pyq 1 Posted ... (edited) The other day overything worked fine using the portable client. Then I formatted my system and suddenly couldn't connect with the portable client anymore. I have no clue why. Any hints how to fix that? This is my log: I 2017.03.22 22:17:49 - Eddie client version: 2.12.4 / linux_x64, System: Linux, Name: Manjaro Linux \r (\n) (\l), Mono/.Net Framework: v4.0.30319 . 2017.03.22 22:17:49 - Reading options from /home/jonathan/eddie-ui_2.12.4_linux_x64_portable/AirVPN.xml . 2017.03.22 22:17:49 - Data path: /home/jonathan/eddie-ui_2.12.4_linux_x64_portable . 2017.03.22 22:17:49 - Application path: /home/jonathan/eddie-ui_2.12.4_linux_x64_portable . 2017.03.22 22:17:49 - Executable path: /home/jonathan/eddie-ui_2.12.4_linux_x64_portable/airvpn . 2017.03.22 22:17:49 - Command line arguments (0): . 2017.03.22 22:17:49 - Operating System: Unix 4.9.15.1 - Linux jonjaro 4.9.15-1-MANJARO #1 SMP PREEMPT Wed Mar 15 21:29:34 UTC 2017 x86_64 GNU/Linux I 2017.03.22 22:17:50 - OpenVPN Driver - Found, /dev/net/tun I 2017.03.22 22:17:50 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (/home/jonathan/eddie-ui_2.12.4_linux_x64_portable/openvpn) I 2017.03.22 22:17:50 - SSH - Version: OpenSSH_7.4p1, OpenSSL 1.0.2k 26 Jan 2017 (/usr/bin/ssh) I 2017.03.22 22:17:50 - SSL - Version: stunnel 5.40 (/home/jonathan/eddie-ui_2.12.4_linux_x64_portable/stunnel) I 2017.03.22 22:17:50 - curl - Version: 7.53.1 (/usr/bin/curl) I 2017.03.22 22:17:50 - Certification Authorities: /home/jonathan/eddie-ui_2.12.4_linux_x64_portable/cacert.pem . 2017.03.22 22:17:50 - Updating systems & servers data ... I 2017.03.22 22:17:50 - Session starting. . 2017.03.22 22:17:50 - Unable to understand if IPv6 is active. . 2017.03.22 22:17:53 - Systems & servers data update completed I 2017.03.22 22:18:02 - Checking authorization ... ! 2017.03.22 22:18:02 - Connecting to Rukbat (Netherlands, Alblasserdam) . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[ui]: stunnel 5.40 on x86_64-unknown-linux-gnu platform . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[ui]: Threading:PTHREAD Sockets:POLL,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[ui]: Reading configuration from file /home/jonathan/eddie-ui_2.12.4_linux_x64_portable/c7ff7edc61ce47d42c7b082c524fd7a2c744d2074f36396398ea8bd617ca3961.tmp.ssl . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[ui]: UTF-8 byte order mark not detected . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG6[ui]: Initializing service [openvpn] . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[ui]: Configuration successful . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:46088 . 2017.03.22 22:18:02 - SSL > 2017.03.22 22:18:02 LOG6[0]: s_connect: connecting 213.152.162.85:443 . 2017.03.22 22:18:02 - OpenVPN > OpenVPN 2.4.0 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 29 2017 . 2017.03.22 22:18:02 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 . 2017.03.22 22:18:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2017.03.22 22:18:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:02 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:49619 . 2017.03.22 22:18:02 - OpenVPN > Socket Buffers: R=[87380->87380] S=[16384->16384] . 2017.03.22 22:18:02 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:49619 [nonblock] . 2017.03.22 22:18:02 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:49619 . 2017.03.22 22:18:02 - OpenVPN > TCP_CLIENT link local: (not bound) . 2017.03.22 22:18:02 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:49619 . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG5[0]: s_connect: connected 213.152.162.85:443 . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.12:53094 . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG6[0]: SNI: sending servername: 213.152.162.85 . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG6[0]: Peer certificate not required . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG6[0]: Certificate verification disabled . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG6[0]: Client certificate not requested . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG6[0]: TLS connected: new session negotiated . 2017.03.22 22:18:03 - SSL > 2017.03.22 22:18:03 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption) . 2017.03.22 22:18:04 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:49619, sid=a5580b2a eab1a66a . 2017.03.22 22:18:05 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2017.03.22 22:18:05 - OpenVPN > Validating certificate key usage . 2017.03.22 22:18:05 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2017.03.22 22:18:05 - OpenVPN > VERIFY KU OK . 2017.03.22 22:18:05 - OpenVPN > Validating certificate extended key usage . 2017.03.22 22:18:05 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2017.03.22 22:18:05 - OpenVPN > VERIFY EKU OK . 2017.03.22 22:18:05 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2017.03.22 22:18:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2017.03.22 22:18:06 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:49619 . 2017.03.22 22:18:08 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2017.03.22 22:18:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.10.101 255.255.0.0' . 2017.03.22 22:18:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2017.03.22 22:18:08 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2017.03.22 22:18:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2017.03.22 22:18:08 - OpenVPN > OPTIONS IMPORT: route options modified . 2017.03.22 22:18:08 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2017.03.22 22:18:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2017.03.22 22:18:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2017.03.22 22:18:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2017.03.22 22:18:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:08 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlp3s0 HWADDR=e4:a4:71:6e:e8:08 . 2017.03.22 22:18:08 - SSL > 2017.03.22 22:18:08 LOG6[0]: Read socket closed (readsocket) . 2017.03.22 22:18:08 - OpenVPN > TUN/TAP device tun0 opened . 2017.03.22 22:18:08 - SSL > 2017.03.22 22:18:08 LOG6[0]: SSL_shutdown successfully sent close_notify alert . 2017.03.22 22:18:08 - OpenVPN > TUN/TAP TX queue length set to 100 . 2017.03.22 22:18:08 - SSL > 2017.03.22 22:18:08 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing . 2017.03.22 22:18:08 - SSL > 2017.03.22 22:18:08 LOG5[0]: Connection closed: 4090 byte(s) sent to TLS, 4653 byte(s) sent to socket . 2017.03.22 22:18:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0 . 2017.03.22 22:18:08 - OpenVPN > /sbin/ifconfig tun0 10.50.10.101 netmask 255.255.0.0 mtu 1500 broadcast 10.50.255.255 . 2017.03.22 22:18:08 - OpenVPN > Linux ifconfig failed: could not execute external program . 2017.03.22 22:18:08 - OpenVPN > Exiting due to fatal error ! 2017.03.22 22:18:08 - Disconnecting . 2017.03.22 22:18:08 - Connection terminated. I 2017.03.22 22:18:11 - Checking authorization ... ! 2017.03.22 22:18:12 - Connecting to Elnath (Netherlands, Alblasserdam) . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[ui]: stunnel 5.40 on x86_64-unknown-linux-gnu platform . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[ui]: Threading:PTHREAD Sockets:POLL,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[ui]: Reading configuration from file /home/jonathan/eddie-ui_2.12.4_linux_x64_portable/ab504fb5ae97951adc167f4c25ca8c179b14b09b6d96d45577c93d0594e2c98b.tmp.ssl . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[ui]: UTF-8 byte order mark not detected . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG6[ui]: Initializing service [openvpn] . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[ui]: Configuration successful . 2017.03.22 22:18:12 - OpenVPN > OpenVPN 2.4.0 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 29 2017 . 2017.03.22 22:18:12 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:35858 . 2017.03.22 22:18:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2017.03.22 22:18:12 - SSL > 2017.03.22 22:18:12 LOG6[0]: s_connect: connecting 213.152.180.6:443 . 2017.03.22 22:18:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:46029 . 2017.03.22 22:18:12 - OpenVPN > Socket Buffers: R=[87380->87380] S=[16384->16384] . 2017.03.22 22:18:12 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:46029 [nonblock] . 2017.03.22 22:18:12 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:46029 . 2017.03.22 22:18:12 - OpenVPN > TCP_CLIENT link local: (not bound) . 2017.03.22 22:18:12 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:46029 . 2017.03.22 22:18:13 - SSL > 2017.03.22 22:18:13 LOG5[0]: s_connect: connected 213.152.180.6:443 . 2017.03.22 22:18:13 - SSL > 2017.03.22 22:18:13 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.12:41634 . 2017.03.22 22:18:13 - SSL > 2017.03.22 22:18:13 LOG6[0]: SNI: sending servername: 213.152.180.6 . 2017.03.22 22:18:13 - SSL > 2017.03.22 22:18:13 LOG6[0]: Peer certificate not required . 2017.03.22 22:18:14 - SSL > 2017.03.22 22:18:14 LOG6[0]: Certificate verification disabled . 2017.03.22 22:18:14 - SSL > 2017.03.22 22:18:14 LOG6[0]: Client certificate not requested . 2017.03.22 22:18:15 - SSL > 2017.03.22 22:18:15 LOG6[0]: TLS connected: new session negotiated . 2017.03.22 22:18:15 - SSL > 2017.03.22 22:18:15 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption) . 2017.03.22 22:18:15 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:46029, sid=36733d43 9e7b7f0b . 2017.03.22 22:18:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2017.03.22 22:18:16 - OpenVPN > Validating certificate key usage . 2017.03.22 22:18:16 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2017.03.22 22:18:16 - OpenVPN > VERIFY KU OK . 2017.03.22 22:18:16 - OpenVPN > Validating certificate extended key usage . 2017.03.22 22:18:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2017.03.22 22:18:16 - OpenVPN > VERIFY EKU OK . 2017.03.22 22:18:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2017.03.22 22:18:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2017.03.22 22:18:16 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:46029 . 2017.03.22 22:18:18 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2017.03.22 22:18:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.9.192 255.255.0.0' . 2017.03.22 22:18:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2017.03.22 22:18:18 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2017.03.22 22:18:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2017.03.22 22:18:18 - OpenVPN > OPTIONS IMPORT: route options modified . 2017.03.22 22:18:18 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2017.03.22 22:18:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2017.03.22 22:18:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2017.03.22 22:18:18 - SSL > 2017.03.22 22:18:18 LOG6[0]: Read socket closed (readsocket) . 2017.03.22 22:18:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:18 - SSL > 2017.03.22 22:18:18 LOG6[0]: SSL_shutdown successfully sent close_notify alert . 2017.03.22 22:18:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2017.03.22 22:18:18 - SSL > 2017.03.22 22:18:18 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing . 2017.03.22 22:18:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:18 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlp3s0 HWADDR=e4:a4:71:6e:e8:08 . 2017.03.22 22:18:18 - SSL > 2017.03.22 22:18:18 LOG5[0]: Connection closed: 4090 byte(s) sent to TLS, 4652 byte(s) sent to socket . 2017.03.22 22:18:18 - OpenVPN > TUN/TAP device tun0 opened . 2017.03.22 22:18:18 - OpenVPN > TUN/TAP TX queue length set to 100 . 2017.03.22 22:18:18 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0 ! 2017.03.22 22:18:18 - Disconnecting . 2017.03.22 22:18:18 - OpenVPN > /sbin/ifconfig tun0 10.50.9.192 netmask 255.255.0.0 mtu 1500 broadcast 10.50.255.255 . 2017.03.22 22:18:18 - OpenVPN > Linux ifconfig failed: could not execute external program . 2017.03.22 22:18:18 - OpenVPN > Exiting due to fatal error . 2017.03.22 22:18:18 - Connection terminated. I 2017.03.22 22:18:21 - Checking authorization ... ! 2017.03.22 22:18:22 - Connecting to Asellus (Netherlands, Alblasserdam) . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[ui]: stunnel 5.40 on x86_64-unknown-linux-gnu platform . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[ui]: Threading:PTHREAD Sockets:POLL,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[ui]: Reading configuration from file /home/jonathan/eddie-ui_2.12.4_linux_x64_portable/5a23ed3a3228c915403759cf81b71f4f7f0b281bd2804ad90b51a78e0d0208ed.tmp.ssl . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[ui]: UTF-8 byte order mark not detected . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG6[ui]: Initializing service [openvpn] . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[ui]: Configuration successful . 2017.03.22 22:18:22 - OpenVPN > OpenVPN 2.4.0 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 29 2017 . 2017.03.22 22:18:22 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:58026 . 2017.03.22 22:18:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2017.03.22 22:18:22 - SSL > 2017.03.22 22:18:22 LOG6[0]: s_connect: connecting 109.202.107.21:443 . 2017.03.22 22:18:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2017.03.22 22:18:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:9177 . 2017.03.22 22:18:22 - OpenVPN > Socket Buffers: R=[87380->87380] S=[16384->16384] . 2017.03.22 22:18:22 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:9177 [nonblock] . 2017.03.22 22:18:22 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:9177 . 2017.03.22 22:18:22 - OpenVPN > TCP_CLIENT link local: (not bound) . 2017.03.22 22:18:22 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:9177 . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG5[0]: s_connect: connected 109.202.107.21:443 . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.12:39224 . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG6[0]: SNI: sending servername: 109.202.107.21 . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG6[0]: Peer certificate not required . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG6[0]: Certificate verification disabled . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG6[0]: Client certificate not requested . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG6[0]: TLS connected: new session negotiated . 2017.03.22 22:18:23 - SSL > 2017.03.22 22:18:23 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption) . 2017.03.22 22:18:23 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:9177, sid=d3ed7284 e2137c20 ! 2017.03.22 22:18:24 - Disconnecting . 2017.03.22 22:18:24 - SSL > 2017.03.22 22:18:24 LOG6[0]: Read socket closed (readsocket) . 2017.03.22 22:18:24 - SSL > 2017.03.22 22:18:24 LOG6[0]: SSL_shutdown successfully sent close_notify alert . 2017.03.22 22:18:24 - SSL > 2017.03.22 22:18:24 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing . 2017.03.22 22:18:24 - SSL > 2017.03.22 22:18:24 LOG5[0]: Connection closed: 313 byte(s) sent to TLS, 56 byte(s) sent to socket . 2017.03.22 22:18:24 - Connection terminated. I 2017.03.22 22:18:24 - Cancel requested. ! 2017.03.22 22:18:24 - Session terminated. Edited ... by giganerd Apply LOG formatting to logs Share this post Link to post
LZ1 662 Posted ... Hello! Have you tried using a different protocol from SSL? Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
pyq 1 Posted ... Yes, I tried several different protocols, but always end up with the fatal error or just staying in a connection-retry loop. I really don't get it, it worked just a few days ago (https://airvpn.org/topic/22266-speed-in-china/) on an almost fresh Manjaro install like this one now. Share this post Link to post
OpenSourcerer 1359 Posted ... Check if the net-tools package is installed.If yes, check if ifconfig is in /sbin/ifconfig. It might be in /bin, create a symlink in this case. 1 pyq reacted to this Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
pyq 1 Posted ... Check if the net-tools package is installed. That was the problem, thanks a lot! Share this post Link to post
