hackers2016 13 Posted ... hello everyone Can someone tell me what I did wrong. I setup pfSense on VM with airvpn suddenly all my hosts behind the firewall cannot access the internet I checked the firewall log and I found that my firewall is blocking the traffic The rule that triggered this action is:@114(1465196278) block return in log quick on em1 inet from 192.168.1.0/24 to <PRIVATE_NETWORKS:3> label "USER_RULE: REJECT LOCAL" thank you EDIT: Host can ping the pfsense but pfsense cannot ping any host on this subnet 192.168.1.0/24 Quote Share this post Link to post
hackers2016 13 Posted ... Apr 6 10:24:52 AIRVPN_LAN 192.168.1.18:138 192.168.1.255:138 UDP The rule that triggered this action is:@132(1465196278) block return in log quick on em1 inet from 192.168.1.0/24 to <PRIVATE_NETWORKS:3> label "USER_RULE: REJECT LOCAL" anyone Quote Share this post Link to post
go558a83nk 352 Posted ... you might have better luck posting this in the actual pfsense setup thread. Quote Share this post Link to post
kungur 0 Posted ... is your WAN IP private? check WAN interface for blocking private and bogon networks Quote Share this post Link to post
hackers2016 13 Posted ... is your WAN IP private? check WAN interface for blocking private and bogon networksyes both are checked edit: I can ping 8.8.8.8 fromWANWAN IPv6 Link-LocalAirVPN_WANAirVPN_WAN IPv6 Link-LocalAirVPN_LAN IPv6 Link-Localand localhostbut not from AirVPN_LAN Quote Share this post Link to post
