Not connected, Your IP: 3.149.214.32
Just got airvpn and the download speeds on torrents keep rising and dropping all the time. Ive downloaded in the past without VPN and with a different VPN and the speeds were always steady around 900 kbs and 1mbs or higher. With airvpn its constantly fluctating every minute or 2. It goes up to around 1 mbs, then drops to 100kbs rinse and repeat. Already tried different servers and ports through SSL and SSH same thig.
Welcome to AirVPN!
I recommend you check out the new user guide in my signature and go to the torrent guides section. Your problem may stem from not port-forwarding to not setting things up correctly in the torrent client .
