Not connected, Your IP: 18.222.22.244
j0pad0pa
General Disconnects and lack of a connection.
I am sorry I don't have more details, but perhaps the devs can tell me what to post to resolve the problem.  For the past day or so, I am getting reconnects and disconnects, and ping times are way up.  Also, AirVPN will list that the client is connected, but I have been getting no connection (e.g., can't view web pages).  This is an intermittent problem, and switching servers fixes the problem, but then a few minutes later, the problem starts again.
I am also getting Capatcha screens with many websites I visit (see attached image).
I have been using AirVPN for many years now and I haven't changed any configuration settings since it worked last.
I have attached my logs -- perhaps by looking at this you can help me figure out if the problem is AirVPN or my ISP?
Eddie_20170607_090457.txt
UPDATED Log 10:25am: Eddie_20170607_102438.txt
UPDATED Log 2:04pm: It just happened again.
Eddie_20170607_140159.txt
Here is a copy of the latest log [in spoiler mode]:
I 2017.06.07 11:05:30 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.3.9600.0, Mono/.Net Framework: v4.0.30319
. 2017.06.07 11:05:30 - Reading options from C:\Users\Sysop\AppData\Local\AirVPN\AirVPN.xml
. 2017.06.07 11:05:31 - Data path: C:\Users\Sysop\AppData\Local\AirVPN
. 2017.06.07 11:05:31 - Application path: C:\Program Files\AirVPN
. 2017.06.07 11:05:31 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.06.07 11:05:31 - Command line arguments (1): path="home"
. 2017.06.07 11:05:31 - Operating System: Microsoft Windows NT 6.3.9600.0
I 2017.06.07 11:05:34 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.06.07 11:05:34 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.06.07 11:05:34 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.06.07 11:05:34 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.06.07 11:05:34 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.06.07 11:05:34 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
! 2017.06.07 11:05:58 - Activation of Network Lock - Windows Filtering Platform
. 2017.06.07 11:05:58 - Updating systems & servers data ...
I 2017.06.07 11:05:58 - Session starting.
. 2017.06.07 11:05:58 - IPv6 disabled with packet filtering.
. 2017.06.07 11:06:02 - Systems & servers data update completed
I 2017.06.07 11:06:02 - Checking authorization ...
! 2017.06.07 11:06:03 - Connecting to Sagittarius (United States, Atlanta, Georgia)
. 2017.06.07 11:06:04 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.07 11:06:04 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.07 11:06:04 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.07 11:06:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.07 11:06:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 11:06:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 11:06:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]108.177.134.74:443
. 2017.06.07 11:06:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.07 11:06:04 - OpenVPN > UDP link local: (not bound)
. 2017.06.07 11:06:04 - OpenVPN > UDP link remote: [AF_INET]108.177.134.74:443
. 2017.06.07 11:06:04 - OpenVPN > TLS: Initial packet from [AF_INET]108.177.134.74:443, sid=ee51eff0 bd51c3ef
. 2017.06.07 11:06:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.07 11:06:04 - OpenVPN > Validating certificate key usage
. 2017.06.07 11:06:04 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.07 11:06:04 - OpenVPN > VERIFY KU OK
. 2017.06.07 11:06:04 - OpenVPN > Validating certificate extended key usage
. 2017.06.07 11:06:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.07 11:06:04 - OpenVPN > VERIFY EKU OK
. 2017.06.07 11:06:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sagittarius, emailAddress=info@airvpn.org
. 2017.06.07 11:06:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.07 11:06:04 - OpenVPN > [sagittarius] Peer Connection Initiated with [AF_INET]108.177.134.74:443
. 2017.06.07 11:06:05 - OpenVPN > SENT CONTROL [sagittarius]: 'PUSH_REQUEST' (status=1)
. 2017.06.07 11:06:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.140 255.255.0.0,peer-id 62,cipher AES-256-GCM'
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.07 11:06:05 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.07 11:06:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 11:06:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 11:06:05 - OpenVPN > interactive service msg_channel=0
. 2017.06.07 11:06:05 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=6 HWADDR=10:08:b1:3e:a1:1f
. 2017.06.07 11:06:05 - OpenVPN > open_tun
. 2017.06.07 11:06:06 - OpenVPN > TAP-WIN32 device [Ethernet 5] opened: \\.\Global\{55955DAC-B0A6-42C3-BF58-55A9BC9357BB}.tap
. 2017.06.07 11:06:06 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.07 11:06:06 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.3.140/255.255.0.0 [sUCCEEDED]
. 2017.06.07 11:06:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.140/255.255.0.0 on interface {55955DAC-B0A6-42C3-BF58-55A9BC9357BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.07 11:06:06 - OpenVPN > Successful ARP Flush on interface [18] {55955DAC-B0A6-42C3-BF58-55A9BC9357BB}
. 2017.06.07 11:06:06 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.07 11:06:10 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.07 11:06:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 108.177.134.74 MASK 255.255.255.255 192.168.1.1
. 2017.06.07 11:06:10 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.06.07 11:06:10 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.07 11:06:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 11:06:10 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.06.07 11:06:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 11:06:10 - Starting Management Interface
. 2017.06.07 11:06:10 - OpenVPN > Initialization Sequence Completed
. 2017.06.07 11:06:11 - DNS leak protection with packet filtering enabled.
. 2017.06.07 11:06:11 - Flushing DNS
I 2017.06.07 11:06:19 - Checking route
E 2017.06.07 11:07:00 - curl: (28) Connection timed out after 10047 milliseconds
. 2017.06.07 11:07:00 - Checking route (2° try)
E 2017.06.07 11:07:12 - curl: (28) Connection timed out after 10047 milliseconds
. 2017.06.07 11:07:12 - Checking route (3° try)
I 2017.06.07 11:07:15 - Checking DNS
! 2017.06.07 11:07:16 - Connected.
. 2017.06.07 11:07:16 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.07 11:07:16 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #228 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:07:16 - Above log line repeated 1 times more
. 2017.06.07 11:07:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.07 11:16:35 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #935 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:16:59 - Updating systems & servers data ...
. 2017.06.07 11:17:16 - Systems & servers data update completed
. 2017.06.07 11:17:36 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1545 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:27:38 - Above log line repeated 15 times more
. 2017.06.07 11:27:38 - Updating systems & servers data ...
. 2017.06.07 11:27:40 - Systems & servers data update completed
. 2017.06.07 11:37:55 - Updating systems & servers data ...
. 2017.06.07 11:37:56 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #7311 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:37:56 - Systems & servers data update completed
. 2017.06.07 11:38:03 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #7334 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:48:13 - Above log line repeated 14 times more
. 2017.06.07 11:48:13 - Updating systems & servers data ...
. 2017.06.07 11:48:16 - Systems & servers data update completed
. 2017.06.07 11:48:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #31227 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:52:17 - Above log line repeated 6 times more
. 2017.06.07 11:52:17 - OpenVPN > [sagittarius] Inactivity timeout (--ping-restart), restarting
. 2017.06.07 11:52:17 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2017.06.07 11:52:17 - OpenVPN > Restart pause, 5 second(s)
! 2017.06.07 11:52:17 - Disconnecting
. 2017.06.07 11:52:17 - Management - Send 'signal SIGTERM'
. 2017.06.07 11:52:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.07 11:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 108.177.134.74 MASK 255.255.255.255 192.168.1.1
. 2017.06.07 11:52:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.07 11:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 11:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 11:52:17 - OpenVPN > Closing TUN/TAP interface
. 2017.06.07 11:52:17 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2017.06.07 11:52:17 - Connection terminated.
. 2017.06.07 11:52:17 - DNS leak protection with packet filtering disabled.
I 2017.06.07 11:52:25 - Checking authorization ...
! 2017.06.07 11:52:26 - Connecting to Octans (United States, Atlanta, Georgia)
. 2017.06.07 11:52:26 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.07 11:52:26 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.07 11:52:26 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.07 11:52:26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.07 11:52:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 11:52:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 11:52:26 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]108.62.228.186:443
. 2017.06.07 11:52:26 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.07 11:52:26 - OpenVPN > UDP link local: (not bound)
. 2017.06.07 11:52:26 - OpenVPN > UDP link remote: [AF_INET]108.62.228.186:443
. 2017.06.07 11:52:26 - OpenVPN > TLS: Initial packet from [AF_INET]108.62.228.186:443, sid=e4d52dc9 f32130c0
. 2017.06.07 11:52:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.07 11:52:26 - OpenVPN > Validating certificate key usage
. 2017.06.07 11:52:26 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.07 11:52:26 - OpenVPN > VERIFY KU OK
. 2017.06.07 11:52:26 - OpenVPN > Validating certificate extended key usage
. 2017.06.07 11:52:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.07 11:52:26 - OpenVPN > VERIFY EKU OK
. 2017.06.07 11:52:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Octans, emailAddress=info@airvpn.org
. 2017.06.07 11:52:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.07 11:52:27 - OpenVPN > [Octans] Peer Connection Initiated with [AF_INET]108.62.228.186:443
. 2017.06.07 11:52:28 - OpenVPN > SENT CONTROL [Octans]: 'PUSH_REQUEST' (status=1)
. 2017.06.07 11:52:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.54 255.255.0.0,peer-id 34,cipher AES-256-GCM'
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.06.07 11:52:28 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.06.07 11:52:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 11:52:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 11:52:28 - OpenVPN > interactive service msg_channel=0
. 2017.06.07 11:52:28 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=6 HWADDR=10:08:b1:3e:a1:1f
. 2017.06.07 11:52:28 - OpenVPN > open_tun
. 2017.06.07 11:52:28 - OpenVPN > TAP-WIN32 device [Ethernet 5] opened: \\.\Global\{55955DAC-B0A6-42C3-BF58-55A9BC9357BB}.tap
. 2017.06.07 11:52:28 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.07 11:52:28 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.3.54/255.255.0.0 [sUCCEEDED]
. 2017.06.07 11:52:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.54/255.255.0.0 on interface {55955DAC-B0A6-42C3-BF58-55A9BC9357BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.07 11:52:28 - OpenVPN > Successful ARP Flush on interface [18] {55955DAC-B0A6-42C3-BF58-55A9BC9357BB}
. 2017.06.07 11:52:28 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.07 11:52:33 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.07 11:52:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 108.62.228.186 MASK 255.255.255.255 192.168.1.1
. 2017.06.07 11:52:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.06.07 11:52:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.07 11:52:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 11:52:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.06.07 11:52:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 11:52:33 - Starting Management Interface
. 2017.06.07 11:52:33 - OpenVPN > Initialization Sequence Completed
. 2017.06.07 11:52:33 - DNS leak protection with packet filtering enabled.
. 2017.06.07 11:52:33 - Flushing DNS
I 2017.06.07 11:52:37 - Checking route
I 2017.06.07 11:52:38 - Checking DNS
! 2017.06.07 11:52:39 - Connected.
. 2017.06.07 11:52:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.07 11:52:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.07 11:52:40 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #998 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 11:58:31 - Above log line repeated 13 times more
. 2017.06.07 11:58:31 - Updating systems & servers data ...
. 2017.06.07 11:58:34 - Systems & servers data update completed
. 2017.06.07 11:58:36 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #7060 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:08:48 - Above log line repeated 14 times more
. 2017.06.07 12:08:48 - Updating systems & servers data ...
. 2017.06.07 12:09:00 - Systems & servers data update completed
. 2017.06.07 12:09:05 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #11657 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:19:13 - Above log line repeated 14 times more
. 2017.06.07 12:19:13 - Updating systems & servers data ...
. 2017.06.07 12:19:13 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #13053 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:19:14 - Systems & servers data update completed
. 2017.06.07 12:19:55 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #13178 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:29:28 - Above log line repeated 3 times more
. 2017.06.07 12:29:28 - Updating systems & servers data ...
. 2017.06.07 12:29:29 - Systems & servers data update completed
. 2017.06.07 12:29:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #15082 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:39:39 - Above log line repeated 8 times more
. 2017.06.07 12:39:39 - Updating systems & servers data ...
. 2017.06.07 12:39:41 - Systems & servers data update completed
. 2017.06.07 12:39:41 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #15945 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:49:43 - Above log line repeated 8 times more
. 2017.06.07 12:49:43 - Updating systems & servers data ...
. 2017.06.07 12:49:45 - Systems & servers data update completed
. 2017.06.07 12:49:54 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #18648 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:52:27 - Above log line repeated 1 times more
. 2017.06.07 12:52:27 - OpenVPN > TLS: soft reset sec=0 bytes=13830482/-1 pkts=34463/0
. 2017.06.07 12:52:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.07 12:52:27 - OpenVPN > Validating certificate key usage
. 2017.06.07 12:52:27 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.07 12:52:27 - OpenVPN > VERIFY KU OK
. 2017.06.07 12:52:27 - OpenVPN > Validating certificate extended key usage
. 2017.06.07 12:52:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.07 12:52:27 - OpenVPN > VERIFY EKU OK
. 2017.06.07 12:52:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Octans, emailAddress=info@airvpn.org
. 2017.06.07 12:52:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 12:52:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 12:52:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.07 12:56:10 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #155 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 12:59:47 - Updating systems & servers data ...
. 2017.06.07 12:59:49 - Systems & servers data update completed
. 2017.06.07 12:59:50 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #430 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:09:51 - Above log line repeated 8 times more
. 2017.06.07 13:09:51 - Updating systems & servers data ...
. 2017.06.07 13:09:53 - Systems & servers data update completed
. 2017.06.07 13:10:25 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #9882 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:19:56 - Above log line repeated 12 times more
. 2017.06.07 13:19:56 - Updating systems & servers data ...
. 2017.06.07 13:19:57 - Systems & servers data update completed
. 2017.06.07 13:20:06 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #40525 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:30:00 - Above log line repeated 32 times more
. 2017.06.07 13:30:00 - Updating systems & servers data ...
. 2017.06.07 13:30:12 - Systems & servers data update completed
. 2017.06.07 13:30:34 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #43889 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:40:15 - Above log line repeated 9 times more
. 2017.06.07 13:40:15 - Updating systems & servers data ...
. 2017.06.07 13:40:16 - Systems & servers data update completed
. 2017.06.07 13:40:42 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #46747 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:50:19 - Above log line repeated 24 times more
. 2017.06.07 13:50:19 - Updating systems & servers data ...
. 2017.06.07 13:50:24 - Systems & servers data update completed
. 2017.06.07 13:50:36 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #50054 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:52:27 - Above log line repeated 3 times more
. 2017.06.07 13:52:27 - OpenVPN > TLS: soft reset sec=0 bytes=60526036/-1 pkts=98548/0
. 2017.06.07 13:52:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.07 13:52:27 - OpenVPN > Validating certificate key usage
. 2017.06.07 13:52:27 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.07 13:52:27 - OpenVPN > VERIFY KU OK
. 2017.06.07 13:52:27 - OpenVPN > Validating certificate extended key usage
. 2017.06.07 13:52:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.07 13:52:27 - OpenVPN > VERIFY EKU OK
. 2017.06.07 13:52:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Octans, emailAddress=info@airvpn.org
. 2017.06.07 13:52:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 13:52:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.06.07 13:52:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.07 13:52:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #50609 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 13:55:09 - Above log line repeated 1 times more
. 2017.06.07 13:55:09 - OpenVPN > [Octans] Inactivity timeout (--ping-restart), restarting
. 2017.06.07 13:55:09 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2017.06.07 13:55:09 - OpenVPN > Restart pause, 5 second(s)
! 2017.06.07 13:55:09 - Disconnecting
. 2017.06.07 13:55:09 - Management - Send 'signal SIGTERM'
. 2017.06.07 13:55:09 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.07 13:55:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 108.62.228.186 MASK 255.255.255.255 192.168.1.1
. 2017.06.07 13:55:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.06.07 13:55:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 13:55:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 13:55:09 - OpenVPN > Closing TUN/TAP interface
. 2017.06.07 13:55:09 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2017.06.07 13:55:09 - Connection terminated.
. 2017.06.07 13:55:09 - DNS leak protection with packet filtering disabled.
I 2017.06.07 13:55:16 - Checking authorization ...
! 2017.06.07 13:55:17 - Connecting to Alsafi (United States, Dallas, Texas)
. 2017.06.07 13:55:17 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.06.07 13:55:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.06.07 13:55:17 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.07 13:55:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.06.07 13:55:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 13:55:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 13:55:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]107.183.238.194:443
. 2017.06.07 13:55:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.06.07 13:55:17 - OpenVPN > UDP link local: (not bound)
. 2017.06.07 13:55:17 - OpenVPN > UDP link remote: [AF_INET]107.183.238.194:443
. 2017.06.07 13:55:17 - OpenVPN > TLS: Initial packet from [AF_INET]107.183.238.194:443, sid=0cf8117d 82a8e753
. 2017.06.07 13:55:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.07 13:55:17 - OpenVPN > Validating certificate key usage
. 2017.06.07 13:55:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.07 13:55:17 - OpenVPN > VERIFY KU OK
. 2017.06.07 13:55:17 - OpenVPN > Validating certificate extended key usage
. 2017.06.07 13:55:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.07 13:55:17 - OpenVPN > VERIFY EKU OK
. 2017.06.07 13:55:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.07 13:55:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.07 13:55:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]107.183.238.194:443
. 2017.06.07 13:55:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.07 13:55:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.16 255.255.0.0'
. 2017.06.07 13:55:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.07 13:55:19 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.07 13:55:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.07 13:55:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.07 13:55:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.07 13:55:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.07 13:55:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.07 13:55:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 13:55:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.07 13:55:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.07 13:55:19 - OpenVPN > interactive service msg_channel=0
. 2017.06.07 13:55:19 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=6 HWADDR=10:08:b1:3e:a1:1f
. 2017.06.07 13:55:19 - OpenVPN > open_tun
. 2017.06.07 13:55:19 - OpenVPN > TAP-WIN32 device [Ethernet 5] opened: \\.\Global\{55955DAC-B0A6-42C3-BF58-55A9BC9357BB}.tap
. 2017.06.07 13:55:19 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.06.07 13:55:19 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.16/255.255.0.0 [sUCCEEDED]
. 2017.06.07 13:55:19 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.16/255.255.0.0 on interface {55955DAC-B0A6-42C3-BF58-55A9BC9357BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.06.07 13:55:19 - OpenVPN > Successful ARP Flush on interface [18] {55955DAC-B0A6-42C3-BF58-55A9BC9357BB}
. 2017.06.07 13:55:19 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.07 13:55:24 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.06.07 13:55:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 107.183.238.194 MASK 255.255.255.255 192.168.1.1
. 2017.06.07 13:55:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.06.07 13:55:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.06.07 13:55:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 13:55:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.06.07 13:55:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.06.07 13:55:24 - Starting Management Interface
. 2017.06.07 13:55:24 - OpenVPN > Initialization Sequence Completed
. 2017.06.07 13:55:24 - DNS leak protection with packet filtering enabled.
. 2017.06.07 13:55:24 - Flushing DNS
I 2017.06.07 13:55:28 - Checking route
I 2017.06.07 13:55:29 - Checking DNS
! 2017.06.07 13:55:30 - Connected.
. 2017.06.07 13:55:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.07 13:55:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.06.07 13:55:30 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #136 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.06.07 14:00:27 - Updating systems & servers data ...
. 2017.06.07 14:01:09 - Cannot retrieve systems & servers data. (curl: (28) Connection timed out after 10047 milliseconds)
Seeing a lot of this: AEAD Decrypt error: bad packet ID
Thanks.
JpD.
TCP would work around this. Make sure there is nothing on your system or network interfering with UDP traffic, such as internet security suites with firewalls, QoS settings on the router, etc. Seems like you did change something, did an update somewhere or I don't know. Just don't say something like "I can't figure it out on my system, must be AirVPN or ISP..." hint: it's rarely the case.
Sent via Tapatalk. Means, I don't have a computer available now.
Software is all the same, although I did replace the router with a new one.  How would that change anything?  It's a fast Netgear Nighthawk Model# R6700 v2. How would a router affect AirVPN on a laptop?
Now look at that, you DID change something
All your traffic goes through the router, and the router could attempt to "optimize" certain kinds of traffic. It's more common with newer routers, so you should look through your router's settings and ask here or someone in private to help you identify possible VPN-breaking settings.
I want to follow-up on this thread -- it is a month later and I just plugged this bad boy back in, but I'm still getting disconnects and difficulties loading websites after a few minutes after a successful handshake.
. 2017.08.13 18:10:12 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #75 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings [over and over]
So, let's focus on the NETGEAR GENIE settings for the Netgear Nighthawk Model# R6700v2.
Are there any Netgear Genie setting that I should be aware of that affect or break the AirVPN client connection?
Thanks!
Any chance someone can comment on this?  The Netgear Nighthawk Model# R6700 v2 router uses Netgear Genie.
I want to know whether there are any settings on here that I should configure to make the router more "friendly" to AirVPN.
I still find that the connection goes dead and that I need to disconnect and reconnect (or switch AirVPN servers), and I know the problem is coming from the Netgear router.
Please help... anyone?
You`re not alone. I`m also using AirVPN for several years now, and I have the same problem with permanent disconnection for serveral month now, using a different router. This is really terrible, but obviously there is no solution available.
I tried other VPN-provider, no problem at all. So what to do? I would rather like to stay with AIRVPN, so I`m still hoping to get rid of these annoying disconnection:
  2017.08.26 20:10:39 - Connected.
. 2017.08.26 20:10:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.08.26 20:10:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.08.26 20:19:42 - Updating systems & servers data ...
. 2017.08.26 20:19:43 - Systems & servers data update completed
. 2017.08.26 20:21:14 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2017.08.26 20:21:14 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2017.08.26 20:21:14 - OpenVPN > Restart pause, 5 second(s)
! 2017.08.26 20:21:14 - Disconnecting
etc.
etc.
Try the following:
Check the router ping settings. I'm not familiar with netgear software or any other software. But found this on the net: http://documentation.netgear.com/wgt624v3/enu/202-10090-02/WGT624v3-07-09.html
"Respond to ping on internet port" option
On certain routers there might be two options: The first can be "ignore ping packet from internet WAN port," and the second can be "Forbid ping from internet WAN port," to router.
Switch on the respond to ping option. In other cases, uncheck the "forbid" option and try the Eddie client.
The router would return pings from the net. For a normal mortal, it would be of no concern, but depends on how much of security is desired by the user.
If the above does not work, download the latest openvpn client. The latest release has updated security. Login here and create config files for the usual servers and save them in  the desired place on the computer. Open the Openvpn client and left click on the tray icon and "import files." Openvpn client has to be connected manually to the desired airvpn server.
Hope this helps.
