Not connected, Your IP: 3.149.24.159
foDkc4UySz
IPv6 and TAP driver: enable or disabled?
Standard laptop set up. Windows 7 x64. One WiFi card w/ IPv6 disabled. TAP driver installs by default with IPv6 enabled. AirVPN functions perfectly it seems, within logs I see mention of IPv6 filtering being enabled and disabled without error, and multiple "leak test" sites suggest nothing to be concerned about.
What's the advice on the IPv6 setting for the TAP driver: leave it enabled by default or disable it manually?
I often recommend disabling, if it's not in use. Mostly because it gives a lot of people a headache when it causes problems.
