marcmv1 1 Posted ... Hi, I'm on Fedora 25 and using qbittorrent. I have access to AirVPN and IPVanish. When I download torrents from rarbg, the trackers are trackerfix.com:80 udp:rarbg.to:2710 and udp:rarbg.me:2710 The UDP torrent trackers are working fine when connected to IPV however when connected to AirVPN qbittorrent says "Not Working". In addition, trackerfix.com is unreachable from AirVPN but reachable when I'm not connected. The same behavior is present in Dallas and Chicago AirVPN servers. From AirVPN nc -v -z -u 9.rarbg.to 2710 Ncat: Version 7.40 ( https://nmap.org/ncat )Ncat: Connected to 151.80.120.115:2710.Ncat: UDP packet sent successfullyNcat: 1 bytes sent, 0 bytes received in 2.03 seconds nc -v -z -u 9.rarbg.me 2710Ncat: Version 7.40 ( https://nmap.org/ncat )Ncat: Connected to 151.80.120.113:2710.Ncat: UDP packet sent successfullyNcat: 1 bytes sent, 0 bytes received in 2.32 seconds. [root@tigger ~/rdp]# nc -v -z tracker.trackerfix.com 80 Ncat: Version 7.40 ( https://nmap.org/ncat )Ncat: Connection to 5.39.105.100 failed: Connection timed out.Ncat: Trying next address...Ncat: Connection to 5.39.105.102 failed: Connection timed out.Ncat: Trying next address...Ncat: Connection timed out. From not AirVPN nc -v -z tracker.trackerfix.com 80Ncat: Version 7.40 ( https://nmap.org/ncat )Ncat: Connected to 5.39.105.101:80.Ncat: 0 bytes sent, 0 bytes received in 0.32 seconds. nc -v -z -u 9.rarbg.to 2710Ncat: Version 7.40 ( https://nmap.org/ncat )Ncat: Connected to 151.80.120.113:2710.Ncat: UDP packet sent successfullyNcat: 1 bytes sent, 0 bytes received in 2.35 seconds. nc -v -z -u 9.rarbg.me 2710Ncat: Version 7.40 ( https://nmap.org/ncat )Ncat: Connected to 151.80.120.113:2710.Ncat: UDP packet sent successfullyNcat: 1 bytes sent, 0 bytes received in 2.10 seconds. 1 123456seven reacted to this Share this post Link to post
nick75 25 Posted ... Hi, The likeliest answer is that the administrators have decided to ban those servers. Share this post Link to post
go558a83nk 343 Posted ... Hi, The likeliest answer is that the administrators have decided to ban those servers. you may need to clarify your statement. Air doesn't block or ban anything. What happens is the trackers block the VPN servers. Some Air servers have access, some don't. So, it's the trackers blocking selectively. Share this post Link to post
Whisperer 2 Posted ... Apologize for awakening an old topic, but the alternative is to start a duplicate one. I have the exact same issue. Of the (currently) 23 servers on NewTrackon, only the http-trackers are able to be queried. All UDP trackers report "Could not connect to tracker"Without the VPN tunnel, all but 2 of them work just fine.Many of these trackers respond to ICMP (ping), so the AirVPN server-IP is not blocked, at least not unconditionally. 1 123456seven reacted to this Share this post Link to post
123456seven 0 Posted ... Seeing the same issue: udp trackers blocked. Any solution? Share this post Link to post
OlDirty 0 Posted ... I'm seeing the exact same problem since about a week... Is anyone else having this issue as well? I've tried with 2 Dutch server and a random Roemenian server. If someone is not having this issue, can you please say which server you're using? Thanks! Share this post Link to post
OpenSourcerer 1352 Posted ... For everyone in the future: Open your own thread, give as much info as you can, possibly the same way as OP in this thread. Don't forget logs of OpenVPN/Eddie, of your torrent client, etc. Also note that many public trackers outright ban IPs, networks, and even whole AS numbers of VPN servers and known VPN server ISPs/datacenters from accessing them. Could be another factor. Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
