:21 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:27:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.14 11:27:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:27:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.129.24.178:443
. 2017.06.14 11:27:24 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:27:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.38.5 255.255.0.0'
. 2017.06.14 11:27:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:27:24 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:27:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:27:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:27:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:27:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:27:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:27:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:27:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.14 11:27:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:27:24 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:27:24 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:27:24 - OpenVPN > open_tun
. 2017.06.14 11:27:24 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:27:24 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:27:24 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.38.5/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:27:24 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.38.5/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:27:24 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:27:24 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:27:29 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:27:29 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.129.24.178 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:27:29 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:27:29 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:27:29 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:27:29 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:27:29 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:27:29 - Starting Management Interface
. 2017.06.14 11:27:29 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:27:29 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:27:29 - Flushing DNS
I 2017.06.14 11:27:32 - Checking route
E 2017.06.14 11:27:42 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:27:42 - Checking route (2° try)
E 2017.06.14 11:27:54 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
. 2017.06.14 11:27:54 - Checking route (3° try)
E 2017.06.14 11:28:06 - curl: (28) Operation timed out after 0 milliseconds with 0 out of 0 bytes received
E 2017.06.14 11:28:06 - Routing checking failed.
. 2017.06.14 11:28:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.06.14 11:28:06 - Disconnecting
. 2017.06.14 11:28:06 - Management - Send 'signal SIGTERM'
. 2017.06.14 11:28:06 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:28:06 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.14 11:28:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.14 11:28:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 104.129.24.178 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:28:11 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.14 11:28:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:28:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:28:11 - OpenVPN > Closing TUN/TAP interface
. 2017.06.14 11:28:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.14 11:28:11 - Connection terminated.
. 2017.06.14 11:28:12 - DNS leak protection with packet filtering disabled.
I 2017.06.14 11:28:15 - Checking authorization ...
! 2017.06.14 11:28:15 - Connecting to Sagittarius (United States, Atlanta, Georgia)
. 2017.06.14 11:28:15 - OpenVPN > OpenVPN 2.4.0 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.14 11:28:15 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 32bit
. 2017.06.14 11:28:15 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.06.14 11:28:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.14 11:28:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:28:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.14 11:28:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]108.177.134.74:443
. 2017.06.14 11:28:16 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.14 11:28:16 - OpenVPN > UDP link local: (not bound)
. 2017.06.14 11:28:16 - OpenVPN > UDP link remote: [AF_INET]108.177.134.74:443
. 2017.06.14 11:28:16 - OpenVPN > TLS: Initial packet from [AF_INET]108.177.134.74:443, sid=2384e6ac 12ab5f86
. 2017.06.14 11:28:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.14 11:28:16 - OpenVPN > Validating certificate key usage
. 2017.06.14 11:28:16 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.06.14 11:28:16 - OpenVPN > VERIFY KU OK
. 2017.06.14 11:28:16 - OpenVPN > Validating certificate extended key usage
. 2017.06.14 11:28:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.14 11:28:16 - OpenVPN > VERIFY EKU OK
. 2017.06.14 11:28:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sagittarius, emailAddress=info@airvpn.org
. 2017.06.14 11:28:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.14 11:28:16 - OpenVPN > [Sagittarius] Peer Connection Initiated with [AF_INET]108.177.134.74:443
. 2017.06.14 11:28:17 - OpenVPN > SENT CONTROL [Sagittarius]: 'PUSH_REQUEST' (status=1)
. 2017.06.14 11:28:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.107 255.255.0.0,peer-id 25,cipher AES-256-GCM'
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.14 11:28:18 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.14 11:28:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.14 11:28:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.14 11:28:18 - OpenVPN > interactive service msg_channel=0
. 2017.06.14 11:28:18 - OpenVPN > ROUTE_GATEWAY 100.89.0.1/255.255.0.0 I=2 HWADDR=00:26:08:e8:c2:3f
. 2017.06.14 11:28:18 - OpenVPN > open_tun
. 2017.06.14 11:28:18 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{D3B0D076-2686-44C0-871D-D72BB36D3F5C}.tap
. 2017.06.14 11:28:18 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.14 11:28:18 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.107/255.255.0.0 [SUCCEEDED]
. 2017.06.14 11:28:18 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.107/255.255.0.0 on interface {D3B0D076-2686-44C0-871D-D72BB36D3F5C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.14 11:28:18 - OpenVPN > Successful ARP Flush on interface [15] {D3B0D076-2686-44C0-871D-D72BB36D3F5C}
. 2017.06.14 11:28:18 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.14 11:28:23 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.14 11:28:23 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 108.177.134.74 MASK 255.255.255.255 100.89.0.1
. 2017.06.14 11:28:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=60 and dwForwardType=4
. 2017.06.14 11:28:23 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.14 11:28:23 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:28:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.06.14 11:28:23 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.14 11:28:23 - Starting Management Interface
. 2017.06.14 11:28:23 - OpenVPN > Initialization Sequence Completed
. 2017.06.14 11:28:23 - DNS leak protection with packet filtering enabled.
. 2017.06.14 11:28:23 - Flushing DNS
I 2017.06.14 11:28:27 - Checking route
I 2017.06.14 11:28:28 - Checking DNS
! 2017.06.14 11:28:41 - Connected.
. 2017.06.14 11:28:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.14 11:28:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.14 11:32:33 - Updating systems & servers data ...
. 2017.06.14 11:32:35 - Systems & servers data update completed
. 2017.06.14 11:43:28 - Updating systems & servers data ...
. 2017.06.14 11:43:29 - Systems & servers data update completed
#3 Ajmqwi32i9efm212r99sc
  • New Members
  • Pip
  • 1 posts
Posted 17 June 2017 - 04:34 PM
Im inside the EU and I have the exact same Problem on my main system and my laptop. Both use Win 10 Pro with creators update.
OpenVPN also only works with TCP, since the 14th. Other UDP based VPNs (non AirVPN) still work.
I guess that either Win10 or the telcoms started to block AirVPN on UDP?
I added it to my firewall, though.
EDIT: I also can't connect to US Servers.
#4 Ash2341
Ash2341
  • New Members
  • Pip
  • 1 posts
Posted 20 June 2017 - 08:19 PM
I am having a similar problem in that I cannot connect either. Eddie says 'waiting for latency tests 216 to go and just sits there. Tried lots of other servers and it either does this or doesn't connect.
I am on Windows 10 pro, but haven't updated to creators update yet, but windows has told me it is ready for it so maybe that's the problem?
Eddie is working on 2 other computers, both on windows 10 pro too and using the same internet line so I don't know what to do. Tried uninstalling etc, but same problem. I am based in the UK.
Anyone got any ideas?
Cheers
Ash
#5 hamsteak
hamsteak
  • New Members
  • Pip
  • 2 posts
Posted 23 June 2017 - 04:54 PM
I updated my Win 10 Home a few days ago to 16226 Insider build and don't have any problem connecting to Canada. Will give US and UK a try to see if I can connect to either of those.
#6 hamsteak
hamsteak
  • New Members
  • Pip
  • 2 posts
Posted 23 June 2017 - 07:16 PM
Even though I live in the United States, I was not able to connect to either USA or UK servers.
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 13352 - BW: 37253 Mbit/sYour IP: 23.20.245.192Guest Access.
