Clavis 0 Posted ... Hi there, just renewed my Subscription after a little break and for some reason the AirVPN client isnt working anymore. Never had problems with it 1/2 Year ago.Always getting that "Zeichenabstände sind ungültig und können nicht entfernt werden." error that could be translated into "Character space is invalid and could not be removed".No idea what that error text is supposed to tell me.Changed my password to a one without special characters, reseted config to default, nothing helped.Connecting over OpenVPN works flawless. I 2017.04.30 13:54:52 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.15063.0, Mono/.Net Framework: v4.0.30319. 2017.04.30 13:54:53 - Operating System: Microsoft Windows NT 10.0.15063.0I 2017.04.30 13:54:53 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)I 2017.04.30 13:54:53 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)I 2017.04.30 13:54:53 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)I 2017.04.30 13:54:53 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)I 2017.04.30 13:54:53 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem! 2017.04.30 13:54:53 - Activation of Network Lock - Windows Filtering Platform! 2017.04.30 13:54:53 - Ready. 2017.04.30 13:54:53 - Updating systems & servers data ...I 2017.04.30 13:54:55 - Checking login .... 2017.04.30 13:55:04 - Cannot retrieve systems & servers data. (Zeichenabstände sind ungültig und können nicht entfernt werden.)F 2017.04.30 13:55:06 - Cannot login. (Zeichenabstände sind ungültig und können nicht entfernt werden.) Quote Share this post Link to post
Staff 9761 Posted ... Hello!Can you please try again now? Kind regards Quote Share this post Link to post
msheurich 0 Posted ... I have the same problem. Could somebody pls help? Quote Share this post Link to post
msheurich 0 Posted ... I use Eddie and I got the error message"AirVPN - Cannot login. (Padding is invalid and cannot be removed.)"At the same time login via web is fine.Pls help! Quote Share this post Link to post
escher 0 Posted ... I am also having this issue on windows 8.1 - it doesn't matter what I put in as the username and password, the error is the same. Tried both the latest stable 2.12.4 and the experimental 2.13.2 - same issue both times. Any update on this issue ? Quote Share this post Link to post
