Not connected, Your IP: 3.142.35.75
airvpn1q
Need a little advice on Ipv4 and Ipv6
Ive read on a few sites that I should disable Ipv6 because its better for VPN protection, So naturally I have.
Whilst looking upon my Ipv4 connection I noticed there is a drop named "method" and when I click on it I am given a choice between -
Automatic (DHCP),
Automatic (DHCP) addresses only,
Manual,
Link-Local Only,
Shared to other computers,
Disabled.
If anyone could tell me what those methods are and which one will best serve my anonymity I would greatly appreciate it.
I have tried looking up for myself what these methods are but all the information I found was to technical for my comprehension.
Thanks.
What OS is this? Just go with automatic. DHCP is a way of automatically distributing IP addresses.
It looks like you're using Linux and if so here's how to proceed (network-manager is not reliable), type this in a terminal window:
NOTE: be sure to copy/paste the whole command!!!
sudo sh -c "echo 'net.ipv6.conf.all.disable_ipv6=1\nnet.ipv6.conf.default.disable_ipv6=1\nnet.ipv6.conf.lo.disable_ipv6=1' >> /etc/sysctl.conf"
then:
sudo sysctl -p
Voilà! IPv6 will be completely disabled!
