machavez 1 Posted ... Hi, Eddie client on the PC does some ping latency tests in order to choose the best server to connect, so I wonder, if Im connecting using Android Openvpn Connect or Openvpn Client free, how does AirVpn handle my connection? base on which criteria a servers gets pick? Regards. Quote Share this post Link to post
go558a83nk 352 Posted ... If you're not using a specific server it'll connect you to the least busy server of the region you've chosen. Quote Share this post Link to post
machavez 1 Posted ... So if Im choosing "Earth" I will get the least busy server from all over the world?? jeje. So maybe I should pick the nearest regions, or do you have any suggestions on how to get servers with low latency automatically? Quote Share this post Link to post
go558a83nk 352 Posted ... So if Im choosing "Earth" I will get the least busy server from all over the world?? jeje. So maybe I should pick the nearest regions, or do you have any suggestions on how to get servers with low latency automatically? There is no automatic way to get low latency when using configs. Just load configs for servers that you know are low latency to where you are or will be. Quote Share this post Link to post
