Not connected, Your IP: 3.144.113.197
Hello
I downloaded the debain 32bit linux client and installated it succesfully. However I cannot connect to any servers. I assume because of some firewall issues in the whonix gateway, but I'm new to linux, watch some youtube videos here and there but mostly teaching myself. Anyways, it will try to connect, fail, reauthorize, try again, repeat.
I read the log the best I could but can't put my finger on it. Any help is appreciated, thanks.
I 2017.03.22 05:00:01 - Checking authorization ...
! 2017.03.22 05:00:03 - Connecting to Albireo (United States, Atlanta, Georgia)
. 2017.03.22 05:00:03 - OpenVPN > OpenVPN 2.3.4 i586-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 19 2015
. 2017.03.22 05:00:03 - OpenVPN > library versions: OpenSSL 1.0.1t  3 May 2016, LZO 2.08
. 2017.03.22 05:00:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.22 05:00:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.22 05:00:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.22 05:00:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.22 05:00:03 - OpenVPN > Socket Buffers: R=[163840->131072] S=[163840->131072]
. 2017.03.22 05:00:03 - OpenVPN > UDPv4 link local: [undef]
. 2017.03.22 05:00:03 - OpenVPN > UDPv4 link remote: [AF_INET]104.129.24.178:443
. 2017.03.22 05:00:35 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.03.22 05:00:35 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.22 05:00:40 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.03.22 05:00:40 - Disconnecting
. 2017.03.22 05:00:40 - Connection terminated.
I 2017.03.22 05:00:43 - Checking authorization ...
! 2017.03.22 05:00:45 - Connecting to Albireo (United States, Atlanta, Georgia)
. 2017.03.22 05:00:45 - OpenVPN > OpenVPN 2.3.4 i586-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 19 2015
. 2017.03.22 05:00:45 - OpenVPN > library versions: OpenSSL 1.0.1t  3 May 2016, LZO 2.08
. 2017.03.22 05:00:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.22 05:00:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.03.22 05:00:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.22 05:00:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.22 05:00:45 - OpenVPN > Socket Buffers: R=[163840->131072] S=[163840->131072]
. 2017.03.22 05:00:45 - OpenVPN > UDPv4 link local: [undef]
. 2017.03.22 05:00:45 - OpenVPN > UDPv4 link remote: [AF_INET]104.129.24.178:443
. 2017.03.22 05:01:17 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.03.22 05:01:17 - OpenVPN > SIGTERM received, sending exit notification to peer
! 2017.03.22 05:01:20 - Disconnecting
. 2017.03.22 05:01:20 - Connection terminated.
I 2017.03.22 05:01:20 - Cancel requested.
! 2017.03.22 05:01:20 - Session terminated.
That's your line. Try other servers, ports and protocols and report if something is working.
UDP won't work in Whonix, because it is routed via Tor which only supports TCP by design.
Change to TCP and it should work.
hi there
is there a possibility to hire / tip you to help setting up on my whonix too
this is the last day of my 3 day trial and i couldnt make it work still
The Eddie client or the built-in openvpn with Network Manager will both work, the only mandatory setting is to choose TCP in the protocol.
Make sure first that your workstation and gateway work properly, i.e. that all traffic from the workstation goes via the gateway and your internet
connection and applications such as the browser are working. Then you will be able to connect with TCP.
