I'm using AirVPN from China and am getting Speed between 100 (or less) and 1000 (rarely) kbit/s. I tried to set the TCP/UDP buffer sizes to 256 KB, which didn't change anything. Then I saw another forum post where it was suggested to set them to OpenVPN on a Linux machine, which didn't change anything either. I am using Eddie 2.12.4 (before updating to this version the speed was very low too), so I tried to speed up through the mssfix (which I entered in the settings OVPN directives -> Custom directives), unfortunately no change in speed either.
I tried choosing some Servers in Asia (Hong Kong, Singapore), but they seemed to be even slower than European ones, which I would get through autom
I tried choosing some Servers in Asia (Hong Kong, Singapore), but they seemed to be even slower than European ones, which I would get through automatic selection anyways.
Is there anyone using AirVPN in China with acceptable speed, at least above 10 mbit/s? Or does anyone have any suggestions what I could be doing wrong / could try to get more speed? Before I've been using a friends Astrill VPN, which has been way faster than what I'm getting in speed now. However, I changed to another Linux distribution and couldn't get Astrill running on it. I would love to keep using AirVPN, but ...
Cheers!
Thanks for the quick response!
I tried that, but get the error "ssl not found" for all three options. Does that have to do with Eddie, AirVPN or am I missing some packages? I'm using Manjaro, with the openssl packages installed.
Judging by my 20 minutes of testing so far the speed has improved quite a bit!
Thanks a lot!
My ISP, TalkTalk appears to be disrupting my connection when I use AirVPN.  My connection has been reliable for years, and still is until I use airVPN.  i hope the ssl tunnel is a way around this.  Is there a thread telling how to set this up?  I'm using the Eddie client to connect to the VPN.
Thanks In Advance.
Thanks In Advance.
In Eddie just go into preferences>protocols and select SSL.  Then (re)connect.
