Not connected, Your IP: 18.189.2.122
Ashadyguy
Constantly timing out before connection
Hey guys,
I'm still relatively new to using AirVPN and have been trying it out. It's been working fine since I've had it and started using it and I like it a lot, but since yesterday, every time I try to connect to any server, it will try to connect before checking DNS and then time out and repeat the process, without allowing me to connect. I don't know if I'm just being stupid or missing something, but if anyone could explain this a bit to me I would appreciate it.
My logs are below
E 2017.06.02 11:48:24 - curl: (28) Connection timed out after 10004 milliseconds
E 2017.06.02 11:48:24 - DNS checking failed.
. 2017.06.02 11:48:24 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101
! 2017.06.02 11:48:24 - Disconnecting
. 2017.06.02 11:48:24 - Management - Send 'signal SIGTERM'
. 2017.06.02 11:48:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.06.02 11:48:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.06.02 11:48:24 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.06.02 11:48:24 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2017.06.02 11:48:30 - OpenVPN > /sbin/route delete -net 88.150.240.7 192.168.178.1 255.255.255.255
. 2017.06.02 11:48:30 - OpenVPN > delete net 88.150.240.7: gateway 192.168.178.1
. 2017.06.02 11:48:30 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.06.02 11:48:30 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.06.02 11:48:30 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.06.02 11:48:30 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.06.02 11:48:30 - OpenVPN > Closing TUN/TAP interface
. 2017.06.02 11:48:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.06.02 11:48:30 - Connection terminated.
. 2017.06.02 11:48:30 - DNS of a network adapter restored to original settings (MT65xx Preloader, to Automatic)
. 2017.06.02 11:48:30 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2017.06.02 11:48:30 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2017.06.02 11:48:30 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
I 2017.06.02 11:48:33 - Checking authorization ...
! 2017.06.02 11:48:33 - Connecting to Alshain (United Kingdom, London)
. 2017.06.02 11:48:33 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.06.02 11:48:33 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.06.02 11:48:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2017.06.02 11:48:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.02 11:48:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.02 11:48:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.06.02 11:48:34 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.06.02 11:48:34 - OpenVPN > UDP link local: (not bound)
. 2017.06.02 11:48:34 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.06.02 11:48:34 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=aefedc5a 29575860
. 2017.06.02 11:48:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.06.02 11:48:34 - OpenVPN > Validating certificate key usage
. 2017.06.02 11:48:34 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.06.02 11:48:34 - OpenVPN > VERIFY KU OK
. 2017.06.02 11:48:34 - OpenVPN > Validating certificate extended key usage
. 2017.06.02 11:48:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.06.02 11:48:34 - OpenVPN > VERIFY EKU OK
. 2017.06.02 11:48:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.06.02 11:48:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.06.02 11:48:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.06.02 11:48:35 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.06.02 11:48:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.27.164 255.255.0.0'
. 2017.06.02 11:48:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.06.02 11:48:35 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.06.02 11:48:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.06.02 11:48:35 - OpenVPN > route: writing to routing socket: File exists
. 2017.06.02 11:48:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.06.02 11:48:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.06.02 11:48:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.06.02 11:48:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.06.02 11:48:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.02 11:48:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.02 11:48:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.06.02 11:48:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.06.02 11:48:36 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=en0 HWADDR=c8:69:cd:9d:6c:a4
. 2017.06.02 11:48:36 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.06.02 11:48:36 - OpenVPN > Opened utun device utun1
. 2017.06.02 11:48:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.06.02 11:48:36 - OpenVPN > /sbin/ifconfig utun1 delete
. 2017.06.02 11:48:36 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.06.02 11:48:36 - OpenVPN > /sbin/ifconfig utun1 10.4.27.164 10.4.27.164 netmask 255.255.0.0 mtu 1500 up
. 2017.06.02 11:48:36 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.27.164 255.255.0.0
. 2017.06.02 11:48:36 - OpenVPN > add net 10.4.0.0: gateway 10.4.27.164: File exists
. 2017.06.02 11:48:36 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.178.1 255.255.255.255
. 2017.06.02 11:48:36 - OpenVPN > add net 217.151.98.162: gateway 192.168.178.1
. 2017.06.02 11:48:36 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.06.02 11:48:36 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.06.02 11:48:36 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.06.02 11:48:36 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.06.02 11:48:36 - Starting Management Interface
. 2017.06.02 11:48:36 - OpenVPN > Initialization Sequence Completed
. 2017.06.02 11:48:36 - DNS of a network adapter forced (MT65xx Preloader, from Automatic to 10.4.0.1)
. 2017.06.02 11:48:36 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2017.06.02 11:48:36 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2017.06.02 11:48:36 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.06.02 11:48:36 - Flushing DNS
I 2017.06.02 11:48:36 - Checking DNS
Thanks.
