Eddie 2.12.4 SSH connection
  • This topic is locked This topic is locked
6 replies to this topic
#1 slim2001
slim2001
    Member
  • Members
  • PipPip
  • 16 posts
Posted 19 March 2017 - 01:27 AM
I've just updated to the latest version of eddie and now I can't login using the SSH ports, the previous version had no issues
. 2017.03.19 01:04:46 - SSH > OpenSSH_7.3p1, LibreSSL 2.4.1
. 2017.03.19 01:04:46 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config
. 2017.03.19 01:04:46 - SSH > debug1: /etc/ssh/ssh_config line 20: Applying options for *
. 2017.03.19 01:04:46 - SSH > debug1: /etc/ssh/ssh_config line 56: Applying options for *
. 2017.03.19 01:04:46 - SSH > debug1: Connecting to 213.152.162.153 [213.152.162.153] port 22.
. 2017.03.19 01:04:46 - SSH > debug1: Connection established.
. 2017.03.19 01:04:46 - SSH > debug1: permanently_set_uid: 501/20
. 2017.03.19 01:04:46 - SSH > debug1: key_load_public: No such file or directory
. 2017.03.19 01:04:46 - SSH > debug1: identity file /Users/****/.airvpn/e57c23a47705e0e3a2bc3565cf6e1b13729bfe037f5280e51f2564d1f6e9c496.tmp.key type -1
. 2017.03.19 01:04:46 - SSH > debug1: identity file /Users/****/.airvpn/e57c23a47705e0e3a2bc3565cf6e1b13729bfe037f5280e51f2564d1f6e9c496.tmp.key-cert type -1
. 2017.03.19 01:04:46 - SSH > debug1: Enabling compatibility mode for protocol 2.0
. 2017.03.19 01:04:46 - SSH > debug1: Local version string SSH-2.0-OpenSSH_7.3
. 2017.03.19 01:04:46 - SSH > debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Debian-5+deb8u1
. 2017.03.19 01:04:46 - SSH > debug1: match: OpenSSH_6.7p1 Debian-5+deb8u1 pat OpenSSH* compat 0x04000000
. 2017.03.19 01:04:46 - SSH > debug1: Authenticating to 213.152.162.153:22 as 'sshtunnel'
. 2017.03.19 01:04:46 - SSH > debug1: SSH2_MSG_KEXINIT sent
. 2017.03.19 01:04:46 - SSH > debug1: SSH2_MSG_KEXINIT received
. 2017.03.19 01:04:46 - SSH > debug1: kex: algorithm: curve25519-sha256@libssh.org
. 2017.03.19 01:04:46 - SSH > debug1: kex: host key algorithm: ecdsa-sha2-nistp256
. 2017.03.19 01:04:46 - SSH > debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
. 2017.03.19 01:04:46 - SSH > debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
. 2017.03.19 01:04:46 - SSH > debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
. 2017.03.19 01:04:46 - SSH > debug1: Server host key: ecdsa-sha2-nistp256 SHA256:dKQRbRqgJUIpwV8/awEsOjhdmrka4iGKdL6nBA2G7bQ
. 2017.03.19 01:04:46 - SSH > Warning: Permanently added '213.152.162.153' (ECDSA) to the list of known hosts.
. 2017.03.19 01:04:46 - SSH > debug1: rekey after 134217728 blocks
. 2017.03.19 01:04:46 - SSH > debug1: SSH2_MSG_NEWKEYS sent
. 2017.03.19 01:04:46 - SSH > debug1: expecting SSH2_MSG_NEWKEYS
. 2017.03.19 01:04:46 - SSH > debug1: SSH2_MSG_NEWKEYS received
. 2017.03.19 01:04:46 - SSH > debug1: SSH2_MSG_SERVICE_ACCEPT received
. 2017.03.19 01:04:46 - SSH > debug1: Authentications that can continue: publickey,password
. 2017.03.19 01:04:46 - SSH > debug1: Next authentication method: publickey
. 2017.03.19 01:04:46 - SSH > debug1: Trying private key: /Users/****/.airvpn/e57c23a47705e0e3a2bc3565cf6e1b13729bfe037f5280e51f2564d1f6e9c496.tmp.key
. 2017.03.19 01:04:46 - SSH > Load key "/Users/****/.airvpn/e57c23a47705e0e3a2bc3565cf6e1b13729bfe037f5280e51f2564d1f6e9c496.tmp.key": Permission denied
. 2017.03.19 01:04:46 - SSH > debug1: Next authentication method: password
. 2017.03.19 01:04:46 - SSH > debug1: read_passphrase: can't open /dev/tty: Device not configured
. 2017.03.19 01:04:46 - SSH > debug1: permanently_drop_suid: 501
. 2017.03.19 01:04:46 - SSH > ssh_askpass: exec(/usr/X11R6/bin/ssh-askpass): No such file or directory
. 2017.03.19 01:04:46 - SSH > Permission denied, please try again.
. 2017.03.19 01:04:46 - SSH > debug1: No more authentication methods to try.
. 2017.03.19 01:04:46 - SSH > Permission denied (publickey,password)****
#2 slim2001
slim2001
    Member
  • Members
  • PipPip
  • 16 posts
Posted 19 March 2017 - 01:55 AM
Just gone back to 2.11.15 and now everything is working fine again.
#3 slim2001
slim2001
    Member
  • Members
  • PipPip
  • 16 posts
Posted 19 March 2017 - 06:27 PM
I think there's something wrong with the SSH configuration files.
I'm using 2.11.15, which connects fine using SSH, the latest version (2.12.4) however doesn't connect via SSH.
I've downloaded the configuration files and tried using viscosity and tunnelblick to connect via SSH and none of them worked.
#4 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7050 posts
Posted 19 March 2017 - 07:36 PM
The SSH configuration files are fine, to connect please follow the instructions here:
https://airvpn.org/ssl
We don't know about Viscosity, but Tunnelblick does not support OpenVPN over proxy or SSH or stunnel connections, we're sorry.
Developers have anyway been informed about the issue in Eddie 2.12.4 and if the bug is confirmed it will be fixed very soon.
#5 slim2001
slim2001
    Member
  • Members
  • PipPip
  • 16 posts
Posted 19 March 2017 - 07:55 PM
You mean this link
https://airvpn.org/ssh
That worked with viscosity fine after using the command line
#6 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7050 posts
Posted 19 March 2017 - 08:32 PM
You mean this link
Yes, sorry about the typo, the correct link is the one you mentioned.
#7 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7050 posts
Posted 20 March 2017 - 03:19 PM
Fixed. Please see here:
https://airvpn.org/topic/22214-eddie-2124-released/#entry59540
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Servers online. Online Sessions: 13180 - BW: 34678 Mbit/sYour IP: 54.159.30.26Guest Access.
