Not connected, Your IP: 3.22.181.211
electricsheep
Connection refused (code=111) Openvpn - Android
I am having troubles trying to connect with openvpn (Android ) It worked fine until today....(I am not tech-savy at all)
I already tried to uncheck the bypass option...And both TCP and UDP protocols.
https://airvpn.org/topic/19934-openvpn-for-android-connection-refused/?hl=+connection%20+refused%20+code
Thank you.
EDIT: seems to work now....
Edited ... by electricsheep
